Author Topic: [IC] GMK Shaded - GB AUGUST 1st! - A simple BoG/GoB keyset with Modi addons  (Read 13326 times)
Offline Chippy
  • sus chef
GMK Shaded
A simple BoG/GoB GMK keyset with optional Modi addons.
GMK Shaded will enter group buy on August 1st! All kits will run!
Kits
• Base - $129
• Ext - $45
• Modi - $70
Vendors
• USA - CannonKeys
• KR - GEON
• CN - KBDFans
• OC - Daily Clack
• UK - ProtoTypist
• EU - KEYGEM
• SEA - iLumkb
• CA - DeskHero
Background
For years I have wanted a Black on Gray/Gray on Black GMK set with text + icon legends and a colored mod addon kit. It's honestly that simple. 2+ years of dwelling and a couple DM threads with some awesome people in the community later and here I am. Modi is coming back to GMK in two different colorways, and I finally get my dream set into IC.
Colors
• Black - CR
• Gray - N9
• Magenta - MG1
• Orange - V2
• Purple - DY
• Green - N7
• Red - RO2
• Yellow - N6
• Blue - N5
Interest Check
I'm putting this above the kitting because it's that important. As much as I would love both of these colorways into GB at the same time, I don't know if there is enough demand for both. My friends and co workers are split- so I need your help. If you are interested in this set, please consider filling out the IC to help me decide what the best path is.
Kitting
Gray on Black Base
Gray on Black Extensions
Black Modi
Black on Gray Base
Black on Gray Extensions
Gray Modi
Keyboard Renders
GMK Shaded with and without Modi mods rendered on a Brutal V2 65%.
Deskmat & Artisan Collabs
I ran out of all creative juice trying to choose which shade of black and gray, cut me some slack. This set will highly likely not run with any collabs as the main goal is to keep it simple and get this run.
Vendors
• USA - CannonKeys
• KR - GEON
• CN - KBDFans
• OC - Daily Clack
• UK - ProtoTypist
• EU - KEYGEM
• SEA - iLumkb
• CA - DeskHero
Closing Words
Thank you for reading this IC. Please let me know if you have any questions/feedback either by replying in this thread or (preferably) in the IC Form.
Thank You
• superdoedoe for being a good lad and responding to my DMs over the last couple of years (look, I finally did it)
• Upas and Ana from CannonKeys for the help with kitting and general feedback
• DC for being down to give Modi another go
• The 40s community who will surely read the IC fully and fill out the form before commenting asking where the 40s support is in the Modi addon kit
• Liv for the sweet renders
• Friends & coworkers who finally pushed me to get this into IC
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=125089.0][img width=316 height=120]https://i.imgur.com/WRI9Qs7.png[/img][/url]
« Last Edit: Wed, 02 July 2025, 14:27:04 by Chippy »
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline Chippy
  • sus chef
Re: [IC] GMK Shaded - A simple BoG/GoB keyset with Modi addons
« Reply #1 on: Wed, 23 April 2025, 11:32:05 »
Render/Kitting Archive
Initial Kitting [OLD]
Gray on Black Base
Black Modi
Black on Gray Base
Gray Modi
Initial Keyboard Renders [OLD]
Kitting Changelog
First Revision
  • Darkened renders across the board to try and be more realistic
  • Change nav legends to be classic (ie: front print on Prt Sc and Pause)
  • Fixed Pg Dn/Up to have space between legends
  • Windowed keys in extension kit will be smoke (semi-translucent CR)
  • Removed windowed stepped caps lock in Modi kit
  • Added doubleshot stepped caps lock
  • Added 2x 1.5u Supers to Modi kit
  • Added 2x 1u Alts to Modi kit (These were added in post after rendering. They will be properly rendered during the next iteration)
« Last Edit: Fri, 09 May 2025, 17:40:52 by Chippy »
Offline mr_foggy
  • neue = nope
« Reply #2 on: Wed, 23 April 2025, 11:35:29 »
very interested in both bases, BoG especially. already have the OG black modi
Offline rayy
  • aesthetics enthusiast. serving. 🇺🇸
« Reply #3 on: Wed, 23 April 2025, 11:54:42 »
Super hype for this to go into GB with the recent cancelletion of GMK Chromatic This is a fire rebound. :cool:
-the kid.
Offline IOVERCALLHISTIOCYTES
« Reply #4 on: Wed, 23 April 2025, 11:57:19 »
Both colorways exist, gmk dark (CR on N9) and the rare gmk exent (N9 on CR). Isn’t a reason to not rerun.
N9 modi would be super fun
Offline whirlwind
« Reply #5 on: Wed, 23 April 2025, 12:30:32 »
Yes please
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #6 on: Wed, 23 April 2025, 12:30:49 »
I had always been interested in a GMK Dark re-run with classic modifiers, so this fills that need.
Filled out the IC form. Would suggest doing classic modifiers (Prt Sc / Sys Rq and Pause / Break) for the base, and also adding stepped Caps Lock in doubleshot form for the modi kits.
Offline Natetypesfast
« Reply #7 on: Wed, 23 April 2025, 12:47:34 »
Mods are hot
Offline roostrc0gburn
  • its just plastic
« Reply #8 on: Wed, 23 April 2025, 12:53:22 »
I like it.
Offline white_rabbit
« Reply #9 on: Wed, 23 April 2025, 12:54:59 »
BoG with Modi sign me up!
Offline Meepergon
« Reply #10 on: Wed, 23 April 2025, 13:34:59 »
big big fan of BoG. are Icon Mod child kits out of the question? I guess already having one set of mod kits per base is already pushing it, probably. regardless I'm in for at least one set of BoG.
Offline upas
« Reply #11 on: Wed, 23 April 2025, 14:28:08 »
Looking ace, I'm in  :thumb:
Offline superdoedoe
  • ( ͡° ͜ʖ ͡°)
« Reply #12 on: Wed, 23 April 2025, 17:15:55 »
 ;D
Offline konstantin
  • Formerly constexpr
« Reply #13 on: Wed, 23 April 2025, 17:25:54 »
I think the kitting is excellent. Good job. You may just want to consider adding a numpad R1 1u = key to the extension kits, and perhaps dropping the second R4 1u Fn (it seems unnecessary since there's already one in base). I would also prefer the stepped Caps Lock in extensions to be non-windowed.
That being said, I'm definitely interested in picking up both modifier kits for combining with other sets.
Offline Pontus
« Reply #14 on: Wed, 23 April 2025, 18:21:26 »
Loving the BOG & Modi combo  ;D GLWIC!
Offline kennnyshiwa
« Reply #15 on: Wed, 23 April 2025, 19:38:19 »
Ohhh this with the modi mods looks really good and subtle, I like it.
Offline mcmcmc
« Reply #16 on: Wed, 23 April 2025, 22:22:25 »
 :cool: :cool: :cool:
Offline Gemmmmmmmmmmmmmy
« Reply #17 on: Thu, 24 April 2025, 00:27:40 »
Nice and simple, I like this!
Life seems so much smaller
Swim to the moon
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #18 on: Thu, 24 April 2025, 04:57:25 »
in for modi
please add basic 40s to modi. and maybe icon modi?
« Last Edit: Thu, 24 April 2025, 09:01:42 by twitchytheinsideman »
Offline FlowShow
« Reply #19 on: Thu, 24 April 2025, 05:12:13 »
Love it! And icon mods would be great.
Offline ZavaZ86
« Reply #20 on: Thu, 24 April 2025, 05:55:26 »
Rush rush rush
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #21 on: Thu, 24 April 2025, 06:01:07 »
Damn ima be broke when this runs lmao. I need both sets for sure.
Offline keepoto
  • HHKB top for TKL pls
« Reply #22 on: Thu, 24 April 2025, 06:08:07 »
cool all this effort to make tariff-era costco mictlan
Offline Samvvell
  • 60% Enthusiast
« Reply #23 on: Thu, 24 April 2025, 08:44:26 »
IC filled, looks sick
Offline AMZ
« Reply #24 on: Thu, 24 April 2025, 09:57:15 »
Can't wait to join the GB!
Offline King4477
« Reply #25 on: Thu, 24 April 2025, 11:24:15 »
In
Offline Chippy
  • sus chef
« Reply #26 on: Thu, 24 April 2025, 17:01:32 »
First off, thank you everyone for the immediate support and feedback on this set. I want to respond to some feedback and responses in the first day of the IC.
  • Requests for doubleshot stepped caps in Modi Kit - will likely replace the shinethrough cap with this.
  • Requests for OG modifiers - will take a look at these for the next iteration. There were a handful of people who specifically wanted OG nav keys, which I will be exploring.
  • Requests for icon mods - I'm sorry, but this set will be staying text + icon.
  • (Lack of) Requests for 40% Modi - VERY few people said they wanted 40s support in Modi. At this point I do not see it getting added.
  • Requests for 1.5u Supers - Will take a look and see, I want to be pretty lean here though. I see you though, and I am listening.
For those who left requests/feedback that I did not specifically mention above, I will still be looking over everything before the next version of kitting is finalized.
Thank you again for the feedback everyone, looking forward to reading even more :)
    • Twitchy Homepage
« Reply #27 on: Fri, 25 April 2025, 06:20:26 »
I would be really happy if you kept the windowed Caps Lock in the Modi.
Offline Chippy
  • sus chef
« Reply #28 on: Fri, 25 April 2025, 15:53:52 »
I aim to please. With 40s likely not making it into Modi, there might be room for both versions. Will have to take a look.
Offline skwrl
« Reply #29 on: Sun, 27 April 2025, 23:33:00 »
Sadge for no 40s support (edit: that I need). I'd snatch this up so quick if it had the shifts I need (2u and 1u).
« Last Edit: Sun, 27 April 2025, 23:36:07 by skwrl »
Offline extrapriusplease
    • All my links
« Reply #30 on: Mon, 28 April 2025, 12:01:45 »
Very sick! Love low contrast sets
Offline Cringelord
  • Crack Connoisseur
« Reply #31 on: Tue, 29 April 2025, 18:54:29 »
Gmk Dark rerun is cool, I'll buy both, and nice work on led keys. My concern is that GOB and Cosmos just ran within the last few years and if this will hit MOQ, not to mention all the other black sets like Mitclan and Tribal. Don't care for colored modis.
Offline patricklau
« Reply #32 on: Tue, 29 April 2025, 20:39:25 »
BoG with modi fosho  GLWIC  :thumb:
Offline Lanes
« Reply #33 on: Thu, 01 May 2025, 11:13:15 »
Thank God someone is doing this. I've been itching for a GoB set for ages.
Lanes
« Reply #34 on: Thu, 01 May 2025, 17:11:24 »
Ooooh I like this a lot, a tough choice picking between GoB or BoG
Swim to the moon
Offline SlothRock
« Reply #35 on: Thu, 08 May 2025, 13:53:34 »
I’m all on board for this!!
Offline neo.geo
« Reply #36 on: Fri, 09 May 2025, 01:28:08 »
In for both base sets
Offline NightFox99
« Reply #37 on: Fri, 09 May 2025, 04:30:08 »
Yes, please. Finally...
Offline Chippy
  • sus chef
« Reply #38 on: Fri, 09 May 2025, 16:15:43 »
Thank you again for all the feedback everyone! The first revision renders are live and updated in the OP. Here is a summary of what changed.
  • Added doubleshot stepped caps lock to Modi kit
Many vendors have reached out, so be on the lookout for a full vendor list next week. It's looking like this set will definitely run, and we're looking into a way to try and run both colorways at the same time given the even support we saw in the IC. Nothing is guaranteed at this point however.
Please continue to provide feedback where you see fit, however I want to mention two specific things that have received VERY little support, and will almost certainly will not make it in.
  • There will not be 40s support in the Modi kits
  • There will not be a Intl kit for this set, unless the EU/UK vendors specifically want to support it
« Last Edit: Fri, 09 May 2025, 17:49:30 by Chippy »
Offline Chippy
  • sus chef
Vendors have been confirmed for all regions!
  • US - CannonKeys
  • KR - GEON
  • CN - KBDFans
  • OC - DailyClack
  • UK - ProtoTypist
  • EU - KEYGEM
  • SEA - iLumkb
  • CA - DeskHero
Online ivanh98
any chance for a render on a 60%, to showcase a more complete use of modi?
Offline Chippy
  • sus chef
Definitely looking to add more renders as we get closer to the GB! Will keep this suggestion in mind.
Offline Raie_de_Boule
Interesting. Will check for a ESFR kit
(let me hope at least)
Offline EdgeOfInfinity
will try to grab both if i can.
glwic!
Offline NightFox99
Looks great, I'm in. (Hoping for ESFR kit too)
Offline diorite
Loving the grey on black for the fully murdered out look. The accent mods give it a totally different vibe which I also like. Awesome set!
Offline Chippy
  • sus chef
Vendors
• USA - CannonKeys
• KR - GEON
• CN - KBDFans
• OC - Daily Clack
• UK - ProtoTypist
• EU - KEYGEM
• SEA - iLumkb
• CA - DeskHero
