Author Topic: [IC] Optica - 60%  (Read 39818 times)
Offline the flying penguin
[IC] Optica - 60%
« on: Wed, 02 October 2024, 12:42:55 »
OPTICA
DISCORD
GOOGLE FORM
INDEX
1. Introduction
2. Specifications
3. Media
4. Availability
5. Soundtest
6. Status
Introduction
Hello Geekhack, this is the interest check for Optica.
With so many boards with intricate weights on the back that end up being under-appreciated, Optica was created from a desire to make something that looked as good as it types and sounds, from the angles that actually matter.
With design traits inspired from the likes of Geon, Gok and many others, my aim with the case design is to continue pushing the modern keyboard aesthetic in a way that isn't as loud as Matrix/QK, or as predictable as the boxes on wedges(not that there's anything wrong with either).
Specifications
WK/WKL/HHKB
6.9° Typing Angle
Front Height: 17.9mm/22.0mm EKH
1.54kg Fully Built
Combination of Plate-mount F1-8x O-Ring Style Gasket + Friction-fit O-Ring (Use them both at once)
Internal Ribbing for Acoustics
Angled Screw Assembly
PCB:
1.6mm FR4 PCB (MX Only)
H60 JST Positioning
H60 O-Ring Mounting Points
Materials:
Aluminium Plate
Aluminium Top & Bottom Case
Stainless Steel Weight
Pictures
Credit: 青空
Credit: Saper, NaoNao
Availability
Optica will be sold in the GB format, and manufactured by KEZEWA.
MOQ: 50
GB Period: 3rd Jan - 3rd Feb
Timeline: Q2 2025 - Delivered 3 months after GB ends
Estimated Price: $399USD w/ 2 PCBs and stainless steel weights.
Final Price: $349USD w/ 2 PCBs and stainless steel weights
Prices will be adjusted slightly depending on your local vendor.
Kit Contents:
1x Top Case
1x Bottom Case
1x Weight
1x Aluminium Plate
1x Hotswap PCB
1x Solder PCB
1x Carry Case
1x C3 Daughterboard w/ JST Cable
1x Set of 50A Gaskets
1x Set of 70A Gaskets
1x Set of Rubbet Feet
Vendors:
International:KBDFans
US : ClickClack
EU: EloquentClicks
AU: Toro.Studios
Vietnam:Nuxros
China:Kezewa
Singapore: ktechs
Malaysia: Mecha
UK: Prototypist
CA: Mech.land
Soundtest
Gateron Smoothies w/ 70A Gasket
SWK Catmints w/ 70A Gasket
Status
Colourways are still being decided on;
but raw and silver are definitely being included.
Prototype Notes:
Notes from V1:
Minor adjustments to internals.
Notes from V1.2
Typing feel and sound are within target.
Removal of eye accent from weight.
Addition of text engraving on weight.
Adjustment of front accent machining plane.
Adjustment of edge breaks around the front accent.
Confirmation of this version to be utilised as Media Units.
Update to V1.3
Adjustment to angled screw mounting
Addition of force break
Increased internal space
Adjusted internal ribbing
Re-addition of eye weight
The low MOQ is a conservative estimate, and the pricing will be changed accordingly to the expected number of units with data from the IC form.
I will bending MYMK 2024 with Optica and my other boards!
Thank you to the many friends that helped this project take shape for the past year.
Thank you to Kevin and Manu personally for helping elevate the project in ways I could have never alone.
Thank you, for reading all the way to the end!
Don't forget to fill up the form!
« Last Edit: Thu, 23 January 2025, 09:33:42 by the flying penguin »
Offline Kaitodesu
  • Chief of Custom Keyboards(COCK) at Mecha Malaysia
    • I take photos and videos of Keyboards
Re: [IC] Optica - 60%
« Reply #1 on: Wed, 02 October 2024, 12:59:19 »
Love the leaf spring gasket mount in a small, easy-to-control 60% enclosure. Very pleasing and clean acoustics especially when I listen to friction-fit oring everyday.
« Reply #2 on: Wed, 02 October 2024, 13:20:55 »
Love the side profile
Offline nuxroskb
    • Keyboard from Vietnamese Maker
« Reply #3 on: Wed, 02 October 2024, 14:06:26 »
I'm in love...
Offline LOOX
« Reply #4 on: Wed, 02 October 2024, 17:17:27 »
It's really superb. Is there an idea for the date of the GB?
Offline Aethelberht
« Reply #5 on: Wed, 02 October 2024, 19:13:13 »
I'm better than all of you combined.
Offline kentdo10
« Reply #6 on: Wed, 02 October 2024, 20:04:07 »
Lets goooooo!!!
Offline sauvieng
« Reply #7 on: Wed, 02 October 2024, 20:15:50 »
hot damn!
Offline nuxroskb
« Reply #8 on: Thu, 03 October 2024, 00:03:19 »
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #9 on: Thu, 03 October 2024, 02:41:39 »
Board is absolutely gorgeous! Filled out the IC! I will note here tho that I think you could def run this at an MOQ of 100. 60% is super popular still and it’s a very gorgeous board with a very nice sound profile.
« Reply #10 on: Wed, 09 October 2024, 11:21:16 »
Thank you for the kind words!
The MOQ and pricing was chosen with the idea in mind that the loud design would ultimately make this board rather polarising, and the current IC results do indicate that to be the case.
Nevertheless, I'm glad that this was able the board was able to speak to you!
« Reply #11 on: Wed, 09 October 2024, 11:22:58 »
I'm in love...
Lets goooooo!!!
hot damn!
Thank you for the support!
Offline pseudonym
« Reply #12 on: Thu, 10 October 2024, 14:36:45 »
Non-shiney weight would be great.
Offline LOOX
« Reply #13 on: Fri, 11 October 2024, 02:42:53 »
There is no seller for Europe?
Offline jd
  • 60%
« Reply #14 on: Tue, 15 October 2024, 20:29:57 »
Is this compatible with most other 60% PCBs or do we have to use the PCBs that come with the case?
« Reply #15 on: Wed, 16 October 2024, 01:37:35 »
This will be compatible with any H60-based PCB!
Updated with EloquentClicks on board!
Offline jd
  • 60%
« Reply #16 on: Wed, 16 October 2024, 16:38:19 »
Thank you, definitely very interested in the GB now!
Offline keepoto
  • HHKB top for TKL pls
« Reply #17 on: Sun, 27 October 2024, 03:39:16 »
oui this some good ****
Offline Saurov
« Reply #18 on: Sun, 08 December 2024, 13:09:39 »
really love the design on this, looks very elegant with those curves (also prefer the text on the weight vs the eye on the original design). definitely interested - would love to see a purple or lilac color option.
Offline zegonix
« Reply #19 on: Wed, 11 December 2024, 02:18:21 »
is there an update on the timeline?
« Reply #20 on: Mon, 30 December 2024, 10:38:56 »
Updated the IC with new photos and updates for the GB very soon!
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #21 on: Mon, 30 December 2024, 12:12:35 »
Let's go! Also saw the price got knocked down by $50, very nice!
Offline rayy
  • aesthetics enthusiast.
« Reply #22 on: Mon, 30 December 2024, 15:54:11 »
she's a beaut.  :thumb:
Offline Surefoot
« Reply #23 on: Sat, 04 January 2025, 06:58:49 »
Will you provide plate files ? Provided plate is ANSI only, I'd like to have my own ISO plate cut (also with different materials).
« Reply #24 on: Sun, 05 January 2025, 23:21:12 »
Plate files will be provided at the end of the GB!
Offline zegonix
« Reply #25 on: Mon, 06 January 2025, 09:33:07 »
awesome!
will there be qmk firmware? and if so, will it be pushed to qmk_firmware repository or made available another way?
« Reply #26 on: Wed, 22 January 2025, 23:11:06 »
Yes to both!
Will be added to GitHub as soon as VIAL gets put in.
Offline zegonix
« Reply #27 on: Thu, 23 January 2025, 02:19:35 »
great, can't wait for my unit to arrive :)
the second line suggests you are pushing to the vial fork? or both qmk_firmware and vial?
also, would the mcu be compatible with zmk? in case that project gets support for wired and other features i can't do without, i would really like to give it a try and potentially port my keyboards to zmk.
« Reply #28 on: Thu, 23 January 2025, 09:29:20 »
...the second line suggests you are pushing to the vial fork? or both qmk_firmware and vial?
Both.
Unfortunately, ZMK's 3
From my understanding, ZMK's 32/64-bit requirement unfortunately makes this not possible.
Offline zegonix
« Reply #29 on: Fri, 27 June 2025, 03:54:38 »
i am to receive my unit on monday, so i looked through the qmk repository for the firmware, to be prepared when the keyboard arrives.
i could not find a keyboard by that name, is it merged yet? otherwise, can i get the schematics or pinout, to make my own configuration?
« Reply #30 on: Tue, 01 July 2025, 13:10:51 »
shoot me a dm on Discord, @theflyingpenguin
Offline zegonix
« Reply #31 on: Wed, 02 July 2025, 03:12:10 »
i would rather not use discord. also i sent you a dm on geekhack, hope that works for you.
« Reply #32 on: Mon, 07 July 2025, 11:27:00 »
Is this ever getting a rerun in the future? love the design unfortunately when GB was open at kbdfans I couldn't afford this. If so I would save up and just wait.
Offline Wise Donkey
« Reply #33 on: Wed, 21 January 2026, 16:05:55 »
Any chance of another run of the Optica in 2026? Or maybe a 65% version?
Offline Kezewa2020
« Reply #34 on: Wed, 21 January 2026, 17:26:08 »
Let's wait and see
Offline zegonix
« Reply #35 on: Thu, 22 January 2026, 02:39:46 »
that would also be a good opportunity to fix the main issues (i write this comment from my optica60):
* case ping due to tilted hidden screw design which makes near impossible to do a good force break
* use a reasonable bootloader for STM32F103, or a chip with a reasonable locked bootloader
* provide qmk configuration, or at least a schematics/pinout
after connecting a debugger by soldering on leads and flashing a decent bootloader, following the traces by hand and making my own qmk configuration (for gui-free, plaintext configuration of the keymaps) i am quite happy with the board.
TLDR: while the last two points are probably not an issue for most, i would recommend to lookout for the case ping in case of a rerun.
