Author Topic: [IC] LM75 - 75% keyboard of LM - CNC, Rubber/Tadpole mount  (Read 10261 times)
Offline daviddgm
« on: Tue, 18 July 2023, 04:37:41 »
Mount type
Tadpole from Geonworks (will be included)
Mount Shock Absorption Balls - used in drones (will be included)
Details
Top CNC Aluminum
Bottom CNC Aluminum
Side RGB led light through Polycarbonate
Case Angle: 6.5 degrees
Mounting: Rubber Shock Absorption Balls or Silicone Tadpole from Geonworks
Case Material: 6063 Aluminum
Making process: CNC - sandblast - anodizing
Front Height: 19 mm
Back Height: 19 mm (with chamfer) and 31 mm (before chamfer)
Weight: ~1400g and ~1800g (mounted with brass plate)
Plate:  Aluminum, Brass, PC or FR4 (PBT on demand)
PCB Compability: To be defined
Prototype
The Prototype Will be made in Aug/2023.
Expected Price
USD 120-145 more shipping fee
IC Form
https://docs.google.com/forms/d/1mD6q8YyhoaV9n8cozvay4cUxbCHHTZ18mfqdJZ_fdxI
Instagram
@lm_kbd
Regards,
Eng. David Martinz - LM Keyboards
« Last Edit: Tue, 18 July 2023, 06:38:44 by daviddgm »
Offline Furki
Re: [IC] LM75 - 75% keyboard of LM - CNC, Rubber/Tadpole mount
« Reply #1 on: Tue, 18 July 2023, 15:02:55 »
What is the final layout out of the 4 renders going to be?
And is there a hole in the side of the case or is that where the PC inlays are going to sit?
Where are the mounting points of the tadpoles
Offline daviddgm
« Reply #2 on: Tue, 18 July 2023, 17:56:36 »
Hi! After IC we want to select two most voted to make. For the first model 84key we selected pcb YMD75 that support Ansi/ISO and for compat and exploded models we want to make pcb in cooperation with Y&R Studio and maybe support Ansi/ISO.
The holes are 100x3x3mm at sides.
Mount points are 8 near to the screw holes and support alternative top mount.
« Last Edit: Wed, 19 July 2023, 06:25:40 by daviddgm »
Offline Rhienfo
  • GOTHETIGES
« Reply #3 on: Wed, 19 July 2023, 18:20:35 »
Could we see a diagram of the mounting points as this can impact a keyboard greatly. Also could we get the EKH please, it's a more accurate way of telling the front height for potential buyers.
Offline daviddgm
« Reply #4 on: Thu, 20 July 2023, 05:31:13 »
Hi! The EKH is 23mm or 24mm (depending mounting position, If you use rubber balls). About mount points are not defined, specially for the exploded version, but are 4 up and 4 down. Do you have any suggestion?
Offline godofdeath
« Reply #5 on: Fri, 21 July 2023, 15:24:39 »
OMG please number 4 if it's the layout that I think it is. Is it like the evolv75 layout?
Offline daviddgm
« Reply #6 on: Sun, 23 July 2023, 14:46:33 »
Yes, the same layout.
Offline godofdeath
« Reply #7 on: Thu, 10 August 2023, 20:03:50 »
Have you got the proto? Which layout will it be?
Offline jackrabbit
« Reply #8 on: Fri, 11 August 2023, 15:37:25 »
I think 2 is the most interesting and classy design. the angled chin is aesthetically pleasing and comfortable for your hands, and the compact 75% with separated F row is the nicest design. Exploded 75% is just bandwagoning on the popularity of the satisfaction75 and all the imitators after it, and lots of people are over that layout now because it adds too much bezel on the bottom where your hand rests. Just my 2 cents
"I like my keyboards thunderous and my plates stiff." -Maledicted
Offline godofdeath
« Reply #9 on: Sat, 12 August 2023, 18:09:38 »
The exploded 75 layout is new, not the same as sat75, it has all .25u spacing. This is someone actually trying to put to market the evolv75 layout with the 1.5u shift. So far everyone that's done an IC for the layout never put anything out.
Everyone other board with 75 has the ugly sat75 with .5u spacing or the 7v with the .25u but can only fit 3/4 keys on the right due to spacing.
Offline alper_maestro
« Reply #10 on: Tue, 29 August 2023, 04:21:14 »
Expected Price
GB price is 230 USD
no idea why, but that is a big difference suddenly. Unfortunately, the price is too high for me.
« Last Edit: Tue, 29 August 2023, 04:23:08 by alper_maestro »
Offline aicyborg
« Reply #11 on: Tue, 29 August 2023, 17:18:19 »
Expected Price
GB price is 230 USD
Where've you got this information from? Agreed that 230 is too much for what all this is - MKC75 was like 120USD or thereabouts for a HS PCB config, but I don't see where 230 is said.
« Reply #12 on: Wed, 30 August 2023, 16:34:34 »
Expected Price
GB price is 230 USD
Just check their website. GB is already live.
https://geekhack.org/index.php?topic=121144.0
https://www.dgmelet.com/opencart/index.php?route=product/product&path=68&product_id=565
