Author Topic: [IC] iF Keyboard Kit by Castle Bravo Studio  (Read 6612 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Sun, 23 June 2024, 10:20:56 »
iF
Post edited by Click Clack
Index
- Inspiration
- Modules
- Structure
- Colorways
- Specifications
- Pricing and Vendors
Inspiration
Hello, everyone. This is ClickClack. We're introducing a new project named iF, which we started following 2.5 years ago. At the inception of the iF design, Castle Bravo Studio prioritized practicality and user experience. Considering the varying key requirements for different software and games, this setup can be effectively utilized across numerous fields.
Modules
Toggle Switch
Simplified Operation: The toggle switch significantly simplifies operations, allowing quick left-right toggling with a single finger for tasks such as switching songs, browsing photos, and navigating slideshows. This is more convenient compared to using the arrow keys on a keyboard.
Customizable Functions: The switch can be customized for various functions, providing convenient operation for more application scenarios, such as binding keys for specific applications for quick actions.
Superior Tactile Feedback: Compared to touch screen interactions, the physical buttons offer irreplaceable tactile feedback, making blind operation more convenient to let the user focus more on their screen.
Knob
Linear Encoder: The knob uses a damped encoder, offering strong directional feedback suitable for various user scenarios.
Customizable Functions: By default, it adjusts the volume. However, users can utilize VIA to customize different inputs. The knob works perfectly with the encoder, achieving secure locking without screws.
NFC Integration: Supports NFC scanning to activate iOS shortcuts and other functions. Users can scan the keyboard's NFC tag with their phone to set corresponding actions through shortcuts, enabling interactions with smart home devices and quick operations. Future developments may unlock additional interesting functionalities.
Quick Action
All-New Quick-Action: Multifunctional button for customizable shortcuts with a quick touch.
Fingerprint Module
Fingerprint Module: Supports Windows Hello for fast computer unlocking. Setup is simple and quick, with Windows Hello native support and payment-grade security.
Wireless: Bluetooth 5.0 supported.
Structure
This design has matured with the development of gasket structures in recent years. It isolates the inner frame from the case, reducing unwanted rebound and noise caused by resonance.
Exploded View
Colorways
Anodized Purple:
Anodized Silver:
Anodized Navi Blue:
Anodized Black:
Anodized Wine Red:
Coating White&Black:
More Photos:
Specifications
Layout: 75%
Material: Aluminum
Plate: FR4(Flex-cut), POM(Non-flex Cut), Aluminum(Flex-cut)
Connection: Wired, Bluetooth
Driver: Supporting VIA
Battery: 1200mAh
PCB: 1.6mm Uncut Hotswap (Indicator Lights included on PCB and DB)
Typing Angle: 7°, Front height 20mm
Surface Treatment: Anodized/Coating
Weight: ~1.3kg
Layout
What's Included?
Case
Multimedia modules (including NFC chip)
Hotswap PCB
DB
FPC Cable
Foam set(Poron foam, PE foam)
Gaskets set
Plate
Battery
Bumpons
Excludes: switches, keycaps, stabilizers.
Pricing and Vendors
Estimated Price: TBD
Join ClickClack's Discord for latest update, discussion, questions:
Fill in Interest Check Form:
Follow ClickClack's IG for other new projects:
« Last Edit: Fri, 05 July 2024, 15:06:02 by ClickClack.io »
Offline xLeHoy
  • weeb board enjoyer
Re: [IC] iF keyboard Kit by Castle Bravo Studio
« Reply #1 on: Sun, 23 June 2024, 11:23:50 »
I know at least one guy who will get this just because of the fingerprint sensor
Offline Randomlosername
  • Gacha Done Got Me
    • IG
Re: [IC] iF Keyboard Kit by Castle Bravo Studio
« Reply #2 on: Tue, 02 July 2024, 13:47:35 »
Tbh I love this. Windows & IOS Integration on a Keeb? Yes pls. Also 75's rule lol. I hope we keep seeing more from this project.
Offline njcxqqy
  • Less is a bore
« Reply #3 on: Sat, 06 July 2024, 00:18:35 »
Thank you and we have updated some prototype pictures
Offline Bennettb
« Reply #4 on: Sat, 06 July 2024, 12:10:27 »
This is lowkey kinda cool! The finger print sensor + knobs = ;D
