Author Topic: [IC] Vantage by Zepsody - 60% | Leaf Spring | Molded Gaskets | Cem3 Pcb  (Read 16484 times)
Offline The Equals D
Vantage
By Zepsody
IC Form
Background
Vantage is a project that has seen many iterations over the past couple of years. Initially starting as a side project in 2021, I shifted my focus to Vantage last year in response to the changing keyboard market and increased demand for affordable keyboards. The goal with Vantage has always been to offer a high-end, low-gimmick keyboard at a reasonable price. The sound, feel, and quality had to be top-notch while having a premium and timeless design. Because of these high standards, this project took much longer than I expected. But, six prototypes and many thousands of dollars later, I am ready to show off the finished product.
Info
Colors - Lightning Purple, Red, Black, E-white
Layout - WKl, WK, or HHKB 60% (Considering fixed 7u, would love feedback on this)
Material - Anodized 6063 Aluminum (E-White will be E-coated), Stainless Steel Weight
Plate Options - Pom, Aluminum, Carbon Fiber, Aluminum Half Plate, Carbon Fiber Half Plate
Gaskets (Molded Wrap Around) - 80 Durometer, 70 Durometer, 50 Durometer,
Pcb - Cem3 H60 by Hineybush, Hotswap and Solder Available
Angle - 7.5 Degrees
Front Height ~ 18mm
Price - Estimated at $295
Kit Includes - Top Case, Bottom Case, Weight, Plate, H60 Cem3 Pcb, Set of Gaskets, PE Plate and Poron Case Foams,
Screws, Custom Molded Bumpons, Daughterboard (Modified UDB), DB Cable, Carrying Case
Bumpon Info - The bumpon color will be changed from transparent (as seen in the prototypes) to either white or black, depending on the case color.
Vendors
U.S. - Zepsody
OCE - ALLCAPS.store
International - TBD
E-White Prototype Photos
Sound Test By Alexotos
Sound Test By Captain Sterling
Lightning Purple Prototype Pictures
Black and Red Renders
Plate Options (Universal Plate May Be Offered)
Renders Showing Internals
Zepsody Discord
IC Form
« Last Edit: Thu, 16 November 2023, 09:44:31 by The Equals D »
Offline Abstand
Re: [IC] Vantage by Zepsody - 60% | Leaf Spring | Molded Gaskets | Cem3 Pcb
« Reply #1 on: Sat, 11 November 2023, 21:29:26 »
Looks awesome. Classic design at a decent price. Would love to see more colors (silver, perhaps?) but i'm definitely interested.
Offline HubertThemad
  • * St. Jude Supporter
« Reply #2 on: Sat, 11 November 2023, 21:46:39 »
Best of luck with this, Jason!
IC filled out, excited to see this come to fruition.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #3 on: Sun, 12 November 2023, 00:27:37 »
Looks great!! Nice lines, and really attractive board.
Offline mr_foggy
  • neue = nope
« Reply #4 on: Sun, 12 November 2023, 04:18:16 »
that lavender :O
« Reply #5 on: Mon, 13 November 2023, 13:27:20 »
Ty! While I would love to offer other colors, I think the 4 I have chosen will be the only I can offer. With the market being as it is, it is hard to predict the quantity that will sell, so I have to assume a low moq. This unfortunately means a lower number of color choices.
I appreciate the kind words Lightning! Hopefully I will be able to send a prototype your way so you can check it out
that lavender :O
It's nice right? I am really happy with how it turned out
Also, the build stream time has been announced
Alexotos will be building a vantage prototype tonight at 7pm est
Offline xhxzzh
« Reply #6 on: Mon, 13 November 2023, 21:37:40 »
Why no HHKB layout?
« Reply #7 on: Mon, 13 November 2023, 21:59:46 »
Why no HHKB layout?
I was not sure if it would be doable without a cost increase, so I left it out of the plans.
I have received a lot of feedback from customers asking for a HHKB option. I am looking into whether or not it can be done without a price increase. Hopefully I will be able to offer it, but no promises for now.
Offline PrizeOcelot5911
« Reply #8 on: Tue, 14 November 2023, 03:06:03 »
I am very interested in dry purple, it is very calm and not that bright color, I am looking forward to it! :thumb:
Offline xhxzzh
« Reply #9 on: Tue, 14 November 2023, 16:45:42 »
HHKB should be just top case blocker difference, why it would increase the manufacture cost? Really like the design. If it have HHKB option I will definitely join the groupbuy.
Offline Kiririn
« Reply #10 on: Tue, 14 November 2023, 18:41:17 »
Loving the look and sound of the board after Alex built the proto. I do agree that a HHKB option should be considered and there shouldn't be much of an increase of manufacture cost if any as it's only the top case blocker that is different.
Offline kylekwong1
« Reply #11 on: Tue, 14 November 2023, 19:09:12 »
Kit Includes - Top Case, Bottom Case, Weight, H60 Cem3 Pcb, Set of Gaskets, PE Plate and Poron Case Foams,
Is plate included in the kit?
« Reply #12 on: Tue, 14 November 2023, 22:01:52 »
It Is Included
More options and things the manu has to make = higher cost. That being said, y'all are right that it should not change things much. I was just trying to make sure I could price under $300, so I did not include it. I also did not think so many people would be asking for it. I am talking to the manu and I will have an answer about HHKB within a day or two.
« Reply #13 on: Thu, 16 November 2023, 09:45:38 »
Update:
HHKB will be offered. The price will not change.
Offline vhaarr
« Reply #14 on: Fri, 17 November 2023, 02:57:46 »
christmas is saved :-D in 2024 I mean lol
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline fuster
« Reply #15 on: Fri, 24 November 2023, 14:07:39 »
Looks really good and sounds better.
Offline involuntarysoul
« Reply #16 on: Thu, 07 December 2023, 19:36:21 »
add beige color please
Offline clannadkhang
« Reply #17 on: Sat, 10 February 2024, 10:12:51 »
A silver or grey color would be amazing, maybe r2? ;D
Offline LiftOffToSpace
« Reply #18 on: Sat, 10 February 2024, 11:43:27 »
Love the lavender!! 🔥🔥🔥
