Author Topic: [IC] BabyDragon - 60% keyboard  (Read 18195 times)
Offline TripleT9x
« on: Sat, 12 October 2024, 08:08:56 »
Hi all,
From my little workshop Wuqi.works. I'm excited to introduce my new project keyboard - Baby Dragon
This project is 60% layout with o-ring mount. The theme of the keyboard inspired from the movie How to train the dragon "Toothless"
Prototype
Prototype soundtest
Specifications:
- Typing angle: 8°
- Dimensions: 294.7mm x 108.9mm
- Front height: 19.06mm
- Case marterial: 6061 aluminum
- O-ring mount
- Clip-in stab support
- Inner weight: copper
- Backplate: brass/copper with sandblasting and clear cover or Black/silver aluminum anodized
- Fullbuild : 1.6 kg
Solder PCB layout support
Hotswap PCB layout support
Color
It's red color on the first prototype. I running with few more color: Black, Blue, Grey and Pink. i'll update when new color on hand
Kit Content
- Body Case
- Aluminum plate (Black anode)
- Inner weight copper
- Backplate
- 1.6mm PCB
- 50A oring rubber
- Daughter board
Pricing
- My planning is in-stock few pcs per color
- Price: about 220$ for kit
« Last Edit: Sat, 12 October 2024, 08:58:50 by TripleT9x »
Offline Daebak_Tofu
Re: [IC] BabyDragon - 60% keyboard
« Reply #1 on: Sat, 12 October 2024, 08:36:06 »
Is the "dragon design" inspired by HTTYD Toothless? It looks like the chibi Toothless you can find on the internet
Offline TripleT9x
« Reply #2 on: Sat, 12 October 2024, 08:41:02 »
leave me any question or advice. Thank all !
« Last Edit: Sat, 12 October 2024, 09:27:59 by TripleT9x »
Offline TripleT9x
« Reply #3 on: Sat, 12 October 2024, 08:50:08 »
Yep, I love that movie. The theme of the keyboard is inspired from Toothless.
« Last Edit: Sat, 12 October 2024, 09:07:34 by TripleT9x »
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #4 on: Sat, 12 October 2024, 13:54:12 »
Super cute little 60 and it doesn't sound too bad either! I would love to pair an all black one with Noche Negra base from GMK Mictlan!
Offline usedchopstick
« Reply #5 on: Sat, 12 October 2024, 18:47:19 »
This looks great and I'm interested for sure. Would  it be possible to add an HHKB top?
Offline TripleT9x
« Reply #6 on: Sat, 12 October 2024, 20:34:55 »
On that prototype, HHKB is not possible. 1st prototype i made for my personal hobby. I think will have something change on next prototype.
« Reply #7 on: Sat, 12 October 2024, 21:45:15 »
I like the design. Any chances of anodized silver for a case color?
Also, Obligatory:
Offline Gemmmmmmmmmmmmmy
« Reply #8 on: Sat, 12 October 2024, 22:37:03 »
This is adorable
Life seems so much smaller
Swim to the moon
Offline Saurov
« Reply #9 on: Sat, 12 October 2024, 22:49:10 »
looks cute, interested to see the other colours. GLWIC
Offline SpookyGC
« Reply #10 on: Sun, 13 October 2024, 08:00:03 »
Also, Obligatory:
Lol this is what i was expecting when i saw the title.
Offline azhdar
  • Praise the AZERTY god
« Reply #11 on: Mon, 14 October 2024, 02:01:25 »
ISO ?
Azerty Propagandiste
Offline TripleT9x
« Reply #12 on: Mon, 14 October 2024, 10:35:32 »
yes !!!
ISO ?
I'm cooking pcb, so I think I can add ISO on the solder version
Offline jd
  • 60%
« Reply #13 on: Tue, 15 October 2024, 13:26:25 »
Is the case compatible with other 60% PCBs and/or daughterboards?
Offline TripleT9x
« Reply #14 on: Tue, 15 October 2024, 23:07:37 »
also need O-ring mount suppport on the pcb
Offline pseudonym
« Reply #15 on: Thu, 17 October 2024, 15:04:46 »
I filled out the IC form, but want to ask for HHKB in the forum as well, preferably with 3-1-3 split SB option for both HS and solder PCB.
Your design is very cute!
Offline feedj
« Reply #16 on: Sat, 19 October 2024, 00:58:26 »
Cute little board!
Are you looking into other plate materials or is it gonna be an aluminum only plate?
Offline TripleT9x
« Reply #17 on: Sat, 19 October 2024, 03:27:32 »
Cute little board!
should i add-on fr4 plate for another options?
Offline feedj
« Reply #18 on: Sat, 19 October 2024, 15:36:40 »
Well personally id go with a CF or FR4 option. I think carbon would fit the aesthetics of the board and the toothless dragon theme, thus would be my preferred choice but even if you just wanna limit it to only aluminum I think its fine.
Offline jd
  • 60%
« Reply #19 on: Sat, 19 October 2024, 18:55:10 »
I like aluminium plates, but having more options is definitely a plus.
Offline KenGuru
« Reply #20 on: Sun, 20 October 2024, 12:57:29 »
I like this, but I‘m a little concerned about the curves on the side. Looks like pretty visible machining marks.
Would love if this could be fixed.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #21 on: Sun, 20 October 2024, 14:23:12 »
Nice design, gives me a real OG vibe since it's shape is reminiscent of those old tray mount Hammer 60% cases that were very popular when around 2014/2015. I agree with KenGuru that I'd like to see tighter machining on the finalized case, also would personally like to see it made from 6063 alu for cleaner machining & anno. Either way I definitely dig the design & price point you're shooting for, GLWIC!
  • Gacha Done Got Me
    • IG
« Reply #22 on: Sun, 20 October 2024, 14:39:55 »
It looks like for whatever reason that portion of the board did not get polished or buffed which is why there is still remnants of heavy machine lines. That type of severe radial tool pathing isn't gonna be clean no matter what tho. Unless they use something like a 1/16th" Ball Nose EM lol. Or maybe even a 1mm (which would take hella long adding to the overall cost) Just looks like they need to polish and then buff that lightly before they finish it and it should look much much better (Am a machinist for reference)
Offline jd
  • 60%
« Reply #23 on: Sun, 20 October 2024, 17:13:19 »
Have you thought about offering this keyboard with a WKL and HHKB option? I'm a big fan of the WKL aesthetic on 60%.
Offline TripleT9x
« Reply #24 on: Sun, 20 October 2024, 19:54:15 »
Thank you for the advice, i'll attention that point.
maybe WKL on the other version of BabyDragon.
Offline Rob27shred
« Reply #25 on: Mon, 21 October 2024, 04:55:13 »
Nice, that seems like a better solution. Since you're a machinist could you let me know if I'm right or wrong about 6063 vs 6061 as far as machining goes? I've always been told 63 is easier to machine & finish while 61 is more of a structural material that is harder to finish. Just looking for another opinion so I am not spreading misinformation, thanks!
Offline scorcher36
« Reply #26 on: Mon, 21 October 2024, 09:48:18 »
This is unique to the theme but I not sure how well this will be received considering how unpolished the board is right now. Board overall seems very rough. Need more revision for sure. GLWIC.
Offline TripleT9x
« Reply #27 on: Mon, 21 October 2024, 10:06:48 »
Thank you! surely make more proto for improve the project.
