Author Topic: Acorn Archimedes Keyboard Converter  (Read 19991 times)
Offline hasu
  • @tmk
« on: Mon, 30 October 2023, 22:41:01 »
This covnerter makes Acorn Archimedes keyboard usable on modern USB computer.
Check this for technical information and resources.
- https://github.com/tmk/tmk_keyboard/wiki/ACORN-ARCHIMEDES-Keyboard
Preassembled TMK converter is available here: https://geekhack.org/index.php?topic=72052.0
Firmware
Source code: https://github.com/tmk/tmk_keyboard/tree/master/converter/archimedes_usb
Tested by Archimedes A300 keyboad.
Keymap Editor
https://www.tmk-kbd.com/tmk_keyboard/editor/unimap/?archimedes_usb
Pinouts and Wirings
Mini-DIN-6P female socket from the front:
Code: [Select]
                    Connector                   AVR pin
      ,--_--.       1: Reset                    PD0
     / o6 5o \      2: NC
    | o4   3o |     3: GND                      GND
     - 2o o1 -      4: 5V                       VCC
      `-___-'       5: In(from keyboard)        PD1
                    6: Out(to keyboard)         PD3
Target microcontroller is Atmel ATMega32U2 by default but porting this project to other 8-bit AVR controllers would be easy.
Mouse support
Not tested with real mouse but it should work somehow.
I don't have Archimedes mouse to test, try and make a report if you have one.
Acknowledgement
Geekhack member Drag0nFly kindly sent the Archimedes keyboard to me spending much postage, this never happened without his generous offer. Thank you.
« Last Edit: Tue, 31 October 2023, 01:21:27 by hasu »
Offline hasu
  • @tmk
Re: Acorn Archimedes Keyboard Converter
« Reply #1 on: Tue, 23 December 2025, 21:26:50 »
[Firmware Update]
Today I found the fact that A300 keyboard(by Keytronic) has full N-key rollover feature and updated firmware to support NKRO on the Archimedes converter.
https://github.com/tmk/tmk_keyboard/commit/389b2d7ee890263a74962cb318f83150251bf91d
