Author Topic: 65% but with space above arrow cluster  (Read 4670 times)
Offline phinix
« on: Fri, 04 April 2025, 03:57:17 »
I saw a keeb like that in the past, but what is now available - 65% but a space (one cap gap) above arrow cluster, then 3 caps above.
I know there are many full caps above, or 2 caps above, but I need 3 - I must have Del, Home and End from navi cluster.
Is there one like that?
I want to try 65% but arrows and those 3 caps are a must for me, dont like layers.
Offline Leslieann
Re: 65% but with space above arrow cluster
« Reply #1 on: Fri, 04 April 2025, 05:36:46 »
I was looking for similar but here's what I ended up doing, it sounds like a lot but it's really not that bad (I too hate layers).
I'm using an NK65 with no space, meaning 4 keys directly above the arrows, but I remapped it similar to what you're looking for (with no layers needed). From the top I have backspace, then home, end, end, rt arrow. Yes two end keys, basically regardless of which lower key I hit it's always an end key. I initially set the center key on far right as a mod key but it just drove me nuts.  As for the caps, well they don't really match because very few sets support this layout but I did get close enough for me, they go DEL, pgup, pgdn, end, rt arrow. So while not perfect it gives some indication that's similar to what they are, sort of.
Another thing that did mess with me a bit was the lack of space or division along the bottom row, it took me quite a while to get consistent with the left arrow. I would have preferred a gap there and just remap the rt alt into a mod key, which I was ready to do just before I finally started getting more consistent with the lt arrow so I just left it. The plan was remap FN to the rt alt, remap FN to CTL and then put a block off cover over the original RT ctrl. Like I said, by the time I got around to it I was more or less adjusted so I left it as it was.
As for actual page up/dn, I did remap those into a mod layer but only because I have one game that needs one of them on occasion but it's just one old game that uses it, otherwise, I never use them.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline phinix
« Reply #2 on: Fri, 04 April 2025, 09:33:53 »
OMG, I feel your pain :)
Sounds like too much for me. I used 65% before without gaps and it flipped my OCD so hard I felt panic.
Thing is, I need that space around arrows cluster, mentally I need, phisically my fingers seek that gap when I move my hand to the right, fingers need to find it, otherwise I get a glitch in my brain, electric short, my face goes bbzzzzzzz and I pee my pants a little.
So yeah, I need a space around arrows :)
Sounds like I'm doomed, TKL for life.
Or those FRL, but they waiting for one for up to £150 max and plastic.
