Author Topic: [GB] Long Boi - A 30inch or 7ft keyboard  (Read 97997 times)
Offline JackPikatea
« on: Mon, 20 November 2023, 15:17:37 »
Long Boi Group Buy
Background
Hello everyone! Jack from Pikatea here. It's a well known fact that bigger is better with most things in life. This keyboard comes in 2 variants, a 30 inch (762mm) or 7ft-2in (2184mm) size. The 7ft version can be converted to 44 inches (1117mm). It features 2 numpad positions with layout options that you'd expect from a mechanical keyboard plus a rotary encoder and a small macro cluster. Both versions are gasket mounted. The 30 inch version is made with 3mm stacked matte black acrylic. It hides fingerprints and sounds great! The 7ft versions is printed in matte black PLA. It takes a week of constant printing!
Group Buy Info
* Base Price: $135 USD (30 inch version) and $335 USD (7ft version)
* GB open: November 20th 2023
* GB closed: December 20th 2023
* Estimated Fulfillment: April 15th 2024
Specs
* QMK, VIA, and VIAL compatible
* Plate mounted rotary encoder
* RP2040 Controller
* Gasket Mounted
* 30 inches (762mm) or 7ft-2in (2184mm). The 7ft version can become 44 inches (1117mm) by removing the side bezels.
* 1.7kg (30inch version) and 2.7kg (7ft version)
Product Page
Discord Server
Instagram
Twitch
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
Re: [GB] Long Boi - A 30inch or 7ft keyboard
« Reply #1 on: Tue, 21 November 2023, 09:59:24 »
reserved
« Last Edit: Tue, 21 November 2023, 10:03:13 by twitchytheinsideman »
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #2 on: Tue, 21 November 2023, 12:45:19 »
GLWGB!
Got me the 30 incher since I am a weakling and can't handle 7 feet.
Offline hzh0525
« Reply #3 on: Tue, 21 November 2023, 15:28:59 »
OMG!Like a machete!
Offline SageCrowDesign
  • Vendor
    • Sage Crow Design Deskmats
« Reply #4 on: Wed, 22 November 2023, 09:46:15 »
Props for the innovative style! Definately something unique to show off!
Offline NumPadEnjoyer
« Reply #5 on: Tue, 28 November 2023, 00:59:30 »
Very cool have you considered making it longer?
Offline funkmon
« Reply #6 on: Tue, 28 November 2023, 11:04:48 »
Unironically this. It doesn't have enough keys. You omit either numbers or function keys and things like break.
There's space there. I would genuinely purchase this product for the lulz if it was even fully functional as a keyboard.
Offline nathanchere
« Reply #7 on: Tue, 28 November 2023, 14:45:58 »
Pretty much my thoughts too.
Offline JackPikatea
« Reply #8 on: Wed, 29 November 2023, 14:22:51 »
Offline JackPikatea
« Reply #9 on: Wed, 29 November 2023, 14:24:48 »
I'm not sure what you mean... It's a fully functional keyboard.
Offline Piperaceae
    • DCS SMRT R2 Links
« Reply #10 on: Wed, 29 November 2023, 14:45:47 »
I think they're complaining there's no function row. But like, put them on one of the number pads.
Offline gasp
  • Formerly 'boop' (NTBCW Booper)
    • none
« Reply #11 on: Fri, 01 December 2023, 10:03:13 »
I’ll take 2
Offline nathanchere
« Reply #12 on: Wed, 13 December 2023, 17:17:32 »
Or a normal number row.
I'm also thinking not just missing Fx and number rows, I'm thinking using a mouse with this would probably be pretty uncomfortable.
