Author Topic: [IC] Cerberus FRL TKL Keyboard - With Glowing Eyes!  (Read 22804 times)
Offline upas
« on: Wed, 10 July 2024, 14:37:28 »
The Cerberus FRL TKL Keyboard
Hey everyone,
I’m writing this to introduce everyone to a new keyboard project I’ve been working on that I’ve named “Cerberus”. It’s a FRL TKL that uses single-sided gasket mounting.
I have a bunch of details on the design itself below, but if you’re ready to just fill out an IC form, it’s available HERE. I need your feedback!
The inspiration for this board came from a desire to highlight a mounting style that ai03 used on the Brutal v2 series, but hasn’t shown up in many other places - and also to make a “sequel” board to the two-side gasket / sandwich mounted Chimera65.
The Mounting Style
The Cerberus keyboard and Brutal v2 both use a single-sided gasket mounting structure, where only the bottom case has gaskets. The goal of this structure is to better mimic the sound of top mount keyboards, while also adding some of the benefits of gaskets.
In top mount keyboards, the plate is screwed into the top part of the keyboard, making plate-to-top contact, and does not touch the bottom part of the keyboard. On Cerberus, this plate-to-top contact is present due to the gaskets only existing under the plate, and the top case being designed to touch the top plate.
And by virtue of having gaskets under the plate, there is some bounce present when typing on the board, more similar to a Bakeneko or other gasket mounted board. This provides acoustic isolation between the plate and bottom case - eliminating a confounding factor in trying to achieve that top mount style sound.
The end result is a board that sounds as good as and also feels less stiff than a traditional top mount board (though, in my opinion, plate material will make the most difference in terms of perceived stiffness).
With that in mind - there are still some key differences in the mounting style of Cerberus and the Brutal v2 series. Primarily, the Cerberus covers far less surface area with gaskets than the Brutal v2 did. This results in more bounce, as there are fewer contact points where gaskets need to compress. But I believe the resulting sound is more similar to top mount - on usual top mount boards, the plate to top contact zones are not that large.
The Theme
Since this board is meant to be a bit of a sequel to Chimera - I picked another mythological creature as its theme. I didn’t want to make another Chimera-style board - like a ChimeraTKL or a Chimera75 (though, if people want that, please let me know) - I wanted it to be something new.
Cerberus is a three headed dog from Greek mythology who guarded the gates of Hades. So with the theme of Cerberus, I tried to design around the concept of three. Cerberus has three heads, so the board has three main accent pieces. There are two colored side pieces, and a bottom crest all sharing an accent color - for three accent pieces total. And when looking at the bottom of the board, there are three “weights” visible (two brass, one accent piece).
Finally, there’s an engraving of a Cerberus head on the top of the board above the arrow cluster. One piece of feedback I heard about Chimera is that people wished the engraving on the back of the board was mimicked on the front. So I tried to do that here. In addition, the eyes glow with RGB LEDs mounted behind them.
Other Design Considerations
The side profile of the board was designed to be aesthetically pleasing, while still giving users an easy way to pick up the board. One of my personal pet peeves is when a board is hard to pick up - and I try to avoid that in my designs. Many of my previous boards have featured Koala-like curves to enable this, but this time around, I went with a curved back.
For this board, I decided to include wireless functionality. It’s likely not going to be wireless by default, but I wanted to ensure that people who want a wireless board would have an option here for it. The interior of the case has a cavity to hold a battery, and when I tested a ZMK PCB that I designed for Cerberus with an FR4 plate, the wireless worked well. When using the wireless PCB, the RGB LEDs shining through the Cerberus’s eyes also double as status indicators - which I think is a neat little touch.
To reduce the acoustic impact of including this battery cavity, I also included an inner brass weight. This weight spans across the alphas on the board - which has been perceived by hobbyists in the past to improve the sound of the alphas as well. Personally, I do think it makes an impact which I consider an improvement, but if others prefer the sound without the inner weight, that’s totally valid as well.
I also wanted the Cerberus to sit low on a desk. It’s not the lowest keyboard ever designed, but the front of the keyboard is less than 18mm tall (as it sits on a desk), and the case is ~20mm tall at the middle of the first row of keys.The case has a 6.5 degree typing angle, to make it comfortable for most people.
As a result of the design decision to make the keyboard sit low - including three external weights was non-trivial. Parts of the bottom case are entirely cut out to ensure the weights have space to mount. But the acoustic impacts of these cutouts are mitigated by the inner brass weight covering.
There are 4 POM alignment pins included in each unit to help ensure the plate stays centered. The current mounting style does compress the bottom gaskets (which are quite soft) a little, but does not provide nearly enough compression to lock the plate in place. I also don’t use screws to keep the plate in place as you would if you were making a top mount board - so I chose to use alignment pins. I drew inspiration from the Moment keyboard designed by jjw - this was also a single-sided gasket mounted board, with the key difference being that the top case did not touch the plate.
Finally - I wanted to design this board to be price accessible. One of the key reasons why I chose to use an inner weight and three external weights instead of relying on a through weight was to keep costs down. This is a bit counterintuitive - how can more parts be cheaper than one part? But the external weight and inner weight can all be machined from flat stock. Through weights typically have angled features, requiring extra machine time which drives up the cost of keyboards. The inner weight also solved other design problems as well, making the choice even easier.
Based on these efforts, we should be able to sell Cerberus at an MSRP starting under $300.
The Small Details
To provide even compression across the gaskets, and also keep the back curve present on the board, I had to use “internal” screws. There are four screws on the bottom of the board that are necessary to keep the top and bottom case parts together - but there are also 6 screws under the keycaps. The screws that we’ll include for Cerberus will be black screws - at least for these 6 spots - so that the chances of noticing the screws under your keycaps in day to day use is minimized.
And about the four screws on the bottom of the board - we’ve created molded rubber feet to cover where they sit. If you look at the bottom of the board once fully assembled, you won’t see screw holes. I may modify these to round out the edges to make them less noticeable.
Hearing feedback on prior projects about the big Cannon logo being a polarizing feature - I’ve decided to move it to above the USB port for Cerberus. It’s much smaller than it was on a board like Chimera or Balance, and much easier to ignore now if you aren’t a huge fan of it.
The side accent pieces have a small chamfer where they meet the top and bottom cases - which also share this small chamfer. This little design element helps further provide separation between the accent pieces and the top and bottom cases. The top and bottom cases are designed to look seamless.
And the USB port is centered on the back of the board, and features a little hood. This should cover most of the metal bits on most USB cables, so your board will look sleek when used.
I’ve also added little cutouts for force-break specific gaskets.The idea behind force breaking is to break the metal on metal contact of the top case with the bottom case. In my testing, I used soft poron for force breaking, which did make a small change in acoustics. I believe the board already sounds good without force breaking - but this is an extra way that people can tune their boards to match their preference.
I used the same cutouts and gaskets to also provide force-breaking between the plate and top case. Personally, I preferred the acoustics of the board without these installed. Installing them removes the plate-to-top contact which helps the board mimic top-mount acoustics. But they are also there for those who want to experiment and tune their board, or simply prefer a more isolated sound.
The Evolution of the Design
What you’re seeing now is not how Cerberus was initially envisioned - and I wanted to share a bit of the design process and how I landed here. There are more similarities than differences between the two versions of prototypes that I had made, but I think it’s interesting to see the process.
The first prototype has a few notable differences:
No alignment pins
Almost completely different bottom weights
Additional top badge with Cerberus engraving, but no RGB
Adding alignment pins was a bit of a no brainer. Initially, I had hoped the gaskets would compress enough that friction would lock the plate into place. This was not the case. Even when the keyboard was fully assembled, I could physically move the plate assembly left and right in the case when it was assembled. And if you shook the case, you could hear some rattling. But sound and feel wise - the first prototype checked all the boxes. I didn’t want to change the compression characteristics of the board and change the sound and feel, so alignment pins were the best solution.
For the bottom weights - the first prototype’s weights just felt a bit too… normal. The idea at first was to use a “medallion” instead of a “crest” like we did on Chimera. With the dimensions of the board, it felt like it would fit better. So I went along that path for the first prototype. But when I saw it, it just didn’t hit the right way for me. While more difficult to machine, the current badge feels way more detailed, and gives the board a bit more uniqueness in my opinion.
Because of thickness limitations, I couldn’t make the revised Cerberus accent piece any larger than it is on the second prototype. Instead, I had to adjust the two brass external weights to be slightly smaller. With these adjustments, keeping the flame engravings on the weights wouldn’t have provided the same sort of visual balance it once did - so I removed them. This makes me a bit sad, as I felt like those flames really added to the theme, but I do overall love the bottom of the keyboard a lot more now.
And for the top case - I made the decision to remove the mini Cerberus medallion, and change it into an engraving with glowing eyes. First - I think glowing eyes are really cool - and if you don’t, you can always turn them off. When first picking the theme of Cerberus, I wanted to add glowing eyes somewhere, but couldn’t figure out where. And with the medallion shape on the back removed, I didn’t think it made much sense to keep a medallion shape on the front. While the front is now missing a visual accent that used to be there, it’s a cleaner look now, and the engraving can be infilled to provide extra contrast. I also wanted to listen to feedback from Ripple about the badge - it was a bit of a polarizing feature, so simplifying to an engraving felt like the right call.
Future Improvements
There are still a few things I’d like changed in the final production design. At the moment, when the bottom of the keyboard meets the back curve, I think it changes too abruptly. I’m going to smooth out the transition there. It’s a small thing that some people might not notice, but as I’ve used the board in testing, it’s the one thing that stands out to me as out of place.
Another issue with the current prototype is the crest fitment. It looks like there is a gap on one side, but not the other. There’s supposed to be a miniscule, even gap around the crest. That isn’t the case, and I’ll be talking to the factory about solutions. As drawn in the 3d model - the gap is consistent - so I think this is likely a machining or tolerance problem. Either way, it’ll be addressed for production.
Both of the prototypes I got came with brass bottom accents. And while brass is cool and heavy, I think offering those in aluminum for more of a color selection, or copper, or stainless steel, or all three - would be pretty cool, and work better, aesthetically, for some colors. It would make the board weight less - but that could be a good thing for some people.
With all that in mind, overall - I’m pretty happy with the current design, which is why I’ve chosen to IC it now!
TL;DR
Cerberus is an FRL TKL with single-sided gasket mounting.
Gaskets sit between the plate and bottom case
The plate touches the top case to provide acoustics similar to a top mount keyboard.
It feels good to type on and sounds good
It looks cool
The eyes on the top Cerberus engraving glow with RGB lights
Super cool Cerberus shaped crest on the bottom
8 part case not including the plate
Designed to support wireless (as an addon)
Sub $300 MSRP
PCB Details
QMK and VIA compatible PCB (wired) w/ STM32 Microcontroller
Both hotswap and solderable will be available
ZMK compatible PCB (wireless) w/ nrf52 Microcontroller (ZMK Studio soon)
Only hotswap for wireless
Hotswap PCBs will have 7U bottom row support only, probably, fill out the IC if you think that’s bad
S1 Unified Daughterboard (it will use Molex Pico EzMate)
All PCBs will feature ESD protection
No Backlight Support
RGB Daughterboard for glowing eyes
Other Things People Normally Ask About
Weight: 1518g built with PC Plate, Bottom Brass Weights
I'll get unbuilt weight very soon
Front height: ~17.75mm
Front height in the middle of the bottom row: ~20mm
Angle: 6.5 Degrees
Checking Interest
There are a few things that I’m still trying to figure out about this board, and it’s also not too late to make some changes.I’ve tried to incorporate feedback from prior designs already to create something that I’ll like, but that lots of other people will also like. So I’d love your feedback! I can’t promise that certain things will change, but all feedback is welcome.
Currently, I don’t know what colors to offer. We’ve received prototypes in Black and Red and Purple and Grey. Both of them look pretty cool, but I’m not sure that I’m sold on the shade of red. I want to offer an “ectoplasmic green” accent color similar to Thresh from League of Legends - if you’re familiar with that - because I think it’ll fit the Cerberus theme pretty well.
Whatever colors I do land on - I’m thinking about offering set colorways similar to how I’ve done Chimera in the past. But I’m open to suggestions - so submit your favorite colorway to the IC form. Would people rather be able to mix and match from whatever colors are available? If enough people ask - I’ll try my best to make sure that happens.
Then there’s layouts - I’m planning on selling this by default with a fixed 7U bottom row hotswap PCB, so that WKL is also supported. I think It’d be silly to run an FRL TKL and not offer WKL, so I’ll offer WKL during the group buy for sure!
Do people want 6.25u bottom row support on the plate? What about the hotswap PCB? Are there passionate 6.25U bottom row supporters for TKL sized boards? I’d love to hear from you and find out!
For plate materials, I’ve tested PC, Alu, and FR4. They all sound good, my favorite is FR4 (surprise, surprise). What other plate materials would you like to see?
Our sub $300 MSRP is based on a 200 MOQ. Is that realistic? The price might go up a bit if we can’t hit our target MOQ. And selling 200 custom keyboards (that aren’t from GEON lol) is a lot in 2024. If you’re interested in the board at the ~$300 price point, please let us know in the IC form as well!
Are you interested in the wireless option for the board? Are there enough people for us to offer a hotswap ISO PCB? Or do you have any other comments, questions or concerns? That’s exactly what the IC form is for - so don’t be afraid to submit!
>> SUBMIT THE IC FORM HERE <<
Upas
More Photos
Much thanks to anaolivetree for grabbing most of these (the good ones are hers, mine are the bad ones)
She's taken more photos, but I haven't uploaded them yet
Offline upas
Re: [IC] Cerberus FRL TKL Keyboard - With Glowing Eyes!
« Reply #1 on: Wed, 10 July 2024, 14:37:58 »
Meta question:
Do you have any feedback about the format of the IC?
For example, would it be better if the TL;DR was at the top?
Or do you have any other feedback?
Common Q&A:
Q: Who is going to manufacture the board?
A: We're partnering with Hongtu to manufacture this board.
Q: Can you make a solderable wireless PCB?
A: Leave a comment in the IC form and I will definitely consider it!
Q: NE ISO AVAIL?
A: If we have enough demand in the IC form, we will consider it as well! The solderable wired PCB will have ISO support already.
Q: Do you have a sound test?
A: I don't have any professional quality ones, but I took some myself: https://geekhack.org/index.php?topic=123295.msg3189521#msg3189521. I'll keep adding more to this post as I make more with different configurations.
Q: Screwless is bad, why did you go screwless when you have screws on the bottom already?
A: To help pick up the board, I wanted to put a curve in the back. Having screws go through a curved face isn't an aesthetic I really like.
(Reserved lol)
« Last Edit: Tue, 23 July 2024, 16:29:57 by upas »
Offline koibito
« Reply #2 on: Wed, 10 July 2024, 14:52:07 »
This looks sooo nice, especially the engravings! I’m not even a huge fan of FRLTKL but I’d consider grabbing one of these (and would definitely grab one in a 65% in the future, hint hint)
Obviously I’m biased since I prefer a 6.25u spacebar, but I think support for that on the plate/PCB would be nice :) I prefer having a larger win key just because I use it a lot when working on my Mac.
One idea – it’d be cool if the RGB for the eyes could work as a caps lock indicator, if the PCB doesn’t have support for that already.
For ~$300 this seems like it could be a really good deal!
« Reply #3 on: Wed, 10 July 2024, 15:02:04 »
Just filled out the IC. I pray that Anodized Silver is added as a Top Case color option. I have more keycap sets that I would want to put on it with Silver.
Good luck Upas! I'm loving my Ripple TKL and still use all my Brutal V1 boards. Would love to add this board to my main rotation
Sent from my Pixel 8 Pro using Tapatalk
Offline upas
« Reply #4 on: Wed, 10 July 2024, 15:04:11 »
Thanks for the feedback!
I have a universal plate designed with 6.25U as well already - so if the IC responses show that a universal plate is in demand, we could easily swap that in.
And for the RGB eyes idea - currently they just work as separately controlled RGBs, but we could hook it up to caps lock / layer state too. That's a good idea.
Fingers crossed the anodized silver makes it!
The more "yes" responses we get in the IC, the more likely it'll be that we can offer more colors.
Thank you for the support <3
Offline bigmaxnonions
« Reply #5 on: Wed, 10 July 2024, 15:11:47 »
Is there any concern with pinging from the plate hitting the top of the case? I am not sure how squishy the gasket material is but if there is any compression during typing, when the gaskets decompress I imagine the plate will hit the top of the case. Could there be some included strips of tape or something to put on the top of the plate to isolate it from the top of the case? Other than that, really like the design, interested to see what colors are selected.
Offline kriegar
« Reply #6 on: Wed, 10 July 2024, 15:13:54 »
I DEMAND ECTO GREEN
Offline TyPo.mk
« Reply #7 on: Wed, 10 July 2024, 15:15:48 »
Cool stuff Upas! Form filled.
Outing yourself as a league of legends player is very embarrassing though
Offline spikedsynapse
« Reply #8 on: Wed, 10 July 2024, 15:20:39 »
This looks so dope.
Offline upas
« Reply #9 on: Wed, 10 July 2024, 15:21:15 »
I DEMAND ECTO GREEN
I swear I don't play League!!! (anymore)
But I really want the ecto green. So it's probably gonna happen.
In my experience, I couldn't personally hear any plate to top ping. But I'm also not a heavy typist.
I have some sound test clips that I can share once I find them.
The gaskets are under compression already, so while they are going to provide some softness and could compress further under typing, I don't think there's a large force going through the plate to the top when it returns to cause a noticeable ping.
If you really press hard on the plate/pcb assembly, you can make it bounce, but even then, I don't really hear a return ping.
The force break gaskets are also present where the plate touches the top - if you're a heavier typist, or think you are going to have ping, you can use those force breakers to ensure the plate doesn't hit the top directly, and has something in the way.
I think I labeled them in orange on the force breaking diagram.
Again - for me, it wasn't an issue, so I prefer the sound without the force breakers there. But it is built in as an option for this very reason as well.
« Last Edit: Wed, 10 July 2024, 15:23:43 by upas »
Offline upas
« Reply #10 on: Wed, 10 July 2024, 15:49:19 »
I took this quick sound test. I used the first prototype, but the second didn't really have any internals changed other than alignment pins added
(I used the first one because the second one is currently built with an FR4 plate)
Please excuse the outside noises - it's hot and I have a portable AC installed but the window isn't completely sealed and outside noises leak in. I turned the AC off for the sound test, and I'm pretty sure you can hear a car honk.
Specs:
- PC Plate
- No force breakers installed (at all)
- Keygeek Luxury Linears
- GMK Red Dragon
https://voca.ro/11wAxyZa2YOj
Offline DirtyGingy
« Reply #11 on: Wed, 10 July 2024, 16:27:51 »
That molex connector is enough for me to lose all interest.
Offline upas
« Reply #12 on: Wed, 10 July 2024, 18:06:04 »
I know this might not change your mind - but I did want to come to the defense of the much maligned molex pico ezmate connector.
First - many prototype boards may have cables and connectors sourced from different places. Or, they might use clone parts which aren't as nice as the official Molex Pico EzMate parts. These prototypes are often what content creators have struggled with, or have had poor experiences with. I believe that the parts we use in our production boards do actually have a nicer connection, and last longer. In our testing, they work quite well up to at least 30 mating cycles - which is still not as much as JST-SH, but swapping in a fresh cable extends that effective mating cycle time to be even longer.
Molex Pico EzMate has a lot of other positives as well.
Since changing some of our products to Molex Pico Ezmate, we've received fewer support tickets regarding issues with the connector. Even when packed well, we have seen JST-SH ports fall off of PCBs. This is natural, as they are a tall part compared to a lot of things on the PCB. A given individual might have never experienced a broken JST-SH port, but in aggregate, it does happen, and can be a frustrating experience if you do happen to receive that.
More people also struggle with JST-SH compared to Molex Pico EzMate. All of our PCBs are flashed from the factory, so we know the connector port is correct and doesn't have any bent pins. If it wasn't - the PCB wouldn't have been able to be flashed at the factory. But we still get a good number of support tickets from customers regarding JST-SH bent pins. It's harder to get molex connection wrong.
Finally - when you take a board apart and you forget to disconnect the JST cable - sometimes the JST port can get torn off of the PCB. At worst, it also tears up traces with it. Meaning you need a completely new PCB. And even if traces aren't torn up - not everyone has the skills to resolder a port back on. In our testing with Molex Pico EzMate, the failure point is the cable. We have 0 reported instances of our Molex ports falling off of a PCB. It's way easier (and cheaper) to replace a cable versus a PCB.
If you are familiar with JST-SH and don't suffer from bent pins, and always remember to disconnect your cables fully before disassembling, and build your keyboard 5+ times, I do think that JST-SH is a better connector. But from my point of view, Molex Pico EzMate leaves a little extra room for error, and that's why I personally like it (and have been using it in recent designs).
« Last Edit: Wed, 10 July 2024, 18:08:58 by upas »
Offline hottnucks
« Reply #13 on: Wed, 10 July 2024, 22:32:59 »
This gonna get Cycle 7'd, too expensive. Why do you like to use those huge socket cap screws on all your boards? Also why hex instead of torx?
« Last Edit: Thu, 11 July 2024, 10:15:34 by hottnucks »
Offline DirtyGingy
« Reply #14 on: Thu, 11 July 2024, 01:12:42 »
I'll go with: my bastion PCB for my obliterated75 had the connector literally fall apart from trying to gently pop it loose for a build change.
I don't care about the other benefits if someone with 50+ modern boards and 20ish vintage boards who knows how to be careful had that happen. Those are disposable connectors and meant for embedded systems only.
Offline rikercd
« Reply #15 on: Thu, 11 July 2024, 10:29:41 »
A Chimera-styled TKL would probably make me buy another keyboard
Offline VXQN
« Reply #16 on: Thu, 11 July 2024, 11:40:03 »
Really great documentation with this. Sadly the design is not to my taste but I do appreciate it. GLWGB!
Offline halfling_barista
« Reply #17 on: Thu, 11 July 2024, 14:58:14 »
It looks from the pics of the S1 that the EZ-Mate is SMT but with exposed pins on the back. Is that the same on the main PCB side? I'm just gauging whether - worst case - replacing one with a soldering iron would be possible/recommended rather than hot air.
For me, first one should be fine, but latter gives me pause.
Don't have any boards with these yet, but I really like some recent designs (Cerberus, Petrichor for the LED db) that use them.
EDIT: Forgot to mention, I quite like this and think $300 is a very fair price. Typing sounds wonderful! I agree, it sounds more like a top mount than the Brutal v2, which I also greatly enjoy.
« Last Edit: Thu, 11 July 2024, 17:30:57 by halfling_barista »
Offline upas
« Reply #18 on: Fri, 12 July 2024, 10:39:23 »
Totally heard there - just a point of clarification - was it the connector on the cable or on the PCB?
If IC results share your sentiment, we'll definitely consider swapping back to JST.
It's an easy thing for me to do, and we can make room in the board to support it.
Offline DirtyGingy
« Reply #19 on: Fri, 12 July 2024, 14:15:23 »
Pcb
Offline lkkedward
« Reply #20 on: Sat, 13 July 2024, 11:20:19 »
I love the top engraving with LED but I dont think the bottom art/accent/color/shape are working well, at least not appealing to my eyes.
Offline upas
« Reply #21 on: Tue, 16 July 2024, 12:10:29 »
Pcb
Definitely let our support team at CannonKeys know if you haven't already - if you have, then something is up with our summary statistics.
The connector coming off the PCB was the first time I'm hearing about it on one of our boards with reinforced PCB footprints - that's one of the huge perceived benefits of Molex, but if they are coming off of PCBs, that is also concerning.
For me, I like the current bottom - but I'm not in love with the colors, and I think that might be detracting from the overall appeal.
Particularly, I think silver would work much better than brass on the grey and purple unit.
Whereas I think the black and red unit works really well with brass.
But this is also down to personal taste and opinion. I've heard from people that they really like the bottom and brass + purple combination.
Maybe that's one reason we should allow people to pick all their accents instead of relying on set colorways :D
Offline DirtyGingy
« Reply #22 on: Tue, 16 July 2024, 12:12:34 »
Pcb
I've had the board for a while now and assumes t would be considered user error. I didn't expect anything under warranty/CS
Offline upas
« Reply #23 on: Tue, 23 July 2024, 16:35:40 »
Quick update:
Based on IC feedback, the wired hotswap PCB will also support stepped caps, full right shift, and 6.25U bottom row (in addition to 7U, normal caps, and split R shift)
The wireless hotswap PCB will have more limited support - 7U only, Normal caps only
The default plate is currently 7U only, but based on IC feedback, it seems that we'll likely change that to a universal plate.
Only a few comments about molex connectors - so unless something measurably changes, I'll likely stick with Molex.
Maybe we will include a 2nd backup molex cable since that's the most common point of failure.
Offline upas
« Reply #24 on: Tue, 30 July 2024, 16:01:13 »
Another update - I used a really long cable to connect the PCB to the RGB daughterboard (since it's all I had available), which became really annoying to hide under the top case bezel. If the cable is too short, assembly is difficult, and if the cable is too long - it's annoying to hide. But even a medium-length cable is gonna have slack you'll need to hide.
So I added a cavity in the top case where you can tuck the extra cable slack.
I've also made the (hopefully) final changes to the removeable feet to add a bit of extra friction when they stay in their holes, and round them out a bit to make them look a bit nicer.
The plate is universal ANSI now - I think I will make a separate ISO version for the GB.
With these minor changes - I think we're really for a new (and hopefully final) round of prototyping. If the new prototype passes, we can move on to the group buy! There's a chance this could run this year.
« Last Edit: Tue, 30 July 2024, 16:02:48 by upas »
Offline shendoo
  • *RAUGHS*
« Reply #25 on: Wed, 31 July 2024, 06:52:31 »
Love the thematic and great documentation. Unfortunately, a bit too simple on the side profile for my taste and the weight design needs some iteration.
Offline enomooshiki
« Reply #26 on: Wed, 31 July 2024, 18:31:08 »
that glowing eyes design just too cool! GLWIC!
Offline ashendarien
« Reply #27 on: Sat, 03 August 2024, 03:35:38 »
Having built on 3 production pcbs with molex, I've had issues every single time with the connector not actually firmly staying in place while I assemble/reassemble the rest of the board, simply falling out via gravity or the cable's own weight, as well as if the board was lifted or tilted after assembly. I actually thought I broke both connectors and the cable, but no, swapped everything out (and then again, since the daughterboard was bad 😂 . Only solution was taping it down. Not elegant.
I don't think jst is the be all/end all but molex is a hard pass. I've had more issues on one board than on ~50 other boards, let alone rebuilds. Definitely reasonable and fair for y'all to look at statistics and say hey, jst hard fails more than molex does, and is costing more to support, but as an end user molex is actually worse to fix, since I could just solder jst but molex is fiddly.
Offline upas
« Reply #28 on: Wed, 11 September 2024, 15:34:33 »
I have a few updates - including picking colors that'll be announced at the end of the post.
But first, I want to thank everyone for the feedback so far and address some of the feedback as well.
I've just received the (hopefully) final prototype - I'm waiting on a few final parts, and will be assembling it later this week.
Molex vs JST
I really do appreciate all the talk about Molex vs JST, and I've considered the options, and decided for this board to stick with Molex.
Again - it's mostly about the data we've seen and the support experience. I know for folks who can solder, JST is fine. But not everyone can solder.
We are going to consider going with JST SH for other boards moving forward though, especially as we get into higher price points where people might want to customize and rebuild their boards more.
Landing around $325, we're hoping Cerberus has wider appeal, so molex makes a bit more sense.
Side Profile
I think someone in the IC thread said they thought the side profile is a bit simple - and I suppose it is. But it's an intentional choice.
The board is designed so it's easy to pick up with the curve in the back, so I didn't see a need for a cutaway like on Chimera.
And the crest and engraving are pretty complex! It's good to have simple and complex parts for balance, imo.
But also - having the sides be simple allow us to get them made in brass and PVD Black steel - which I think is a really nice touch.
If the contour was too complex, it'd be expensive to machine in brass and very hard to get a good PVD finish in any material.
Final Prototype Changes
For the final prototype, I wanted to address a few things:
  • Sharper bottom corner I called out in the initial IC post
  • Crest centering on the bottom case
  • RGB daughterboard ease of build
Honestly, the biggest change was the 3rd point. The build experience on the grey and purple prototype (which some content creators are going to get to build) was not great when it came to the RGB daughterboard.
First, the cable was too long. For this new prototype, I got some new cables made for the RGB daughterboard that are shorter, which should help the build experience.
But even with the shorter cable, there was really nowhere for the cable to go. So in the final prototype, there's a cutout near the RGB daughterboard where the cable can be tucked.
Also, the RGB daughterboard would short out of screwed down too hard. I've changed the mounting a bit so there's less case - DB contact now, and that fixes the issue.
Colors
So about 60% of all IC submissions said that they wanted to select their own colors on each part, and I tried to make this happen!
But this is actually tough for MOQ purposes and achieving as low of a price as we hope for. If we expected to sell thousands of these, I think it'd be a different story, but in 2024, we have to be realistic about what demand will probably look like.
With that in mind - for the GB, I'm thinking that we'll allow people to mix and match colors, etc. for an upcharge, but rely on pre-set colorways for the most part.
I've picked out a bunch of pre-set colorways, and honestly I really like them all - but I'd love to hear what you think!
The renders aren't perfect, but they should show off the general combination of colors - in particular, I think it's a bit hard to see the rose gold and light blue, but we'll update these as we have more time to do so (our renderer is currently on vacation).
The colorway names are not at all set in stone either, we tried to pick things that fit the "Cerberus" vibe but I'm not in love with all of them.
Most of these colors were suggested or voted up in the IC!
Hades
Top and Bottom: Black
Sides and Crest: Burgundy
Bottom Weights: Dark Gold
Persephone
Top and Bottom: E-White
Sides and Crest: Rose Gold
Bottom Weights: Silver
Pluto
Top and Bottom: Blue-Purple
Sides and Crest: Gray
Bottom Weights: Dark Gray
The Depths
Top and Bottom: Navy
Sides and Crest: Light Blue
Designer's Choice
Top and Bottom: Dark Gray
Sides and Crest: Lilac
Ectoplasmic
Sides and Crest: Ecto Green (Pantone 326C)
Bottom Weights: Black
Sleepy Hollow
Top and Bottom: Forest Green
Sides: Brass
Crest: Dark Gold
Bottom Weights: Brass
Demonic
Sides: PVD Black Steel
Crest: Black
Bottom Weights: PVD Black Steel
(Note: this one will be limited quantity, since it's got PVD on it)
Next Steps and Timeline
If this final prototype passes, we could run this group buy as early as late October / early November. The "Designer's Choice" colorway prototype is already being sent around to content creators!
We've taken IC feedback into account, and that'll be reflected on all the extra options we offer, but we're waiting on final quote to see where pricing might land. Stay tuned for more updates!
Offline RozenKristal
« Reply #29 on: Thu, 12 September 2024, 07:17:27 »
Marking this so I can jump in. I can only do TKL
Offline taiyox
« Reply #30 on: Thu, 12 September 2024, 16:35:39 »
really into this, especially the all black colorway :thumb:
Offline keebibi
    • My Discord Server
« Reply #31 on: Fri, 13 September 2024, 16:29:40 »
Loving the grey/lilac colorway!
Offline upas
« Reply #32 on: Fri, 27 September 2024, 17:04:51 »
I wanted to post here before creating a new GB thread - just so those following along are the first to know!
(Also for a GB thread, I need to summarize the IC and updates, etc. and that's a bit of work... I think I'll post that tomorrow  :)) )
Major Update
The Cerberus GB will go live from October 25th, 2024 - November 17th, 2024! with a price starting at just: $285!
We're really happy that we were able to beat our price target of $300 - and we thank everyone who filled out the IC for helping us gauge interest and making this possible!
We're pricing at an MOQ of 150, and we think we'll be able to make it.
While we brainstormed some new ideas for the names of the colorways - I decided to stick with these ones that I announced. They might not be the best names, but I've gotten used to them - and I do think they fit the Cerberus vibe.
But based on what the colorway uses, prices might be a bit higher.
Mainly:
Hades, Pluto, The Depths, Designer's Choice, and Ectoplasmic have aluminum accents. They will cost $285
Persephone has an E-white case - so it will cost $295
Sleepy Hollow has brass bottom weights as well as brass sides - the cost increases to $325
And finally - Demonic uses PVD steel, so the cost will be $395
On top of this - during the group buy, we'll also have a Google Form people can fill out if they want to go with a custom colorway (using any of the colors we're already using, not including PVD)
Based on the options you pick, we'll have a price for that too - but it won't be as low as $285.
When it's ready, the group buy post will have pricing for extras and addons as well.
We're also starting conversations with international vendors, so customers can save a bit on shipping.
Unfortunately, the google form customization will be limited to CannonKeys for logistical reasons - so if you're not in the US and want to build your own colorway, you might end up paying a bit more for shipping too.
Final Prototype Updates
The final prototype has been built and just about everything works as expected! It's a blue and brass prototype - which is not actually one of the colors we're going to offer in the GB - but you could use our google form or buy extra accent pieces to make it.
We're going to be sending this unit out to content creators shortly as well, so expect to see some content around this unit too.
There was one minor issue with this prototype, though.
For the Grey + Lilac Proto (designer's choice colorway) our factory made us a bunch of alignment pins - we reused some on the blue and brass prototype we got in - but they didn't fit as well.
This means the plate can rattle against the pins - which the pins are supposed to prevent. We've encountered this before (when we produced the moment keyboard) - and our factory will make sure the alignment pins are tight from the factory, which will solve this issue.
Given this - we're really excited to lock in a date and give folks the opportunity to join in on Cerberus!
« Last Edit: Fri, 27 September 2024, 17:09:58 by upas »
Offline TheManicGeek
  • The Manic Geek
    • Linktree
« Reply #33 on: Wed, 02 October 2024, 23:03:03 »
This will be good to know, thanks for the heads up!
Offline Xinn3r
« Reply #34 on: Sat, 26 October 2024, 01:41:23 »
Any list and timeline on which CCs are receiving the board? I would personally like to see the build experience + sound test from a few to judge before buying it!
