Author Topic: Cherry switch bridges  (Read 1564 times)
Offline Parak
« on: Sat, 23 October 2010, 02:58:09 »
Silly question, but I cannot brain tonight:
So suppose that hypothetically I were to do a diode addition to cherry switches with bridges in them on a custom pcb - would I be correct in assuming that said bridge would no longer be needed and I could remove it from inside the switch?
« Last Edit: Sat, 23 October 2010, 03:32:34 by Parak »
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Sat, 23 October 2010, 06:24:49 »
Yup. You might find 'em handy while routing the board though. Of course if you open up the switches anyway, you could just install a bunch of diodes instead.
Offline Parak
« Reply #2 on: Sat, 23 October 2010, 09:25:32 »
Quote from: keyb_gr;237590
Thanks! I'm planning on doing the the switches and diodes on different layers, which helps with the routing better anyway than having them on the same layer, methinks.
Quote from: ripster;237606
Just to be clear this will NOT give you NKRO without controller changes.
Someone here tried that without checking in first with us.  Lol.
Offline keyb_gr
  • Cherrified user
« Reply #3 on: Sat, 23 October 2010, 19:11:26 »
Quote from: Parak;237624
Yup. Make sure you leave plenty of groundplane though, no need to provoke RFI issues.
Offline ironman31
« Reply #4 on: Tue, 26 October 2010, 22:42:21 »
Well I didn't put diodes in, I just put switches with diodes in another keyboard. Wasn't shooting for NKRO or anything like that.
Btw, I ended up fixing all the problems I had with the traces separating from the board, and I put a jumper on all the switches, so now everything works fine.
Keyboards:
IBM Model M Space Saving Keyboard (Used), HHKB Pro 2 (White, Lettered), Realforce 87U all-45g in White, Filco Majestouch 2 TKL with Cherry MX Browns, Model F PC/AT,  Noppoo Choc Mini (MX Browns), Model F XT, IBM Model M 1397735 (bought NIB), (2) Siig Minitouch (GHSS) one with XM, one with complicated ALPs (modded),2 Dell AT101W, Cherry G80-11900HRMUS (modded with MX browns)
Pointing Devices:
