Author Topic: New species: Cherry MX light blue  (Read 1893 times)
Offline sixty
    • http://deskthority.net
« on: Wed, 20 October 2010, 13:04:54 »
Just when you thought we at least had Cherry figured out and only ALPS were the evil guys, I come around with this!
I found this in the Spacebar on the Talent keyboard I found today.
Sun is gone, so I had to use flash and the pics are bad. But you can see the spacebar has a MX blue of a slightly lighter color. This is harder to see in the pics but actually very obvious in real life.
Before someone blames it on someone throwing something into the dye pot at Cherry in the 80s, nope. Different spring too:
I am assuming this is what they used in their very early days before they came up with Cherry MX greens for their spacebars.
Anyway, there you have it. One more to add to the switch pool. Measures 65g.
Offline didjamatic
« Reply #1 on: Wed, 20 October 2010, 13:20:47 »
Wow, totally different springy.  Even my Dolch Pac-60 boards have Green spacebar switches.  I'll have to check a couple of older ones i have to see.  Since I rarely pull spacebars, I don't know what any have.  I know some have the same blue switch as the others.
Offline elbowglue
« Reply #2 on: Wed, 20 October 2010, 15:30:35 »
That could be a cherry green spring.  Cherry green stem is the same shape as a cherry blue stem, just varies by spring.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
