Author Topic: Wanting some feedback on my project  (Read 21388 times)
Offline Spectre72
« on: Thu, 06 February 2025, 15:36:57 »
Hi, I suppose to preface this I'm very new to the world of keyboards, pretty much only got into them  (Actually I still haven't even bought a proper enthusiast board yet)
I'm currently in the process of designing a simple but hopefully good looking keyboard,
Keybard Layout is F12 TKL
Typing angle is 7.5 degrees with a front height of 18.5mm
Plate is Tadpole mount, planning on it to be PP, no flex cuts [Mostly cause I don't quite know how to do that properly yet]
Top and bottom are held together with magnets, as well as the weight currently though I might change that to being screw in
Haven't decided on if I should do silicone dots as feet or full length bars
it's not designed to take a daughter board however that may change, I'm fairly happy with the USB-C placement but I don't know if daughterboard + center USB placement would be better
I'd love to get some input from some other people on things I could try, add or adjust.
[ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ] [ Specified attachment is not available ]
Offline Spectre72
Re: Wanting some feedback on my project
« Reply #1 on: Fri, 07 February 2025, 23:25:11 »
Update : Board model is fairly close to completion due to help from some more experienced individuals
Major changes :
Weight is now affixed with screws
There are now 2 designs, one that takes Hiney PCBs and one that will take the Geon Daughterboard
Certain Geometries are now simplified for ease of manufacturability
If anyone has any feedback, comments or concerns, do let me know. so far people have been very helpful in my learning process
312189-0
312191-1
312193-2
312195-3
312197-4
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Sun, 09 February 2025, 09:46:06 »
Looks good OP! Nice & simple TKL, I can definitely get behind that!
Offline Spectre72
« Reply #3 on: Tue, 18 February 2025, 00:08:35 »
Went through 2 more redesigns as I wasn't entirely happy with how it looked, Figured if I'm gonna spend 350-400 bucks or so on a custom potentially one off board might as well make it something I love.
Weight is still plain without any engraving, still not sure if I want one or how one should look so for now it's blank.
312386-0
312388-1
312390-2
312392-3
Offline Leslieann
« Reply #4 on: Tue, 18 February 2025, 04:57:52 »
Looks good and not be a downer...
Are you making this yourself at work or having a friend do it?
I ask because your expectation of $350-400 is extremely low. If you're in the US and paying a shop this is probably closer to 3x that (or more), and you probably will not get it right the first, or possibly even the second time. And then you still need finish. The reason group buys get this price is because they already went through prototyping (you hope) and they're ordering in bulk, one-offs always cost a whole lot more.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Spectre72
« Reply #5 on: Tue, 18 February 2025, 09:42:22 »
Hey no worries at all.
Currently the price I listed is Just the case. Not even including the plate, PCB switches etc
The overall build with keycaps and plate comes out to like 870 [CAD] ish not including a PCB either
The quotes I got were from JLC's CNC service board cost coming out to about 380 [CAD] per case pre shipping an taxes which does include sandblast and anodization and a mirror finish on copper weight.
I'm hoping to get it right the first time but I will have some cheaper printed prototypes does soon for fitment and testing.
Offline Jasonnnsen
« Reply #6 on: Thu, 20 March 2025, 10:29:33 »
OHHHHH!The quality of oh JLC is very worrying. In China, many players do not even know how to use the JLC platform to make their own keyboard cases. The vast majority only use JLC for structural verification.
