Author Topic: [IC] SLICK TKL ; Full Stainless steel TKL from SR Industry  (Read 10132 times)
Offline syryan
    • www.kbdmania.net
« on: Sat, 03 August 2024, 02:48:03 »
* SLICK
* Specifications
- Layout : TKL F12 WK / WKL
- Mounting : Bottom / Top
- Typing Angle : 8° 30'
- Front Height : 18.5mm
- PCB : Solder, Hot Swap
- Weight : 4.8Kg ( Unbuild )
- Material : Stainless Steel 304 _ Polishing PVD
- Color : Silver, Black
* Layout
309211-0
* Standard Kit
- Top Case
- Bottom Case
- Carry Case
- Microfiber Towel
- Case Screw
- Mount Screw
- Bumpon
* Extra
- Plate ( Aluminum, PC, Stainless Steel, FR4, Carbon )
- PCB 1.6t ( Solder, Hot Swap )
* Exploded view
309213-1
* Outline Dimension
309215-2
* Proto _ Black
309217-3309219-4
309221-5309223-6
* Ptoto _ Silver
309229-7309231-8
309233-9309235-10
* Faq
- Coming soon
* Venders & Priceing
- Coming soon
* Sound Test
* Discode Link : https://discord.gg/T3Gc5J9fP5
* Instagram Link : https://www.instagram.com/p/C-MtIXQSI-V/?img_index=1
                         https://www.instagram.com/p/C-MtOIcymeM/?img_index=1[/size][/size]
« Last Edit: Fri, 20 September 2024, 22:22:54 by syryan »
Re: [IC] SLICK TKL ; Full Stainless steel TKL from SR Industry
« Reply #1 on: Sat, 03 August 2024, 03:08:25 »
Looks intriguing
GLWIC
Sent from my Pixel 7 Pro using Tapatalk
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #2 on: Sat, 03 August 2024, 06:17:01 »
will be expensive i suppose
slick though
Offline DirtyGingy
« Reply #3 on: Sat, 03 August 2024, 06:29:13 »
The fingerprints...
Offline keepoto
  • HHKB top for TKL pls
« Reply #4 on: Sat, 03 August 2024, 08:11:57 »
no hhkb top i downvote
Offline LiftOffToSpace
« Reply #5 on: Sat, 03 August 2024, 09:39:29 »
must type with white gloves. This feels like a display piece. Look beautiful!
Offline whohackedme
« Reply #6 on: Sat, 03 August 2024, 14:37:43 »
Holy moly.
I hope it sounds amazing because I'm about to bet both colorways. Was also concerned about fingerprints.. then I asked myself how often am I rubbing or touching non-keycap parts of my board. Excited to hear more updates!
Offline xLeHoy
  • weeb board enjoyer
« Reply #7 on: Sun, 04 August 2024, 10:51:57 »
That sounds... Expensive... But I am intrigued nonetheless
GLWIC
Offline enomooshiki
« Reply #8 on: Sun, 04 August 2024, 11:30:06 »
기대됩니다!
Offline SwitchKeys
    • SwitchKeys
« Reply #9 on: Sun, 04 August 2024, 21:08:27 »
Holy moly.
The issue with 'how it sounds' is more the fact that it is relying on 3 layers of foam.
OP were acoustics an issue with it in its current form? I actually don't mind what you're going for here, but the engraving + foam probably kills it for me.
Offline Bahm78
    • https://blog.naver.com/hjg7808
« Reply #10 on: Sun, 04 August 2024, 22:57:26 »
It's a shiny material!
Offline Osidian
« Reply #11 on: Thu, 08 August 2024, 21:48:09 »
Big fan of the stainless steel. This looks very sleek  :thumb:
Offline Cringelord
  • Crack Connoisseur
« Reply #12 on: Fri, 09 August 2024, 01:09:43 »
Cool concept! Too shiny to actually use, maybe consider a sand blasted or low grit satin finish for easy maintenance.
