Author Topic: ML4400 trackball - how smooth it is?  (Read 2730 times)
woody
  •  Guest
« on: Tue, 19 October 2010, 08:08:45 »
Well, got home yesterday with a used Cherry ML4400 in UK layout, black, USB. Thoroughly cleaned it and tested few hours later. The key are as expected - the low-profile ML. Still much better than regular rubber domes.
But the trackball sensation is not okay at all - it squeaks a bit, not smooth, and sometimes I can't roll it easily. The trackball module looks like off-the-shelf, connected by bunch of wires to the keyboard's own MCU board. It has three tiny white balls in vertical grooves to support the rotating ball, and two very low-fi mouse-like rollers. The PCB of the module is not fixed by a screw, held in position only by two stems and wiggles a lot, but the top keyboard frame and the ball restrictor hide that.
The question is, how could I improve the trackball? And how good is it when stock new?
Offline NewbieOneKenobi
« Reply #1 on: Tue, 19 October 2010, 08:11:13 »
Is there absolutely no component anywhere that could use cleaning?
woody
  •  Guest
« Reply #2 on: Tue, 19 October 2010, 08:18:40 »
No, them rollers were cleaned too. Rotate easy enough by finger. They were not even dirty. The PCB and the case had a good amount of dust, but nothing more.
On the other hand, if the dust was industrial and fine enough ... dunno.
________
design host
« Last Edit: Sat, 05 February 2011, 13:54:24 by woody »
Offline itlnstln
« Reply #3 on: Tue, 19 October 2010, 08:24:05 »
I'm not too familiar with this trackball, but might there be some bearings that could be worn?
woody
  •  Guest
« Reply #4 on: Tue, 19 October 2010, 08:26:49 »
Three white balls in plastic vertical grooves serve as bearings. No visible signs of wearing. I'm puzzled, that's why this thread.
________
marijuana seed
« Last Edit: Sat, 05 February 2011, 13:55:59 by woody »
Offline itlnstln
« Reply #5 on: Tue, 19 October 2010, 08:33:30 »
If that's the case, I bet it was pretty crappy from the onset.  IIRC, the trackballs used in the MX11800s were made by Logitech and were OK (not great).  I wonder if they tried to do something in-house with this one.
woody
  •  Guest
« Reply #6 on: Tue, 19 October 2010, 09:01:07 »
Looks like off-the-shelf module. When I disassemble it again, I'll take notion of the trackball board.
________
volcano digital
« Last Edit: Sat, 05 February 2011, 13:56:50 by woody »
