Author Topic: 【IC】Class 65V3---Retro 65+Macro with Solenoid and Buzzer  (Read 14756 times)
Offline Totoro
Hi everyone, and this is MM Studio.
Class65 was the first GB we finished which really means a lot to us. And today we are bringing u 2 different type of Class65 V3, and hoping u like our design!
Renders:
Brass Reforged Version:
When redesigning the Class65, we considered radically altering its original aesthetic—introducing complex design languages or flashy color schemes. Yet lastly, we chose to stay true to its timeless retro essence.
Inspired by vintage keyboards’ pen rests, we utilized the Class series’ signature wide bezel and raised top case to integrate a solid brass pen rest as a functional accent. A matching brass trim was added along the rear edge to enrich visual depth from all angles while subtly increasing the keyboard’s heft.
Classic Version:
The Classic version retains the iconic plain bezel design of the Class65 V1 and V2. Eschewing decorative elements, it features only the signature solid-color wide frame - letting the front panel elevate any desktop set.
Most importantly, both version now support solenoid and buzzers!
Color and version options:
Retro coating white (Refer to gmk L9), Retro coating green, Retro coating red, Ano Silver, PC(PC no protos yet)
(Classic version, Wrist rest, Brass reforged version in renders)
Wrist Rest: Alu case with walnut panel. Though it's designed for class65 but we find it suits most TKL boards
PCB and plate:
1.6mm wired qmk-Vial, PC pad-isolating TOP mount / PCB gasket mount(plateless supported)
Solenoid and Buzzer supporting
Solder:
Hotswap:
Plate:
Copper, Brass, PP, Alu (PP plate will not have any cuts unlike the render)
IRL color reference pics:
Specifications:
Keyboard Size:(Pics below)
Weight:Classic version built ~2.7kg, Brass Reforged version built ~3.1kg, Wrist rest ~0.85kg
Typing Angle: 7°
Mounting method:Top/Gasket (Plateless supported)
PCB:Wired QMK-VIAL
Case material: 6063 Aluminum
Weight material : Brass with antioxidant treatment
Details:
Classic Version Keyboard Kit Price:~250$
Brass Reforged Version Keyboard Kit Price:~280$
Wrist Rest: ~60$
GB Date:  Est in late Apr
« Last Edit: Mon, 07 April 2025, 22:10:26 by Totoro »
Offline KeebDweeb_
    • KeebDweeb
Re: 【IC】Class 65V3---Retro 65+Macro with Solenoid and Buzzer
« Reply #1 on: Mon, 07 April 2025, 12:59:13 »
In for one!! Will go great with my class 80 and 0413.
« Reply #2 on: Mon, 07 April 2025, 13:05:25 »
FINALLY
Offline jonarnt
« Reply #3 on: Mon, 07 April 2025, 13:06:45 »
How about an EC version? Love my EC Class 60.
Offline deductivemonkee
  • Professional Lurker
« Reply #4 on: Mon, 07 April 2025, 13:22:59 »
I dig it. I'd love a HHKB bottom row (left side) but I won't call it a dealbreaker to not have.
Sent from my SM-S911W using Tapatalk
oh yeah I saw that crazy **** if that doesn't win I'm deleting my account
Offline rrdaud
« Reply #5 on: Mon, 07 April 2025, 13:27:42 »
This looks gorgeous! Not sure if I like the brass or the classic version better. BTW what keycaps are those on the first render?
Offline pixelpusher
« Reply #6 on: Mon, 07 April 2025, 15:27:43 »
I own a Class80 and Class60. Love both cases.  I’m looking forward to picking up a 65 now as well.  I prefer the classic design shown here.
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #7 on: Tue, 08 April 2025, 04:01:50 »
This thing is gorgeous!! Is there a reason no 7U for Hotswap but everything else is the same as the solder pcb? If there was a way to get 7U on Hotswap I’m 100% in!
Offline Totoro
« Reply #8 on: Fri, 11 April 2025, 22:14:10 »
We already considering adding 7u support on hotswap pcb in GB
Offline FoxandFoundry
« Reply #9 on: Sun, 13 April 2025, 12:49:43 »
It looks great! I do have one quick question: could you let us know what the front height is? I don't usually use wrist rests, so I just want to make sure if I would be OK without one.
« Last Edit: Tue, 15 April 2025, 12:50:54 by FoxandFoundry »
  • Gacha Done Got Me
    • IG
« Reply #10 on: Tue, 15 April 2025, 01:05:58 »
Excellent! Bc this thing is great fr.
Offline Totoro
« Reply #11 on: Thu, 17 April 2025, 00:54:58 »
19.5mm, almost the same as v1 and v2, u can check from the size pics in the last para of the post.
« Reply #12 on: Thu, 17 April 2025, 18:15:30 »
Great, thank you!
Offline gleneston
« Reply #13 on: Fri, 18 April 2025, 15:08:04 »
Glad there’s going to be a round 3 of this board. I own 2 round one boards, not a fan of the flex cut PCBs from the first round. Will the round 3 pcb and plates work with round one boards?
Offline VaporKeebs
« Reply #14 on: Fri, 18 April 2025, 19:21:49 »
Super excited for this GB. I'm a huge fan the v1. I picked it up second hand so I'll be happy to grab one brand new finally. I think I want to go with the exact color but upgrade to the pen rest version.
Offline B4zookaw
« Reply #15 on: Sat, 19 April 2025, 03:41:19 »
Any EU vendors planned or will this just sell direct from MM?
