Author Topic: [IC]Update on the DR-70F Keyboard  (Read 13090 times)
Offline DaringRun
    • DaringRun
« on: Fri, 22 December 2023, 03:19:55 »
Hello everyone, this is DaringRun!
Long time no see. This time, we want to show you an update on the DR-70F.
Previous IC post:https://geekhack.org/index.php?topic=121073.msg3168859#msg3168859
The following is the updated content:
一.Specification
Typing angle: 7°
Material: 6063alu
Price:Wired$139,Bluetooth $159
Split main area,arrow area,function area
Layout:70%+5%, arrow area and function area can be rotated and switched,one keyboard two layouts
Structure:PCB gasket mount,Sandwich mount
Gasket mount plate: 1.5mm,PC,three split parts.
Sandwich mount plate:1.5mm Alu,anodised gold
PCB: 1.6mm, bluetooth pcb include 6400mah battery.
Polling rate:1000hz in wired mode,800hz in bluetooth mode.
Bluetooth PCB Latency Rate:1.25ms
Instock date: Quantity limited, Estimate on Jan 2024. No quantity limited at Group buy sale
二.Size/Layout/Exploded-view drawing
Programming Support: Wired in VIAL, Bluetooth pcb in LDN.
PCB Gasket mount plate&Sandwich mount plate
三.Package include
1*Top case
1*Bottom case
1*Middle frame
1*Weight
1*Pc led strip
1*Mirror piece
1*PCB
2*Type-c daughterboard
1* Pc plate for gasket mount
1*Foam kit
1*Accessories bag
1*User guide
四.Picture showing
There will be more real-life pictures and review videos next month, so stay tuned!
Our Email:sales01@dr.works
Our Website:https://d-r.works/
Our Discord: https://discord.gg/VEWAzhW2Z7
« Last Edit: Fri, 22 December 2023, 03:22:58 by DaringRun »
DaringRun Design Official Account
A sub-brand from Wind Studio.
https://linktr.ee/daringrun
Offline DirtyGingy
Re: [IC]Update on the DR-70F Keyboard
« Reply #1 on: Fri, 22 December 2023, 04:50:39 »
It's nearly 2024 and we're doing sandwich mount? Sign me up.
Offline lzlzh035
« Reply #2 on: Fri, 22 December 2023, 23:20:55 »
looks nice! sorry abit confused that the post says GB and in stock at the same time. so there will be limited in stock and a GB run, right?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #3 on: Sat, 23 December 2023, 05:17:51 »
I'm pretty sure that is the plan, some in stock inventory available right off the bat then a GB for those who missed out on that & still want in.
Offline sugarfreemedia
« Reply #4 on: Sat, 23 December 2023, 12:29:34 »
Please consider making an ortho option for the main pcb. E.g. Boardwalk layout
Offline DaringRun
    • DaringRun
« Reply #5 on: Sun, 24 December 2023, 23:43:40 »
''looks nice! sorry abit confused that the post says GB and in stock at the same time. so there will be limited in stock and a GB run, right?''
[/quote]
This means that it can be shipped as soon as the order is placed, and you don’t have to wait for several months to receive the keyboard.
« Last Edit: Sun, 24 December 2023, 23:47:24 by DaringRun »
Offline argentstonecutter
  • Greetings, programs!
« Reply #6 on: Mon, 01 January 2024, 14:33:29 »
Greetings, programs! How will I know when it's possible to order (or try ordering) online?
Edit: well, that was quick.
« Last Edit: Mon, 08 January 2024, 17:26:27 by argentstonecutter »
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #7 on: Fri, 05 January 2024, 09:48:19 »
How heavy is the unit unbuilt, and how heavy is the battery cover?
« Reply #8 on: Mon, 29 January 2024, 17:41:16 »
I didn't read closely enough, when I saw that I had missed the red wired version I pulled the trigger on the wireless, and now I see that it doesn't have VIAL. Is there going to be a firmware update for that? Does the alternative software support editing the layers independently?
Edit: I see that the LDN software is Windows-only. Is it possible to downgrade to the wired firmware to use VIAL? Or buy the Wired hotswap PCB and install it?
« Last Edit: Mon, 29 January 2024, 19:04:23 by argentstonecutter »
Offline tuxkey
« Reply #9 on: Sat, 24 August 2024, 17:23:26 »
hope one day we will see a R2 of this project with EU vendors.. Nice board !!!!!!!!!
