Author Topic: [IC] 21XX - A modern unsaver keyboard  (Read 42972 times)
Offline jaynoon
Re: [IC] 21XX - A modern unsaver keyboard
« Reply #50 on: Fri, 18 August 2023, 15:03:56 »
This is totally nuts and I love it
Home: Filco Tenkeyless Brown | Work: KBC Poker w/ Reds | Laptop: MacBook Air Keyboard
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #51 on: Sat, 19 August 2023, 02:42:19 »
GLWIC
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« Reply #52 on: Tue, 22 August 2023, 01:37:55 »
love it, here's my money, pls gib 2
Offline ToFuMaNiA
« Reply #53 on: Tue, 22 August 2023, 10:59:06 »
really liking the mounting type, wondering how it sounds and feels
Offline X666
« Reply #54 on: Wed, 23 August 2023, 08:28:47 »
Looks great! What keycaps on the proto?
Offline chigi22
« Reply #55 on: Wed, 23 August 2023, 08:57:28 »
Looks like CRP 2551 HAD
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #56 on: Wed, 23 August 2023, 09:31:05 »
Yeah it is, The proto was teased on the blacksimon discord and it says that.
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline Rhienfo
« Reply #57 on: Mon, 11 September 2023, 22:57:37 »
Pontus do you have an approximate estimate on when the gb will run (just in general) as I would like to know when to start saving.
Still great project :)
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline offbrandbiscuit
« Reply #58 on: Tue, 12 September 2023, 03:00:57 »
Good luck on this, I'd love to be able to try one of these. Plateless top mount is fun
i like fire trucks and moster trucks
Offline Pontus
« Reply #59 on: Tue, 12 September 2023, 14:00:48 »
I will share more details regarding a potential group buy when I get a vendor on board (hopefully soon). Personally hoping for late Q1 2024 but it depends on the vendor really, I will give an as early heads up as possible ;D
Thank you! I really enjoy plateless boards and I am glad that there are others that do as well  ;D
A bit late but as the others have said all the proto pictures feature CRP 2551had R4  ;D
Offline khai
  • Formerly spoonr00t
« Reply #60 on: Tue, 12 September 2023, 17:22:25 »
nut
Offline Rhienfo
« Reply #61 on: Tue, 12 September 2023, 17:50:06 »
Thanks, probably best to start saving now, after the navi60 cause I love serial experiments lain too much.
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #62 on: Sun, 24 September 2023, 15:53:23 »
erm.. any updates on this? need one on my desk ASAP (as soon as possible)  :p
Offline HubertThemad
  • * St. Jude Supporter
« Reply #63 on: Sat, 14 October 2023, 16:13:55 »
GLWIC! Would go well with the XMI vintage set  :cool:
Offline Pontus
« Reply #64 on: Sun, 05 November 2023, 17:16:45 »
Heyo, I hope everyone is doing well. It's time for a small update  ;D
Case has been slightly adjusted with some QOL changes to make the building process more enjoyable. The main changes are the placement of the solenoid and the inclusion of a grommet to secure smaller cables. The solenoid is now mounted on top of the PCB instead of on the bottom case floor which means you won't have to fiddle around with any cables between the two halves. PCB is being reworked to work with these changes. IC form is still open for feedback so if you want to yell at anything about the new design please do so there.
No news regarding potential vendors quite yet but I am hoping to be able to get something by the end of this month, stay tuned  :cool:
Updated render showcasing the internals
Offline derpter
« Reply #65 on: Sun, 21 January 2024, 22:20:17 »
Nice I love Frieren, will buy this weeb board most likely
Offline TjarleN
« Reply #66 on: Mon, 12 February 2024, 07:33:51 »
I keep rechecking this ic more often than i would like to admit... hopefully you will find a vendor that want to take this on soon :)
rush rush
Offline modulor
« Reply #67 on: Tue, 13 February 2024, 11:31:12 »
rush rush
Same same, here and in Pontus' Discord haha...this is my most anticipated custom board (ever) <3
21XX (soon) | Leggera-G | ClassicGLO | Frog TKL 8K | GH60 rev.C + Leggera-T | 86U 45g  | G80-2100HDU | G80-1000HBU | G80-3700HAU | QFR V1  | FC200R | PokerX | G80-11900LUMEU
Offline aa212121
« Reply #68 on: Tue, 13 February 2024, 17:19:38 »
oo i like the seams on this
Offline pelfox
« Reply #69 on: Mon, 19 February 2024, 12:52:46 »
interested if a keyboard manufacturer picks this up
en boca cerrada no entran moscas
Offline masje
    • masjewerke
« Reply #70 on: Sat, 11 January 2025, 09:57:00 »
rush rush
Offline Skfocmwla18(!
« Reply #71 on: Wed, 29 January 2025, 09:15:26 »
I want this!
Offline boku
  • 東プレ株式会社
« Reply #72 on: Thu, 30 January 2025, 16:49:53 »
Please let this come in black so I may finally have a resting place for all my black relegendables I've been saving for years
HHKB Pro2 Ivory | HHKB Pro2 Charcoal | Realforce 87UW | Realforce 101 | Edius V6KB | DN Piss Ogre
Offline Pontus
« Reply #73 on: Fri, 31 January 2025, 18:42:54 »
Definitely coming back  ;D Things are slowly but surely happening behind the scenes. I am very happy to see that people still are interested in the project, I won't let you down!
Offline IOVERCALLHISTIOCYTES
« Reply #74 on: Sat, 01 February 2025, 00:36:25 »
Looking forward to it
Be fun w the R0 caps we’re talking about in the next thread
« Reply #75 on: Sat, 01 February 2025, 12:06:38 »
If it can be launched in a data general dasher colorway, TAKE MY MONEY. I mean, I’ll take one maybe two regardless, but that would be *chefs kiss* for the dasher keycaps I’ve been saving.
Offline ZavaZ86
« Reply #76 on: Tue, 25 March 2025, 16:49:20 »
It's happening, time to panic :eek:
Offline Pontus
« Reply #77 on: Tue, 25 March 2025, 16:52:30 »
I am happy to announce that CannonKeys graciously have picked up this project. Check out their coming soon page if you want a reread on all the specs! Also happy to share that the colours have been confirmed to blue, Black, & a warm gray. I hope you all find a colour you connect with! The board will also be offered in both the blockered and teased blockerless version!
https://cannonkeys.com/products/21xx
Here's a sticker teaser as well  ;D
« Reply #78 on: Tue, 25 March 2025, 17:02:11 »
THE DAY HAS FINALLY COME
This has been the most anticipated board for me for years. LET'S GOOOO, maybe I'll get one of each color  ;D
« Reply #79 on: Tue, 25 March 2025, 17:05:25 »
LFG
Offline iamtragic
« Reply #80 on: Tue, 25 March 2025, 17:38:22 »
holy **** we're so back
Offline swag
« Reply #81 on: Tue, 25 March 2025, 18:00:59 »
Can't wait to get in on this -- the blue color is such a classic!
Offline modulor
« Reply #82 on: Tue, 25 March 2025, 21:03:16 »
Glad this got picked up and hope you get more vendor support, I'm definitely in b'-'b
« Last Edit: Wed, 26 March 2025, 19:07:49 by modulor »
Offline mr_foggy
  • neue = nope
« Reply #83 on: Wed, 26 March 2025, 04:02:35 »
I'll have one in blue please
Offline erretter
    • My Merch Shop
« Reply #84 on: Wed, 26 March 2025, 06:06:39 »
10u is a must on this board.
Offline Gemmmmmmmmmmmmmy
« Reply #85 on: Mon, 31 March 2025, 15:01:24 »
IT LIVES! I’m really excited for this
Life seems so much smaller
Swim to the moon
Offline GMK_Andy
« Reply #86 on: Tue, 01 April 2025, 21:09:56 »
Cool project  :thumb:
Offline Mikhail
« Reply #87 on: Thu, 03 April 2025, 18:30:27 »
ISO Enter on your prototype is tilted. You need to place the switch in normal position - most of MX switches have stem tilt in south-north direction.
Offline Pontus
« Reply #88 on: Wed, 09 April 2025, 16:58:11 »
Good catch! I originally went with this since it seemed like cherry did either rotation for their own boards. For the next revision it has been rotated to accommodate more switches and keycaps. I will share updated images & renders of the pcb soon to show off everything that has been adjusted!  ;D
Offline Mikhail
« Reply #89 on: Wed, 09 April 2025, 18:03:08 »
Yea, Cherry had both variants, but seems tilt on usual direction will fixed with stab.
Offline deductivemonkee
  • Professional Lurker
« Reply #90 on: Wed, 09 April 2025, 18:15:01 »
Is it too late to pray for a HHKB top offering? I wouldn't need to consider anything other than colour before ordering if that were the case..
Sent from my SM-S911W using Tapatalk
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
Offline Pontus
« Reply #91 on: Wed, 23 April 2025, 15:09:03 »
Hello everyone! Time for a small little update. This weekend Jae from prototypist built the blue 21xx prototype on stream, sorry for not announcing it here but thanks to everyone who still managed to drop by!
The VOD is available on youtube https://youtu.be/dxx7H0_lX9M
This prototype isn't fully representative for the final version since there have been some changes after this unit was made as specified in my previous update. If you just want to see the general experience of the board I highly recommend checking it out though!
The prototype with the finalized design will soon be finished. Hoping to be able to get it shipped around for some streams and photo sessions. Hopefully I will be able to give a bit more of a heads up for those streams, stay tuned! :D
There hasn't been any interest shown in HHKB tops before and there are no plans to offer it in the group buy. Sorry for not being to accommodate it this time!
« Last Edit: Wed, 23 April 2025, 17:41:26 by Pontus »
Offline Metakeebs
    • metakeebs
« Reply #92 on: Tue, 06 May 2025, 02:22:49 »
Would you consider adding the EC Internal option in the future? They seem to be really suitable for EC
Offline Pontus
« Reply #93 on: Tue, 06 May 2025, 03:29:30 »
I have considered EC but decided against it. With the board being themed around cherry keyboards and with it being designed to be used plateless I felt that EC (& alps for those who’ve been asking for that) would force it too far away from my original vision.
Offline FoxandFoundry
« Reply #94 on: Tue, 06 May 2025, 17:08:45 »
Looks amazing. Any chance on doing adding hotswap support?
Offline Pontus
« Reply #95 on: Thu, 08 May 2025, 16:02:47 »
I am happy to be able to show some picture of the latest prototype featuring the final colour for the warm gray ano! Let me know what you guys think  :cool:
Warm Gray Pictures
No hotswap for this board. Same reasoning as the previous answer for EC & Topre, the plateless nature wouldn't play well with hotswap.
Offline EdgeOfInfinity
« Reply #96 on: Thu, 08 May 2025, 17:31:05 »
beautiful pics!
Offline Pontus
« Reply #97 on: Tue, 13 May 2025, 18:31:45 »
GB POST IS LIVE
thanks for the continued support!
