Author Topic: [IC] GMK CYL Flare | GB LIVE!  (Read 47330 times)
Offline Kiririn
Re: [IC] GMK CYL Flare | China Vendor Announced
« Reply #50 on: Mon, 17 March 2025, 12:08:57 »
KBDfans will be the China vendor for GMK CYL Flare!
I remember reading that Max had to do several rounds to get Hi Viz! as bright as it came out, I suspect that it'll be the same way for you.
It most likely will be the same but hopefully it will be less rounds than Max's Hi Viz!
Get the plastic chip
Only if it existed on RAL's list of all RAL 2005 color products.
Offline mr_foggy
  • neue = nope
« Reply #51 on: Wed, 19 March 2025, 13:03:35 »
btw excellent work with the kitting and that 6u in base
Offline Kiririn
« Reply #52 on: Fri, 21 March 2025, 16:07:29 »
Thanks for the support foggy! I'd say kitting is finally locked in and just waiting on my approval of the GMK samples before I set a GB date. Last thing I want is a delay during the GB phase.
Offline Kiririn
« Reply #53 on: Mon, 31 March 2025, 13:11:06 »
GMK got back to me and said the material isn't as lightfast and any lighter will show the black doubleshot underneath. The existing samples will be what we will run with and I'll be figuring out a GB time frame with the vendors.
Offline IOVERCALLHISTIOCYTES
« Reply #54 on: Mon, 31 March 2025, 16:02:30 »
I’m good with it. Can we get a fluorescent lighting and bright sun picture?
Figure direct sunlight and it’s closer to your color standard. Suppose hi light might have similar issues.
Offline Punkypj
« Reply #55 on: Mon, 31 March 2025, 16:33:28 »
I have to say, the sample key doesn’t really look much like the renders in terms of luminance which is disappointing
Offline Kiririn
« Reply #56 on: Mon, 31 March 2025, 16:42:20 »
The sample key was taken in a cloudy overcast. I appreciate the comment but unfortunately it is nearly impossible to photograph neon/fluorescent colors. A camera is shooting in RGB and is using a limited version of that since it can only capture so many colors within those pixels regardless of how many megapixels a camera has. A camera can't see as many colors as our eyes can.
Even if a camera that saves wide gamut or alternative palette files is used, it would not help either since we view the images on more limited sRGB monitors.
Luckily the sun finally came out before the rain started for the rest of the week.
« Last Edit: Mon, 31 March 2025, 20:50:42 by Kiririn »
« Reply #57 on: Mon, 31 March 2025, 21:13:42 »
Maybe a comparison to gmk stock colors like v1 or ro2 red or the accent red of GMK Red Dragon would help. Just has to be neon next to those or at least match the vibrancy of red dragon accent, which is another color I’d be fine with for something named Flare.
Offline Kiririn
« Reply #58 on: Tue, 01 April 2025, 12:39:22 »
Issue is that cameras still have limitations on capturing neon colors on top of having it viewed on a screen. Though V1 turned out to become redder than the RAL 2005 sample.
« Last Edit: Thu, 03 April 2025, 23:41:28 by Kiririn »
Offline bigmaxnonions
« Reply #59 on: Tue, 01 April 2025, 13:50:29 »
when i first saw the samples, i thought the color looked waaaay off to what the renders showed, thank you for the direct comparisons, the color actually looks much more accurate than i previously thought.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #60 on: Tue, 01 April 2025, 14:29:46 »
Great comparison photo!
« Reply #61 on: Tue, 01 April 2025, 18:51:22 »
Yeah this is bright as hell
Offline Punkypj
« Reply #62 on: Wed, 02 April 2025, 02:18:27 »
Yeh the comparison makes it look much brighter  :thumb:
Will there be a international kit?
Offline Kiririn
« Reply #63 on: Thu, 03 April 2025, 15:09:30 »
Yeah I'm guessing by itself, the camera didn't know how to manage the brightness so it toned it down. I knew it was going to be really hard to take a photo of it but it turns out to be impossible unless there is a ton of post-processing.
Thanks dvorcol! It was a major pain in the butt to get the photo though.
Yep it is pretty bright once put in sunlight. Though if it was to be any brighter/lighter, I would need to swap the legends over to a metallic silver from the original black. GMK tried to make it brighter but resulted in the black doubleshot being visible underneath.
Unfortunately I really don't think an international kit would hit the 100 MOQ. I also want to minimize the risk of the neon/fluorescent color degrading in storage over time as it will be placed in open trays instead of an enclosed box.
Offline Kiririn
« Reply #64 on: Thu, 03 April 2025, 15:33:32 »
Latrialum has been added to the collabs list!
Offline Kiririn
Re: [IC] GMK CYL Flare | Tentative GB Date Announced
« Reply #65 on: Sat, 05 April 2025, 12:28:43 »
The tentative GB date for this set has been set for May 12, 2025 - June 15, 2025.
Due to Trump's nonsensical "tariffs", I am given 3 options. Keep the GB date and take a wait and see approach if the tariffs are lowered before the GB date, the price increases for people located in the US, or delay it until this ends.
I'll be keeping the dates for now but be prepared for delays.
« Reply #66 on: Sat, 05 April 2025, 16:31:42 »
We live in interesting times. I’ll buy when it runs.
Offline AMZ
« Reply #67 on: Fri, 11 April 2025, 16:29:48 »
Who will be the main vendor?
Offline Kiririn
« Reply #68 on: Fri, 11 April 2025, 18:42:49 »
Mekibo is the lead vendor for the set. I will always put the lead vendor at the top of the vendor list.
Offline Kiririn
Re: [IC] GMK CYL Flare | US Pricing Update
« Reply #69 on: Thu, 17 April 2025, 14:45:02 »
US pricing has been updated to $150 USD due to tariffs and the USD devaluation. Will be watching how current GMK GBs are performing to determine if we will go through with the GB.
Offline Kiririn
Re: [IC] GMK CYL Flare | GB Date Finalized
« Reply #70 on: Mon, 05 May 2025, 15:16:39 »
GB date has been officially set for May 12 - June 16. GMK has shipped out R2 of samples but will have to see how they turned out when they arrive tomorrow. It is going to be raining all week for me so I'll be having to pray that there is a break in the rain and the sun comes out to confirm which one I'm going to be using.
Offline Kiririn
Re: [IC] GMK CYL Flare | R2 Samples Update
« Reply #71 on: Wed, 07 May 2025, 11:16:16 »
R2 samples came in yesterday and luckily the rain got blown northward so it's sunny!
Verdict is that R2 is brighter and doesn't have the R1 grayed look in artificial light. Under sunlight, R1 is only slightly darker than the R2 samples and I am happy with how the R2 samples came out.
"2" column are the R1 samples while the "B" column are the R2 samples.
Left 2 keycaps are R1 while right 2 keycaps are R2.
"Esc" column are the R1 samples while the "GMK" column are the R2 samples. [Artificial light]
Offline Kiririn
Re: [IC] GMK CYL Flare | GB LIVE!
« Reply #72 on: Mon, 12 May 2025, 11:33:42 »
GB is now live!
GB Thread
« Last Edit: Fri, 23 May 2025, 13:44:50 by Kiririn »
Offline macbrush
« Reply #73 on: Fri, 23 May 2025, 03:59:36 »
I will support any sets that include 6U in the base kit, ALWAYS!
