Author Topic: [IC] AZ ISOK & DCS AZ ROUGE ALERTE  (Read 6783 times)
Offline azhdar
  • Praise the AZERTY god
« on: Mon, 01 April 2024, 02:01:13 »
This project is a keyboard and a keyset combination.
The main goal is accomodate most people no matter which layout they are using.
For this, we had to make compromises.
IC FORM
We are very interested in your feedback, so please fill out the IC below
IC FORM
AZ ISOK keyboard
KEYBOARD RENDERS
DETAILS
Metric system can be confusing.
We created our own measurment system :
  • the angle will be based on the Leaning Tower of Pisa (LTP)
  • the other measurements will be based on nostril gap (NG)
SPECIFICATIONS
  • Case Angle: 1 LTP
  • Front height: 3 NG
  • Materials: alu 6063 + brass weight
  • Mounting method: top mount
  • PCB: QMK/VIA Compatible with USB-C daughterboard
  • Connectivity: Easy as (USB type) A B C
PRICE
TBD some under review
over 900€ * / 770 £ / 146072¥ / JMD 151870$
ETA
Just letting you know that this keyboard will ship on 8th of october 2025.
I'm going to be real with you, this GB will take ages to fulfill , but I will make you feel like kings. I can add features and **** for free basically, let's make this the best 60% possible!
DCS ROUGE ALERTE
We never really cared for DCS, we still don't. But seeing that they might be going away, we can't miss this opportunity to produce a keyset we will be able to flip cherish.
As mentionned above, we want this keyset to accomodate most layouts, we made sure to create a real international kit this time around.
We know that "MOQ going to be really hard to reach with a uncommon layout just pointing out" , we dont want to leave any weird and inferior layout behind. This is why we designed a ROW (Rest Of the World) layout.
SPECIFICATIONS
Manufacturer: SP
Material: Doubleshot ABS
Profile: DCS
KITTING
BASE :
INTL:
ROW ( Rest Of the World)
For this kit, we have a MOQ of 20 units, we had few people asking for it, we're not confident we can ever reach MOQ on this one, we'll drop it if we must.
COLLABS
Our friends from "French Touche" designed a cased that snuggly fits a 60% and also stands out from your dozen of black cases.
FAQ
  • Why no ANSI support on plate ?
ANSI compatibility has been removed from the 60 plate because nobody only one country uses that **** anyway and mounting points have been moved around for better flexibility.
  • What's up with the 3 usb ports on this keyboard ?
Our pcb designer loves making usb hub.
  • Why so many R on the AltGr ?
Because he's very angry
  • What layout does the INTL kit covers ?
Both the Flanders and Wallonia layouts
  • What's up with the screws ?
Some got in the way of the spacebar, so we moved them around a bit.
And yes some are missing on the renders, this is part of our patent-pending proprietary acoustic technology, more on that later.
« Last Edit: Sun, 07 April 2024, 05:56:01 by azhdar »
Azerty Propagandiste
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
Re: [IC] AZ ISOK & DCS AZ ROUGE ALERTE
« Reply #1 on: Mon, 01 April 2024, 02:12:02 »
Was hoping it would come with an ethernet port.
Thoroughly disappointed. 4/20
Offline mr_foggy
  • neue = nope
« Reply #2 on: Mon, 01 April 2024, 02:46:46 »
clearly inferior, 3/10
Offline ramnes
  • T fou, mec?
« Reply #3 on: Mon, 01 April 2024, 03:28:52 »
Alt Grrrrrrr
Offline louckousse
« Reply #4 on: Mon, 01 April 2024, 03:57:39 »
I almost added it to the pcb but at the wireless era it doesn't seem as vital to have an ethernet port that a clearly superior USB-B.
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
« Reply #5 on: Mon, 01 April 2024, 04:19:27 »
GB should be longer for a true GB experience, 5/10
French keyboard streamer
Offline SilfurSol
« Reply #6 on: Mon, 01 April 2024, 04:30:03 »
BAE but no Alps kit, sadge, nice kitting otherwise, 6/9
Offline JQ27
« Reply #7 on: Mon, 01 April 2024, 05:08:31 »
giggle cw60/10
Offline vhaarr
« Reply #8 on: Mon, 01 April 2024, 05:52:35 »
I mean this really should include a tented alice and a separate numpad to be considered a real "combo" in 2024.
Also which switches will you bundle with this that I've never heard of before?
Let the Holy Handgrenades rain.
Hammering on an old Happy Hacking Pro 2. Still going strong!
Offline fops
« Reply #9 on: Mon, 01 April 2024, 09:12:43 »
hello can you do text modifiers for shif t  :thumb:
Offline welmerer
« Reply #10 on: Mon, 01 April 2024, 10:12:00 »
c'est vraiment un clavier de ouf. j'espère que Blacksimon pense la même chose  :thumb: ;D
Offline mk
« Reply #11 on: Mon, 01 April 2024, 10:34:55 »
Is the case angle the 1990 tilt or post-stabilization 2001 tilt? If the tower starts to tilt more again, will a new case be reissued free of charge?
There is a tendency that human noses get larger by age (Measured by nasal breadth (NB) + other measurements. I assume that NB correlates with NG). Will the front height also grow slightly longer over the years?
 Hardly anyone uses F7. Can you remove this from the kitting for cost savings please?
Offline azhdar
« Reply #12 on: Mon, 01 April 2024, 11:17:43 »
Very sorry about it, the angle is based on the post-stabilization 2001 tilt, how else would you take picture of your ISOK next to the Tower ?
If the tower tilts again, we will be happy to issue a round2.
Oui.
We will consider putting it into the ROW kit.
Offline headshot
  • i love low effort projects!
« Reply #13 on: Mon, 01 April 2024, 12:31:06 »
numpad when
Offline _rubik
« Reply #14 on: Mon, 01 April 2024, 16:00:28 »
Could we get your nostril measurements in both imperial and metric system?
