Author Topic: 75% hidden gem?  (Read 4435 times)
Offline jackcalico
75% hidden gem?
« on: Wed, 06 December 2023, 01:52:53 »
What's the cheapest aluminum case, 75%, south-facing, hot-swappable, 2.4GHz, PCB-mounted stabs kit/prebuilt keyboard?
Offline Leslieann
Re: 75% hidden gem?
« Reply #1 on: Wed, 06 December 2023, 04:32:24 »
Aluminum case and wireless do not work well together (metal blocks wireless).
PCB stabs and pre-built is uncommon.
75% is one of the least popular layouts.
And you want it cheap...
You're looking for a unicorn.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline jackcalico
Re: 75% hidden gem?
« Reply #2 on: Wed, 06 December 2023, 05:59:51 »
Yes, sir! I am really curious to see if there are cheap options out there or the QK75 is the only go-to.
Offline expletive
    • ExpletiveGG TTV
Re: 75% hidden gem?
« Reply #3 on: Wed, 06 December 2023, 19:43:57 »
im pretty sure the neo80 is in the works. if you can do without the function keys the neo70 is good to go for order. just grabbed one myself. insanely affordable and well built. solid pick imo. good luck!
https://qwertykeys.notion.site/Projects-40dc00bf807d49ed967d49b3ee7e834c (project update page)
https://www.qwertykeys.com/ (main)
Offline Exquite
  • GeekAnubis
Re: 75% hidden gem?
« Reply #4 on: Thu, 07 December 2023, 08:25:13 »
Mongeeks m1 once had a sale in taobao that was only about $40 for full keyboard with cream blue pro switches.
I'm a Color lover and a designer.
Offline jackcalico
Re: 75% hidden gem?
« Reply #5 on: Thu, 07 December 2023, 08:33:56 »
I don't think it is wireless, is it?
Offline Exquite
  • GeekAnubis
Re: 75% hidden gem?
« Reply #6 on: Thu, 07 December 2023, 23:25:28 »
It is wireless. My bad, it is M1w.
Offline jackcalico
Re: 75% hidden gem?
« Reply #7 on: Fri, 08 December 2023, 07:37:01 »
Still not it, the I am looking for PCB-mounted stabs, and looks like the M1W uses plate-mounted unfortunately.
