Author Topic: Finger pain on some mechanical keyboards  (Read 5111 times)
Offline acidthrot
« on: Sun, 17 September 2023, 05:33:49 »
I have consistently throughout the years had finger pain from some mechanical keyboards, the only ones that haven't caused this pain would be corsair k63 or corsair k70 with mx speeds, not sure if its up to switches or the plate material. its not ergonomics because it is specifically finger pain and only brought on by some keyboards when i bottom out. for example im using a ducky one 2 mini right now with mx speeds and its causing a tingling/discomfort in my fingers when i game and type. but i also had a ducky one 2 with the same switches before and it didn't cause any problems? maybe its manufacturing tolerences. any help would be great
« Last Edit: Sun, 17 September 2023, 05:35:25 by acidthrot »
Offline Leslieann
Re: Finger pain on some mechanical keyboards
« Reply #1 on: Mon, 18 September 2023, 05:42:08 »
Keyboard angle, key height, desk height, chair height... All can be a problem.
Also, it could be you were slowly developing a problem before and it only became obvious recently.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
