Author Topic: [IC] Finn 60XT | GB February 25th, 2026 - March 30th, 2026  (Read 9776 times)
Offline baucts
« on: Tue, 04 February 2025, 17:17:02 »
GB has been confirmed! Official GB topic will be posted by ClickClack, the GB Lead.
IC Form
Intro
Hello everyone, Baucts here. I started designing Finn about 8 months ago. Initially I wanted to make it as a one off but figured it wouldn't hurt to try to run it. This will be my first project, a 60% gasket mount keyboard with symmetrical XT columns. Inspiration comes from Singa’s Kohaku and Ori-Club boards. The name comes from Finn from Adventure Time. There are really no design correlations between this board and the character from the show, Adventure Time is just my favorite cartoon.
Prototype Images
Updates
- 2/10/2025: Prototype case, gaskets, and PCB have been ordered
- 3/5/2025: Prototype pcb and gaskets received
- 3/7/2025: Added prototype images, more will be added
- 4/3/2025: Added final prototype case images before shipping
- 4/14/2025: Added image of built proto 1
- 5/4/2025: Updated ekh
- 5/17/2025: Polycarbonate will be offered
- 5/25/2025: Added more prototype images
- 6/24/2025: Ordered second prototype, 1 full polycarbonate and 1 orange and grey aluminum
- 2/9/2026: Added vendors, final colorways, plate options, updateded renders. GB planned to start Feb 25, 2026
- 2/11/2026: Forgot to add the vendors, updated now
Vendors
NA: ClickClack
EU/UK: Prototypist
SEA: ktechs
CN: ktechs
CA: Mino Keys
AUS: SwitchKeys
Renders
noir
cobalt
ivy
eclipse
grape
blur
Features and Specs
-Polycarbonate or aluminum case
-Silicone gaskets (20A & 50A)
-Internal acoustic tuning
-QMK/VIA compatibility
-RGB under glow & indicator LED
-Friction fit feet
-Aluminum 6063 case
-351.66mm x 113.5mm
-7.5 degree typing angle
-Internal weight
-23.77mm EKH
-19.03mm front height
-1.4g aluminum unbuilt w/ brass internal weight
-WK & WKL
-Aluminum, polycarbonate, or polypropylene plate
-$420 @ 50 MOQ
Layout, Hotswap
Keep up to date on this and other projects
Discord server
Instagram
Twitter/X
My website with infomation
Thanks to Keyboard Atelier discord server. Specifically chill, ellie, & letmegobacktosleep for firmware help.
« Last Edit: Thu, 23 July 2026, 10:54:01 by baucts »
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
Re: [IC] Finn, Gasket 60XT
« Reply #1 on: Tue, 04 February 2025, 17:38:03 »
reserved
Offline DorthaWalter
« Reply #2 on: Wed, 05 February 2025, 02:00:05 »
It's so interesting
Raft Wars
« Last Edit: Wed, 05 February 2025, 19:11:35 by DorthaWalter »
Offline warhopper
« Reply #3 on: Wed, 05 February 2025, 09:45:23 »
I really like the rough outline you have, the side profiles are really striking on the renders. Do you have an idea of what materials for the bottom you are going to offer? I notice a PC bottom in one of the renders and that would be a really cool option to have in the final product.
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #4 on: Wed, 05 February 2025, 14:15:01 »
Absolutely LOVE the layout and the side profile is super unique. Only thing I’d advise is ditching the long feet and opting for bumpons instead. Much cleaner and less risk of it sounding “thuddy” GLWIC!
Offline baucts
« Reply #5 on: Wed, 05 February 2025, 20:59:47 »
Thank you. For the bottom case, the standard will be black anodized aluminum. I still provided some renders of the bottom in polycarbonate because the pcb will have under glow which will be able to shine through the back, side, and the little gaps in the front.
Offline baucts
« Reply #6 on: Wed, 05 February 2025, 21:03:35 »
Thank for the feedback, i am still debating on whether i should use the custom long feet or bumpons. with the custom feet I do think that is looks cleaner since the entire design language is "smooth". When I get a proto from the manu ill be able to test the long feet vs bumpons and will report on my findings, thank for letting me know about this  :thumb:
Offline baucts
Re: [IC] Finn, Gasket 60XT | Prototype Ordered
« Reply #7 on: Tue, 11 February 2025, 02:58:55 »
UPDATES:
3/7/2015: Added prototype images, more will be added
5/4/2025: updated ekh
« Last Edit: Tue, 24 June 2025, 00:59:51 by baucts »
Offline nathanchere
« Reply #8 on: Mon, 17 February 2025, 03:41:56 »
Please consider split space bar support :D
Offline baucts
« Reply #9 on: Mon, 17 February 2025, 07:30:19 »
You got it :thumb:
    • Twitchy Homepage
Re: [IC] Finn 60XT | Final Prototype Images Added
« Reply #10 on: Fri, 18 April 2025, 19:18:00 »
consider WKL top option
Offline bluntkrayon
« Reply #11 on: Sat, 19 April 2025, 01:57:05 »
This is an amazing layout. Any chance of a cherry lip? GLWIC!
Offline baucts
« Reply #12 on: Sat, 19 April 2025, 22:36:12 »
probably wont add a cherry lip. i experimented with adding it and since the sides are curved from the top profile it doesnt fit as well
