Author Topic: [IC] Parabolica60 - iNN Studio | GB Date Updated!  (Read 18180 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Wed, 26 March 2025, 15:32:24 »
Special Community Color Voting!
Parabolica60
by S!mple & iNN Studio
Post edited by Click Clack
Hello everyone, this project is brought to you by S!mple from iNN Studio.
Introducing the Parabolica 60, a 60% foamless three-piece keyboard with a large copper mid-frame, available in 6+ anode colors and 4 mid-frame and badge options.
The TOP and Silicon Tadpole-pin mounting styles with large copper/brass pieces provide a firm feel and solid sound, while the 16.5mm true front height and 7.5° typing angle make for a comfortable typing experience.
We have successfully hosted CN GB and received amazing feedback, and now we are ready to take it global.
Index
- Design
- Specifications and Layout
- Product Showcase
- What is included?
- Pricing and Vendors
- Follow the development
Specifications
Layout
-60% Layout
-ANSI/ISO
-WK/WKL/HHKB
-7U Spacebar ONLY
-Split 3-1-3 spacebar Compatible
-Split backspace and right Shift Compatible
Compatability for Solder & Hot-swap PCB
Mounting and Plate
-   TOP/Tadpole Gasket
(Sharing with same screw-in hole & Relief arms)
-   Aluminum or Carbon Plate
-   Non-Flex Cut ONLY
Typing Angle
•   7.5°
(*See Sideview)
Front Height
-Lowest point of lip:14 mm
-Without lip:16.5 mm
-EKH:21.5 mm
(*See Sideview)
Dimensions
Net Weight
-   1750g+ (Assembled)
Material and Process
-   Top Case:
o   6063 Aluminum Alloy – Anodized
-   Middle Case:
o   Brass – With Nano anti-oxidation Coating or Color Spray Coating
o   Copper—With Nano anti-oxidation Coating
-   Bottom Case:
-   Badge:
o   Copper – With Nano anti-oxidation Coating
o   Stainless Steel – Blasted PVD (*Not Mirror)
PCB
-   1.6mm Non-Flex Cut ONLY
-   Hot-Swap/Soldered Compatible
-   Black varnish surface with iNN Orange UVed logos
-   With unified C series DB & JST connect cables
Connect Mode and Firmware
-   Wired ONLY
-   QMK/VIAL
Product Showcase
Color options for Top Case & Bottom Case (Anodized & in the same color:
Anodized Retro Greige:
Anodized Dusk Titanium:
Anodized iNN Orange:
Anodized Black:
Anodized Dark Violet:
Anodized Lavendar:
Color options for Middle Case:
Brass – With Nano Anti-oxidation Coating
Copper -- With Nano Anti-oxidation Coating
Brass – Spray Coated in Black
Brass – Spray Coated in Color of Community Vote
(*Shiny White Coating in the picture is exclusive for CN GB’s Community Color)
Color options for Badge:
-   Brass - With Nano anti-oxidation Coating
-   Copper - With Nano anti-oxidation Coating
-   Brass - Spray Coated in Black
-   Brass – Spray Coated in Color of Community vote
-   Stainless Steel – Silver Blasted PVD
The Fix Color Kit:
The Color from the community:
You can submit your own color palette and a winner will be voted and adopted as a fixed color option:
-   Top Case & Bottom Case in the same anodized color of your choice
-   Mid frame & Badge in the same spray coated color of your choice
-   All colors should be selected from Pantone C card
The event will be host in iNN Studio Discord channel soon
Join the iNN Studio Discord: https://discord.gg/hMkGUAZhSe
Special Community Colorway Voting can be done here: https://forms.gle/oLz9YMbbbcQzfN5F7
More Photos:
What is included?
Parts included in the Default kit:
Can be upgraded:
1× Anodized Aluminum Top Case of your color choice
1× Anodized Aluminum Bottom Case of your color choice
1× Brass With Nano anti-oxidation Coating Badge
Default:
1× Aluminum/ Carbon Fiber Full Plate
1× 1.6mm PCB with black varnish surface with iNN Orange UVed logos
1× Unified C Series DB & JST connect cables
20× Silicone Tadpolepins 50A & 70A (10 Each)
8× Silicone feets
1× PET bottom pads
1× iNN Studio exclusive keeb case
1× iNN Studio exclusive velvet keeb bag
1× Parabolica PVC souvenir card & Post
1 x Brass With Nano anti-oxidation Coating Mid-frame
All Screws and Packging
Pricing and Vendors
Group Buy Details
Time:15,05,2025 - 15,06,2025
Form:Open GB in Limited Time Window
Pricing:
-Default Kitting 320$
-Middle Case
UPGRADE TO Copper +35$
UPGRADE TO COLOR SPRAY COATED +7$
-Badge
UPGRADE TO Copper FOR FREE
UPGRADE TO Stainless Steel +10$
UPGRADE TO COLOR SPRAY COATED +3$
-PCB
UPGRADE TO Hot-Swap +5$
Vendors:
- The USA and Rest of the world: Click Clack
- United Kingdom: ProtoTypist
- Europe: EloquentKeys
- Oceania: Toro Studio
- Canada: Unikeys
- South Korea: Geon Works
- SEA: iLumKB
- Vietnam: NuxrosKB
More will be updated.
Join ClickClack’s Discord for the latest updates, discussions, and questions:
Fill in Interest Check Form:
Follow ClickClack's IG for other new projects:
« Last Edit: Thu, 24 April 2025, 16:27:12 by ClickClack.io »
Offline ivanh98
Re: [IC] Parabolica60 - iNN Studio
« Reply #1 on: Wed, 26 March 2025, 16:16:31 »
very interesting. glwic
Offline Natetypesfast
« Reply #2 on: Thu, 27 March 2025, 09:28:31 »
This looks great, not bad for $320 glwic
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #3 on: Thu, 27 March 2025, 11:51:17 »
Super pumped for this one! Submitted a color combo as well! Cannot wait to see what the community picks. GLWIC!
Offline Zahul
« Reply #4 on: Thu, 27 March 2025, 12:59:57 »
Looks great, would like to see some renders of the bottom. Also the discord link is broken in the original IC.
Offline Raie_de_Boule
« Reply #5 on: Thu, 27 March 2025, 14:05:32 »
That looks really sexy.
    • clickclack.io
Re: [IC] Parabolica60 - iNN Studio | GB Date Pushed Behind ~2 Weeks
« Reply #6 on: Thu, 24 April 2025, 16:26:23 »
Hey everyone! Due to some QC updates specifically for the China exclusive "Skypink" colorway, the studio needs more time to tackle this issue, pushing the schedule 2 weeks behind. Thank you for understanding!
Re: [IC] Parabolica60 - iNN Studio | GB Date Updated!
« Reply #7 on: Sun, 01 June 2025, 20:23:48 »
What color code is the Dusk Titanium Color?
Offline EmmaAlva
    • tiny fishing
« Reply #8 on: Tue, 22 July 2025, 08:00:08 »
This is impressive, especially for $320 glwic.
tiny fishing
Offline CEGeek
« Reply #9 on: Thu, 31 July 2025, 00:47:39 »
Purple looks good
