Author Topic: Ryzen 7900x... Idle at 85 Degrees?  (Read 5317 times)
Offline Naweo
« on: Sun, 07 April 2024, 05:40:07 »
Hey there
I am runing an aircooled (be quiet double tower air cooling) with arctic silver 5 thermal paste, on a less than 2 year old PC build, windows 11. PC is effectively clean of dust.
My PC in a relatively idle state, utilizing 10-20% of CPU usage, just having tabs open, has high temps.
I tried to monitor on hardwaremonitor and HWinfo.
In both cases, it seems my PC is running incredibly hot for no apparent reason. I tried to re-apply thermal paste and I usually do this without issues. Before and after thermal paste application, temps are still unsually high.
The CPU is default settings, no overclock.
I am particularly concerned with the package temp and the CCD temp. The computers max temperature readings was without any stress tests on the CPU, literally just opening tabs, surfing internet, etc.
https://gyazo.com/771cc0c8dbbbd21cde802d58fe2cb2a1
https://gyazo.com/8a80daeef42ee3792261779ca4a20911
https://gyazo.com/b21851056ef6409dbc05f489baed2e73
https://gyazo.com/4cf7d6088031dd18ccbe1281d63f19e1
Any other info I need to provide? Do I need to get a new CPU or even see if I can get it exchanged?
« Last Edit: Sun, 07 April 2024, 05:51:47 by Naweo »
Offline Leslieann
Re: Ryzen 7900x... Idle at 85 Degrees?
« Reply #1 on: Sun, 07 April 2024, 21:52:30 »
Newer cpus are set to just run all out until near max temp.
If this is new-ish behavior though for yours it could be a bad update or driver.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
