Author Topic: [IC] GMK Dandy R2  (Read 33041 times)
Offline busytimmy
Re: [IC] GMK Dandy R2
« Reply #50 on: Mon, 25 March 2024, 21:48:23 »
Looking good Mr Sour. GL with GB  :thumb:
Offline ClingyMonkee
« Reply #51 on: Tue, 26 March 2024, 11:20:20 »
So... GMK Dandy without the Dandy base? Makes no sense...
Offline sourmk
« Reply #52 on: Thu, 04 April 2024, 16:04:11 »
Heyo! OP has been updated with base and supporting kit renders, we go on Monday!
Thank you! <3
Some Work: GMK Wasabi | GMK Pono | GMK Dandy | ePBT DuO | GMK Hooty | Petals Sixty
Some Collabs: ePBT Ivory | GMK Deep Navy | GMK Fundamentals | GMK Polybius | GMK Blurple | GMK Deepwell | GMK Fuji | GMK Pacific
Some Boards: Daji Seis Cinco, Ocho Quattro, Seis Cero | MatrixLab 2.0 ADD + CP, 2.0 Xmas + CP, 1.2OG | Keycult 1/60 | Hiney Ladybird | QXP | Noxary 268.2
Discord - https://discord.gg/j3PxfJ4rBC | Instagram - https://instagram.com/sourmk | Web - https://www.sourmk.com/
Offline busytimmy
« Reply #53 on: Thu, 04 April 2024, 17:13:02 »
Awesome  :thumb: GL with GB Sour
Offline Keeaboo
« Reply #54 on: Tue, 09 April 2024, 07:18:36 »
Love the R5 and I think going green base only was the right move. GL!
Offline bananafish
  • Je vis. I lube switches with silicone grease.
    • bananafish
« Reply #55 on: Wed, 17 April 2024, 05:24:44 »
Has it gone live?
Offline Mike2046
« Reply #56 on: Sat, 20 April 2024, 19:13:07 »
R1 had yellow accents. Will there be any kit with yellow accents this time?
Offline sourmk
« Reply #57 on: Thu, 25 April 2024, 22:58:28 »
Had been keeping my discord and insta updated, gb will go live friday may 3rd cheers <3
Offline AMZ
« Reply #58 on: Mon, 29 April 2024, 14:13:14 »
Lets goooo
Offline sourmk
« Reply #59 on: Sat, 04 May 2024, 14:53:15 »
quite a few vendors are live already, gb post is pending approval
till then if you'd like to join, links are on my site
Dandy R2
Cheers! <3
