Author Topic: [IC] Apostle: 65% designedbydark GB FORM LIVE  (Read 9540 times)
Offline Lil
    • designedbydark
« on: Fri, 21 March 2025, 01:39:55 »
APOSTLE
* L1001643-Enhanced-NR.jpg (145.69 kB - downloaded 179 times.)
312793-1
Typing test:
GB form: https://forms.gle/dTwprz5EAQFKAyc79
Link to Discord: https://discord.gg/4Cf5FTpFfu
Design and intentions:
    • Balanced, proportional and subdued aesthetic, with dramatic reveal from behind
    • Unique weight design. My first 65% keyboard design!
    • Makes use of [larger] M4 screws for case fastening, tastefully embraces the aesthetic of larger bezels
    • Case walls are not too thin
Pricing and sale information:
    • Expected pricing 650USD before shipping
    • Will involve participants paying the manufacturer (DDS) directly via Alibaba
Lead time:
    • Within 3-6 months of paying the manufacturer (DDS/DADESIN)
    • Will ship directly from the manufacturer
Specs:
    • 65% layout keyboard, ‘seamless’ topcase configuration
    • Approx weight: 1.75kg when built
    • 7 degree typing angle
    • Very low ‘front height’/ relative profile on the desk
    • Plate uses bumpon/spring mount designedbydark
    • Giger-esque weight design
    • MX only, 7U only, ANSI only plate
Changes between prototype v1 and v2:
    • Screwing weights together to reduce unwanted vibrations between them and remove any need for ‘forcebreak’ between weights
Included in the kit:
    • Topcase: 6063 ALU [anodised]
    • Bottomcase: 6063 ALU [anodised]
    • Plate: Steel [Sandblasted + Coated]
    • Weight 1: Copper [Sandblasted + Coated])
    • Weight 2: Copper [Sandblasted + Coated])
    • 3M bumpons: 6.4mm - SJ5382
    • M4 case screws
    • M3 weight screws
Not included:
    • PCB
    • Daughterboard
Compatible with:
    • fly daughterboard
    • WT65 PCB
Vote in the IC:
    • On anodisation colours
    • On whether to remove the cut that reveals the bottomcase at the front of the topcase
    • On preference between Brass/Copper/Steel weights (only one option will be selected)
    • On whether to run the sale via FCFS, raffle or a mix of both
Please let me know what you think!
More photos:
* L1001642-Enhanced-NR.jpg (158.46 kB - downloaded 148 times.)* L1001644-Enhanced-NR.jpg (142.27 kB - downloaded 125 times.)* L1001645-Enhanced-NR.jpg (125.4 kB - downloaded 130 times.)
312787-5312789-6312791-7
Space for updates:
  • 21st of March 2025: Posted IC
« Last Edit: Sat, 19 April 2025, 08:48:26 by Lil »
Offline DirtyGingy
Re: [IC] Apostle: Giger-esque 65% keyboard with leafspring-bumpon mount
« Reply #1 on: Fri, 21 March 2025, 02:29:41 »
That's a lot of places for crumbs and dust to hide
Offline Lil
    • designedbydark
« Reply #2 on: Sat, 22 March 2025, 09:26:11 »
Hopefully it'll be okay as long as you don't turn it upside down and eat over it  ;)
Offline FatefulStranger
« Reply #3 on: Mon, 24 March 2025, 01:16:42 »
Personally love the wild design!  :thumb:
Hoping to see Gondo make a PCB for this beast
Offline Scrubz
  • Don't eat the lube even if it looks tasty
    • Whiplash!
« Reply #4 on: Thu, 27 March 2025, 14:42:41 »
I also personally like the aesthetic, can we perhaps get a better look at the weight and internals? GLWIC
Offline Lil
    • designedbydark
« Reply #5 on: Sat, 29 March 2025, 14:32:42 »
Thank you! We will have to see if he will  :cool:
I'm glad to hear it! Sure, here's a few pictures of the internals (a few of the screw holes needed to be re-tapped for the prototype after some changes but they will be anodised for the GB):
312880-0312882-1312884-2
« Last Edit: Sat, 29 March 2025, 15:05:14 by Lil »
Offline JackQn
« Reply #6 on: Fri, 04 April 2025, 02:10:17 »
Like the overall design. I just worry if it will lift if I press too hard on the ESC button. ?_?
Offline Lil
    • designedbydark
« Reply #7 on: Fri, 18 April 2025, 11:42:18 »
No I don't think so
Offline Lil
    • designedbydark
« Reply #8 on: Sat, 19 April 2025, 08:47:25 »
I'm getting an error each time I try to make a GB post, so i'll link the GB form here:
Offline Metakeebs
    • metakeebs
Re: [IC] Apostle: 65% designedbydark GB FORM LIVE
« Reply #9 on: Wed, 07 May 2025, 08:58:26 »
Gorgeous :thumb:
