Author Topic: [IC] Geim65 - Circle - Triangle - Square  (Read 14956 times)
Offline kahlilnc
    • KNC Keys LLC
« on: Sat, 06 January 2024, 12:19:34 »
The Geim65 is our premiere Keyboard, complementing our Jacket line of switches.
We made a bunch of switches we are really proud of, inspired by the Squid Games series and now we are wanting to try and make a unique keyboard. We wanted something that was easy to build, had an interesting style, and unique mounting methods that were bouncy and sounds amazing. After working to refine a design for months we have some prototypes that we are happy with and now we are going to run an in-stock sale.
We’ve implemented the following QOL features: force-break gaskets, a ball latch for ease of use,
a unique waffle weight for improved acoustics, three mounting methods, and our proprietary bowl-like isolation gasket for a modified bottom/pin mount experience and additional force breaking.
The Geim65 is a tri-mount leaf-spring 65% keyboard you won't want to miss!
IC Form can be found here
There will be 50 units in stock that should be available between March and May 2024.
If we get enough interest, we would love to do a larger run to help cut costs. We would love to aim for the $200-$300 range.
Check out our photo dump: https://imgur.com/a/WfDIGed
Real photos will be added shortly, as we have a green and red sample in hand.
Tentative Pricing: ~$400 per kit
Geim65 Keyboard Features:
* Layout: 65%
* Mounting Styles:
- Gasket - Silicone Socks
- Pin/Bottom - Utilizing a proprietary bowl-like isolation gasket reduces reverberation and provides a unique experience.
- O-Ring
* Case Options:
- Case: Aluminum
- Black - Anodized
- Dark Red - Anodized
- Dark Green - Anodized
* PCB: Hotswap, 1.6mm, Non-Flex-cut, USB-C S1 Unified Daughterboard
* Plate Options:
- Non-Leaf Spring Polypropylene
- Leaf Spring Aluminum
- Leaf Spring Carbon Fiber
- FR-4 Half Plate
* Inside Weight Options:
- Brass - Sandblasted
* Outside Accent/Weight Options:
- Stainless Steel (304) - Mirror Polish
* QMK Firmware and VIA Support
* 19.8mm Front Height
* 6.8° Typing Angle
* Dimensions: TBD
* Manufacturer: Sinorise
Top mount has been removed due to it not being compatible with the ball latch system.
More photos and the latest updates are available on our Discord server.
Hotswap PCB Layout:
Solder PCB Layout:
Kits Include:
* Aluminum Top and Bottom Case
* Solder or Hotswap PCB
* 1 USB-C S1 Unified Daughterboard
* 1 Internal Brass Weight
* Set of Ball Latches Pre-Installed
* 1 of each External Accent/Weight
* 1 Set of Silicone Top-Mount Bowls
* 3 Additional Silicone Bowls for Force Breaking
* 4 Force Break Pads (PORON)
* 1 Set of Silicone Socks
* 1 Set of Feet
* Optional Choice of O-Ring (3 Sizes)
Please check our website for all the available options: https://knckeys.com/products/knc-keys-geim65-keyboard
EDIT: We are waiting on the fourth sample unit (the third from Sinorise). I want to experiment with how having 8 total gasket tabs would compare to how it is now, increase some of the tolerances in the gasket areas, and add additional forcebreaks between the case and weight/accent pieces.
« Last Edit: Thu, 21 March 2024, 10:24:35 by kahlilnc »
Offline NiceJim
Re: [IC] Geim65 - Circle - Triangle - Square
« Reply #1 on: Sat, 06 January 2024, 12:25:20 »
Return of the king -- I'm definitely getting this as soon as it launches. Good stuff.
Offline bizzlesticks
« Reply #2 on: Sat, 06 January 2024, 13:02:40 »
Huh, I think this is the first time I've seen a board with ball-latch and a cherry lip. What's the front height?
Offline kahlilnc
    • KNC Keys LLC
« Reply #3 on: Sat, 06 January 2024, 14:07:23 »
Hey, it has a 19.8mm front height. Had to increase the front height to adjust for it.
Thanks my man!
Offline aicyborg
« Reply #4 on: Sun, 07 January 2024, 19:48:26 »
yoooooo squid game keyboard
in
Offline VXQN
« Reply #5 on: Tue, 09 January 2024, 03:41:40 »
Any chance we can see some shots from less oblique angles?
Offline kahlilnc
    • KNC Keys LLC
« Reply #6 on: Tue, 09 January 2024, 07:22:43 »
Yeah can do. Will be sending my latest prototype unit to a content creator shortly.
in
:D Heck yeah!
Offline PPmonster
« Reply #7 on: Wed, 10 January 2024, 12:41:40 »
I HERE!!! WHEN GB????
Offline kahlilnc
    • KNC Keys LLC
« Reply #8 on: Thu, 11 January 2024, 13:22:39 »
No GB, unless we do a second run. There will be a small in-stock drop within the next couple of months. If the IC does well and if all recipients show that they love the project we will conduct a larger GB at a lower cost and much higher MOQ.
Offline involuntarysoul
« Reply #9 on: Fri, 12 January 2024, 04:25:31 »
not feeling the Korean letters on the bottom
Offline eufiewufie
« Reply #10 on: Mon, 15 January 2024, 20:17:13 »
will 1000% be in if there is a gb with lower price, love this. might cave and get in on the limited drop too :P
Offline kahlilnc
    • KNC Keys LLC
« Reply #11 on: Thu, 18 January 2024, 10:49:41 »
That is the goal! If we get enough interest we are 100% willing to do another run at a higher MOQ. As of right now, I wanted to provide an in-stock drop of 50 units. :/
Offline scorcher36
« Reply #12 on: Wed, 20 March 2024, 06:47:23 »
Possible to add layout support to the IC unless it is not finalized. Interesting board, wouldn't mind picking this up.
Sent from my Pixel 8 Pro using Tapatalk
Offline kahlilnc
    • KNC Keys LLC
« Reply #13 on: Thu, 21 March 2024, 10:22:15 »
Thank you for your interest! The layouts have been added to the OP. I am currently waiting on a fourth sample unit from the manufacturer. If all goes well, I will proceed with the 50 in-stock units.
Offline enomooshiki
« Reply #14 on: Mon, 24 June 2024, 23:04:54 »
Why is it spelled, "Geim" instead of "Game"?
Offline kahlilnc
    • KNC Keys LLC
« Reply #15 on: Tue, 25 June 2024, 14:03:17 »
Hey!
The Korean word for "Game" is "게임," which is pronounced "geim" in English phonics.
Offline enomooshiki
« Reply #16 on: Tue, 25 June 2024, 14:34:36 »
That's weird
As a Korean, I know what "game" is. If you ask Koreans to spell 게임 in English, most people will say "g a m e" not "g e i m"
Actually, if you wanted to be phonetically correct, it should be with strong G , like 께임.
Offline Bennettb
« Reply #17 on: Wed, 26 June 2024, 16:35:58 »
Love it!! The internal weight design makes it so much cooler!
