Author Topic: [IC] Dune65(GB has started on vendors)  (Read 21734 times)
Offline kenny_25
« on: Thu, 11 July 2024, 05:32:45 »
GB has started on vendors,12 Sep, 2024 - 15 Oct, 2024
Hello everyone, I am Kenny from Grit.
Introducing Dune 65, a 65% keyboard kit with an elegant design and excellent typing experience.
Exterior Design:
The inspiration for Dune 65 comes from the lines formed under the action of wind on sand dunes (see the image below: sourced from the internet, contact for removal if copyright infringement).
Our goal for the board design is to be aesthetically pleasing while maintaining simplicity.
Therefore, we have removed elements such as logos and text, starting from the most basic points, lines, and surfaces.
The interwoven lines on the back can represent either deserts stretching to the horizon or layers of sand dunes, allowing everyone to enrich its meaning through their imagination.
Based on the initial design drawings, we adjusted the overall thickness, typing angle, and front height.
We also reconstructed the lines at the back, optimizing the overall visual effect.
While ensuring the appropriate bottom case thickness and enough bottom clearence, we minimized the front height and EKH (Edge Key Height) as much as possible.
The typing angle is set at 8° to achieve a more comfortable typing experience.
Prototype Pics:
Basic Information:
- Layout: 65%, 6.25U WK Layout/ 7U WKL Layout
- Typing angle: 8°
- Front Height: 16.5mm
- EKH: 21.59mm
Supported Layout
Hotswap:
Solder:
Mounting Styles and Internals:
The dual mounting style design of the internal brings high playability to the keyboard.
We continue to use the dual mounting style on Dune 65 and have made further improvements.
For the Top mount, we adopted the Leaf Spring Top Mount and adjusted the arrangement of the lower edge plate springs to ensure a consistently excellent inner shell feel and a crisp and pleasing spacebar sound.
For the Gasket structure, to achieve a solid typing experience, we abandoned the leaf spring structure and adopted a silicone Gasket Mount.
In terms of PCB, it will be using a 1.6mm black core board without flex-cuts.
This internal design ensures a clean sound even without foam.
For the bottom case, we chose brass as the high-density material and kept as is.
We placed the small board and battery compartment inside the weight to make the bottom chamber flat and the bottom shell thickness uniform, resulting in a purer and more solid sound feedback.
Keyboard Information
Mounting Style: Leaf Spring Top Mount / Gasket Mount
PCB: 1.6mm black core
Firmware: QMK/VIA Supported Solder & Hotswap PCB
Plate: Aluminum, extra Alu Half Plate
Plate file will be public after GB ends
Top Case Material: 6063 Aluminum
Bottom Case Material: Brass
Weight Material: 6063 Aluminum
Top Case and Weight Surface Treatment: Anodization
Bottom Case Surface Treatment: Transparent E-Coat
Group Buy Colors (Prototype Pics):
- Moonlight (Silver)
- Deep Sky (Gray)
- Sand (Sand Gold)
- Emerald (Green)
- Midnight (Blue)
- Crimson (Red)
- Rose (Rose Gold)
For more prototype Photos, feel free to check out the below album
Scene: https://imgur.com/a/wGji7Mm
Colors: https://imgur.com/a/Em3R4qE
New Album: https://imgur.com/a/changes-compared-8fMdkFC
Minor changes to the international units
Vendors:
Geon Works
 KBDFans
 Keyspensory
Projected Price Point: $350 + Shipping
DC Invite Link: https://discord.gg/tpENfnabV9
« Last Edit: Tue, 08 October 2024, 19:39:52 by kenny_25 »
Offline azhdar
  • Praise the AZERTY god
  • 65% Enlightened
Re: [IC] Dune65
« Reply #1 on: Thu, 11 July 2024, 05:50:31 »
Been looking for a WKL 65% for a while and this look gorgeous.
Will follow this project.
Azerty Propagandiste
Offline mr_foggy
  • neue = nope
Re: [IC] Dune65
« Reply #2 on: Thu, 11 July 2024, 06:02:02 »
bauer blockers gud
Offline DirtyGingy
Re: [IC] Dune65
« Reply #3 on: Thu, 11 July 2024, 06:36:29 »
I have to say, I initially thought "oh hey, a rather plain 65”, but then the side profile pic came up and I have ti say, classy.
Offline Verri0129
Re: [IC] Dune65
« Reply #4 on: Thu, 11 July 2024, 08:58:56 »
Actually 200 units were sold in the 1st round early bird GB in China. The WKL looks very cool!
Re: [IC] Dune65
« Reply #5 on: Thu, 11 July 2024, 09:28:19 »
That side profile goes hard
Sent from my Pixel 8 Pro using Tapatalk
Offline Neely_12
Re: [IC] Dune65
« Reply #6 on: Thu, 11 July 2024, 10:21:25 »
Board is clean, just wish there were some more unique colors. Glwic  :thumb:
Offline richardliu1124
Re: [IC] Dune65
« Reply #7 on: Thu, 11 July 2024, 20:30:20 »
Sand Gold looks very elegant, I have already purchased it in group buy in China.
Offline Randomlosername
  • Gacha Done Got Me
    • IG
Re: [IC] Dune65
« Reply #8 on: Fri, 12 July 2024, 12:45:04 »
This board seems so well designed! I absolutely love the Deep Sky, Midnight, and Emerald colors. The midpiece on the board is just perfect and that side profile is HOT. This is a must buy for me.
Offline xLeHoy
  • weeb board enjoyer
Re: [IC] Dune65
« Reply #9 on: Fri, 12 July 2024, 15:48:13 »
Nice side profile for sure. Looking forward to seeing more!
GLWIC
Offline antsinyourpants
Re: [IC] Dune65
« Reply #10 on: Fri, 12 July 2024, 21:48:58 »
Gorgeous! SA Ramses would pair perfectly with this.
Offline JonBon
Re: [IC] Dune65
« Reply #11 on: Sat, 13 July 2024, 14:01:03 »
I love the attention to detail, especially the interior engraving!  I'll definitely be following this project.  GLWIC
Offline Kndra
Re: [IC] Dune65
« Reply #12 on: Sun, 14 July 2024, 01:41:07 »
holy side profile
such a pretty keyboard
I have a distaste for the function row
Offline Zyrophr
  • https://zyrophr.com
    • zyrophr.com
Re: [IC] Dune65
« Reply #13 on: Sun, 28 July 2024, 11:12:55 »
bump because true wkl
French keyboard streamer
Offline BlivionIaG
Re: [IC] Dune65
« Reply #14 on: Sun, 28 July 2024, 11:16:17 »
Ohhh a wkl 65 that is pretty 👀.
Offline ThatGeologist25
Re: [IC] Dune65
« Reply #15 on: Tue, 13 August 2024, 09:03:11 »
This looks hella pretty. I almost expected just another plain 65% but damn that side profile goes hard the inside looks amazing. I just want to know when group buy outside China will occur.
  • Gacha Done Got Me
    • IG
Re: [IC] Dune65
« Reply #16 on: Sun, 25 August 2024, 10:19:27 »
Bumping this bc I keep losing the thread and I have to search for when I wanna come stare at this pretty as mf board.
Offline Fwuzzy
Re: [IC] Dune65
« Reply #17 on: Tue, 03 September 2024, 17:07:07 »
I need
Offline tuxkey
Re: [IC] Dune65
« Reply #18 on: Mon, 09 September 2024, 11:12:22 »
Come on guys how about sum EU vendors.. i mean if Geon can give us EU vendors so can you.. There are enough good ones.. Keygem, DeltaKeys, Candykeys .. So no excuse i like the brass bottom and the fact that there is so much brass internal facing promises good internal sound.. And i have like 10 or more 65% boards but this could be my final 65% but not if i have to deal with customs crap.
Thinking about it ,...it's good that you don't have a EU vendor otherwise it would be extremely hard for me to resist.. As Desert theme and that 6.25 spacebar with 3 left 2 right 1.25 is my fav layout..  :cool:
But no EU vendor is a good excuse for me to skip
« Last Edit: Mon, 09 September 2024, 11:23:52 by tuxkey »
Offline fuster
Re: [IC] Dune65
« Reply #19 on: Mon, 09 September 2024, 11:52:02 »
Gorgeous looking board, too bad it is a 65%
Offline kenny_25
Re: [IC] Dune65
« Reply #20 on: Thu, 12 September 2024, 10:46:13 »
I need
The GB has started, feel free to check it out!
Offline androo530
Re: [IC] Dune65
« Reply #21 on: Sat, 14 September 2024, 20:41:59 »
is there a schedule or list of content creators reviewing the board? Lowkey waiting for someone to test out the half plate to see how it sounds before I pull the trigger
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
Re: [IC] Dune65
« Reply #22 on: Sun, 15 September 2024, 02:01:40 »
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline neeebskeeb
Re: [IC] Dune65
« Reply #23 on: Sun, 15 September 2024, 15:00:38 »
@Kenny_65
Is Hotswap 7u Spacebar for the WK layout possible? Please please consider adding that option, I will love you forever! lol
P.S. Delete 6.25 spacebar if needed hehe  ;D
Offline androo530
Re: [IC] Dune65
« Reply #24 on: Sun, 15 September 2024, 20:34:48 »
Thanks, I saw these videos. I don't think any reviewer has received or used the half plate yet. Hoping to get some half plate sound test at some point
  • Gacha Done Got Me
    • IG
Re: [IC] Dune65
« Reply #25 on: Sun, 15 September 2024, 23:59:00 »
Yeah I really wanna hear how a half plate sounds. Granted I already bought a board with both solder and hotswap pcb lol.
Offline kenny_25
Re: [IC] Dune65
« Reply #26 on: Fri, 20 September 2024, 02:20:44 »
09/20 Update:
Adding reference picture of minor changes to the case for the international units.
Adding pictures for Crimson and Rose colorway
Offline kenny_25
Re: [IC] Dune65
« Reply #27 on: Fri, 20 September 2024, 04:33:49 »
Right now we have Alexotos and Mechmerlin finished their review.
While this below list of content creators are going to post before the gb ends
Dbokey
Markerchun
Bumblebee
Offline kenny_25
Re: [IC] Dune65
« Reply #28 on: Fri, 20 September 2024, 04:35:20 »
@Kenny_65
Unfortuantely it won't be possible as its is already full to fill the bottom row with wk and wkl layout. It wont be possible to fit the 3rd. WK 7u only available on solder pcb
Offline kenny_25
Re: [IC] Dune65
« Reply #29 on: Fri, 20 September 2024, 04:46:20 »
We sent half plate to Dbokey, hoping he will build one with half plate
Offline kenny_25
Re: [IC] Dune65
« Reply #30 on: Wed, 25 September 2024, 05:21:11 »
Update on media list with link:
Alexotos:
MarkerChun:
Mechmerlin:
Dbokey: waiting
BumbbleBee: https://www.instagram.com/p/DAME_6NKElW/
Offline kenny_25
Re: [IC] Dune65(GB has started on vendors)
« Reply #31 on: Tue, 08 October 2024, 19:37:08 »
GB has started on vendors,GB 12 Sep, 2024 - 15 Oct, 2024
Exterior Design:
Prototype Pics:
Basic Information:
- Typing angle: 8°
- EKH: 21.59mm
Supported Layout
Hotswap:
Solder:
- Deep Sky (Gray)
- Sand (Sand Gold)
- Emerald (Green)
- Midnight (Blue)
- Crimson (Red)
- Rose (Rose Gold)
Vendor:
Geon Works
KBDFans
Keyspensory
Offline Isodorf
« Reply #32 on: Sat, 12 October 2024, 19:19:27 »
will different plate materials ever be offered?
