Author Topic: [IC] Shark67 - entry level board starting at ~110USD - GB 6 Sep  (Read 8417 times)
Offline Sharke_Studio
« on: Mon, 21 August 2023, 07:54:59 »
Shark67
entry-level 65% keyboard with 2.4G/Bluetooth capabilities and excellent surface treatment.
DISCORD
GB DATE: 6 Sep
Price: ~ 110 USD
Hello everyone, this is Shark Studio.
Today, I bring you my first keyboard design – Shark65.
Shark65 is a budget-oriented keyboard, a perfect entry point into this exciting hobby.
It has a sleek, minimal style and fine, smooth surface treatment.
A picture speaks a thousand words – let me first show you some renders and photos of the board!
Electro-blue
Anode-grey
Coated-green
Electro-pink
Electro-lilac
Anode-violet
Coated-white
Key info
Layout
Exploded view
Layout: 65%, 67 keys
Mount: silicone gasket
Typing angle: 7°
Front height: 18.6mm
PCB: hotswap PCB with QMK/VIA support; supports wired / Bluetooth / 2.4G connection
The default PCB is with flex-cuts, but you can purchase an add-on no-flex PCB
Battery capacity: 2000mAH
Dimensions: 320mm(L) x 110mm(W) x 29mm(H)
Material:
Case: 6063 Aluminum
Plate: Polybarconate (standard) / FR4 (add-on) / Aluminum (add-on)
The default plate is PC no-flex; flex and no-flex version of all plates may be purchased as add-on
PCB: FR4
Weight: 1300g when assembled
Colours:
Anode: grey, purple
Powder spray: white, green
Electrophoresis: pink, blue, violet
Content of kit
Build video
Vendors:
US: ValaSupply
CA: AshKeebs
EU: KeyGem
UK: Prototypist
AU: Allcaps
SG: HexKeyboard
JP: BaseKeys
VN: ThekeebStore
Thank you and I hope to see you at the GB  ;)
« Last Edit: Sat, 26 August 2023, 08:43:32 by Sharke_Studio »
Offline kentdo10
Re: [IC] Shark67 - entry level board starting at ~110USD
« Reply #1 on: Mon, 21 August 2023, 08:08:32 »
GLWIC.
Offline Burt888
« Reply #2 on: Mon, 21 August 2023, 08:31:32 »
why all the flex cuts in the pcb and the plates?
No Split BS, no Stepped Caps Lock?
i know its entry level price but why butcher the plates and the pcb like this?
Offline PlayBox
« Reply #3 on: Mon, 21 August 2023, 13:47:59 »
glwic a bit too much flex cuts for my taste tho
Wysłane z mojego Redmi Note 8T przy użyciu Tapatalka
propably sent from my amazon kindle 10th gen
Offline aicyborg
« Reply #4 on: Mon, 21 August 2023, 19:55:27 »
Very disappointed at no ISO support and fixed plates.
Can't help but find it suspicious you've launched the IC with the GB commencing next week so we can probably presume anything we could give feedback on is already finalised.
Also, Neo65 offered more and cost less/the same.
Offline DirtyGingy
« Reply #5 on: Mon, 21 August 2023, 21:43:45 »
That plate and PCB is an instant turn off
« Reply #6 on: Tue, 22 August 2023, 07:26:51 »
Thank you everyone for your feedback.
After considering your feedback, we will implement the following changes:
  • The default plate will now be a no-flex Polycarbonate plate; both no-flex and flex-cut plates will be offered as add-on
  • No-flex PCB will also be offered as an add-on
We hope that we are able to respond to your feedback in a timely manner, and allay any concerns you may have.
Offline kiru
« Reply #7 on: Wed, 23 August 2023, 12:39:35 »
Please check discord DM
« Reply #8 on: Wed, 23 August 2023, 18:47:26 »
Did someone say shark?
Offline EdgeOfInfinity
« Reply #9 on: Thu, 24 August 2023, 00:39:56 »
y sharke if shark?
