Author Topic: [IC] Hola (40%+pad)& Hola Mini(40% keyboard)  (Read 15375 times)
Offline windlabs
« on: Mon, 23 September 2024, 01:47:23 »
Hello,this is wind studio
Today we bring a new series keyboard,hola mini(40% keyboard) and hola(40% with pad keyboard).
Hola mini-40% layout
Hola-40% with pad layout
Feature:
1.They are designed for who love mini compact keyboard, want to save desktop space or carry it easily.
2.Hola with pad design,maximize typing experience while saving space. Pad area support split all 1u.
3.Split spacebar, a FN key between 2.25u and 2.75u spacebar,designed to reduce finger travel and increase typing speed.
4.Compatible with most keycap base kits,no need to purchase 40 layout dedicated keycaps separately.
1. Appreance
Add 3 small dots of RGB on the upper left side of the front as decoration,also it is caps indicator light.
A slight bevel design is added all sides to form a waistline to optimize the visual effect.
The back uses an engraved line design with a water ripple mirror PVD weight decoration, and hidden screws
2.Structure
Hola & Hola Mini support PCB Gasket
Size
PCB and Plate
Wired hotswap pcb and wired soldered pcb are available, support software on VIAL
Layout of hola mini
Layout of hola
PC/FR4/ALU plate
Hola mini plate
Hola plate
3.Color Choice
Black top case +grey bottom case
E-retro white
Ano red top case +grey gold bottom case
4.Package include
1*Top case
1*Bottom case
1*Mirrowed pvd weight
1*Wired hotswap PCB
2*Type-c daughterboard
1* PC plate
1*Foam kit
1*Accessories bag(bumpons,gaskets,screws,spanners)
1*Package
5.Group buy information
Price:Hola mini $189, Hola $199. Extra wired soldered pcb:$15/pcs, extra fr4/alu plate: $10/pcs
Instock time: estimate on Oct/Nov,determined on later
Instock payment: not determineded now, pls pay attention to our website or discord if there have local vendor
Case material:6063alu
Typing angle: 7°
Mount structure: PCB gasket mount
PCB: 1.6mm
Plate:1.5mm
Weight after assembly: hola mini-0.75kg hola-0.9kg
Shipping:Within a week after instock sale starts
Check product link on our offical website:
https://windstudio.store/products/hola-keyboard-kit?variant=44460998787172
Join our discord and discuss anything!
Discord:https://discord.gg/qXJtBVWwnc
Offline ggggggg
  • schmeiß die forties durch den club
Re: [IC] Hola (40%+pad)& Hola Mini(40% keyboard)
« Reply #1 on: Mon, 23 September 2024, 02:51:38 »
I like this a lot but that bottom row is not a winner. Would much prefer an option without the 1u between spacebars.
Also don't really get the forced split left shift.
« Last Edit: Mon, 23 September 2024, 02:53:17 by ggggggg »
Offline unipanic
« Reply #2 on: Mon, 23 September 2024, 03:44:30 »
I have to agree about the forced split left shift. I'd rather have a larger shift and no extra key there. Please make that optional.
Offline Koniotaur
« Reply #3 on: Mon, 23 September 2024, 08:25:46 »
I like the bottom. Bottom row layout is weird. Every bezel dimensions is different which in my eyes is unpleasant thing. I mean chin, forehead and sides
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #4 on: Mon, 23 September 2024, 12:03:24 »
Love the numpad version but please give us more options for the bottom row and allow a full left ****!
Offline giuliano.cz
« Reply #5 on: Mon, 23 September 2024, 13:35:29 »
Would love to see more bottom row options, if only it was HHKB...  ;)
Offline Zahul
« Reply #6 on: Tue, 24 September 2024, 12:24:30 »
+ on the bottom row and split left shift is a deal breaker
« Last Edit: Tue, 24 September 2024, 14:05:52 by Zahul »
Offline Necrolegion
« Reply #7 on: Wed, 02 October 2024, 12:41:36 »
++ on the bottom row as well. Oof!
I hope you consider at minimum split or 6.25u spacebar. Also any options for hhkb or WKL?
Offline EdgeOfInfinity
« Reply #8 on: Thu, 10 October 2024, 19:28:54 »
+1 what everyone else said
Offline Cringelord
  • Crack Connoisseur
« Reply #9 on: Fri, 11 October 2024, 04:05:39 »
Like everyone else, bottom row layout is ass and split left shift is wack - non iso user lmao.
Offline LASERman Projects
  • Soldering is my native language.
« Reply #10 on: Fri, 11 October 2024, 09:09:02 »
Unlike to "everyone else" comments more big keys on 40% make no sense to me.
Such small keyboard requires changing habits (unless you buy it for display only) and more split keys = more keys = easier to map all keycodes.
The whole idea of utilising typical base kit is brilliant! First one AFAIK and deserves kudos without whining.
Of course I'm biased for unorthodox layouts - I designed this - feel free to ignore me.
Offline ggggggg
« Reply #11 on: Sat, 12 October 2024, 04:53:36 »
It's not the first big mod 40% (off the top of my head Equinox ran 5 years ago). People aren't critiquing the amount of keys, they're complaining about a split bar setup that doesn't feel good to actually use. Fortunately Wind Studio have revised the layout and posted it on their discord. No idea why they're not updating this thread as well.
Offline CONIN
« Reply #12 on: Sun, 13 October 2024, 00:12:06 »
Looking forward to this one!
« Reply #13 on: Mon, 14 October 2024, 04:31:25 »
Nobody said they did and split bar setup is obviously a personal preference. Some of us find split bars reaching further to the sides (like full one does) better to use.
I am just expressing my opinion about slamming any new layout just because it "doesn't look" the same as the boring staple. I'm sure it is not about usage but just a resistance to embrace something different.
Offline XiXora
« Reply #14 on: Tue, 05 November 2024, 11:45:35 »
Are those mini plates final? Those do not support ISO, right?
Offline CONIN
« Reply #15 on: Tue, 05 November 2024, 22:21:20 »
I hope it's just an error, given the layout pics for both the hot-swap and soldered PCBs show ISO support.
Offline ggggggg
« Reply #16 on: Wed, 06 November 2024, 03:30:05 »
My guess is they're just not updating this thread, and haven't produced new renders.
Offline jd
  • 60%
« Reply #17 on: Wed, 06 November 2024, 19:54:19 »
Split left shift is a big deal maker for me.
Offline CONIN
« Reply #18 on: Wed, 06 November 2024, 20:00:43 »
Looks like they don't care about their own thread, but I remember someone mentioning in a recent stream that both PCBs will have Full Left Shift support.
Offline windlabs
« Reply #19 on: Wed, 06 November 2024, 20:13:58 »
Yes, the pcb in stock sale will support full shift
Offline yuukou_
« Reply #20 on: Thu, 07 November 2024, 21:30:20 »
Damn if only this had the option for southpaw numpad, it'd be sick
