Author Topic: [Instock] HMX Cosmic Purple/Lunar Stone switches  (Read 9784 times)
Offline DashanYYY
    • Unikeys
« on: Tue, 20 May 2025, 23:11:00 »
313598-0
HMX Cosmic Purple and Lunar Stone Switches
313590-1
313592-2
[/size]
313594-3
313596-4
Finally, we have full POM housing HMX switches, and we made two of them! Please allow me to introduce you to HMX Cosmic Purple and Lunar Stone switches.
Price
Price:0.35USD/each
HMX Cosmic Purple Switch Specifications
Switch Type: Linear
Designer: Unikeys
Mold: New
Manufacturer: HMX
Stem material: LY
Top Housing: POM
Bottom Housing: POM
Operating Force: 45±2g
Bottom-out Force: 55±2g
Pre-travel: 2.0mm
Total Travel: 3.4±0.2mm
Spring: KOS single-stage extended
Factory Lubed: Yes! Stem legs and stem sliders are covered with a very thin coat of 205g0. The spring and leaf are lubed with dry film. Everything else is dry. There is no lube in the bottom housing or anywhere near the stem pole. The chance that these get lube pooling issue is very small.
HMX Lunar Stone Switch Specifications
Switch Type: Linear
Designer: Unikeys
Mold: New
Manufacturer: HMX
Stem material: POM
Top Housing: POM
Bottom Housing: POM
Pre-travel: 2.0mm
Total Travel: 3.6±0.2mm
Why full POM housing?
Although a lot of people love the clacky and high-pitched HMX sound profile, we do receive complaints from time to time saying the clacky sound is a bit dry. HMX switches with nylon housing and POM or LY stem do sound very loud, clean, and clacky, but due to the nature of the materials, they also tend to sound thin and flat. If you ask me what could add this rich and vibrant sound signature on top of HMX's classic clacky and loud sound, I will tell you it's the POM housing.
The difference between these two switches
The only three differences between Cosmic Purple and Lunar Stone are: Stem material, stem length, and colors.
The longer LY stem makes Cosmic Purple louder and clackier than Lunar Stone switches. The POM stem makes Lunar Stone switches sound a bit quieter and thockier, just like how most full POM switches are. However, that being said, don't expect Lunar Stone switch to sound deep and thocky. You know how HMX is.
Molding Changes:
Because different materials have different shrinkage rates, the housing mold made for nylon couldn't be used to make POM housing. That's why HMX made this new set of POM housing mold. What's changed is that it's compatible with POM material, and the new housing allows light diffuser insertion. Even if you don't insert a light diffuser, the housing openning is big enough for a lot of RGB shine through. On top of that, HMX polished the POM housing mold to make sure the surface is smooth enough to eliminate excessive scratchiness.
Factory Lubrication
We did a special treatment on these two switches to make sure the factory lubing is just on point. The stem legs and stem sliders are covered with a very thin coat of 205g0. The spring and leaf are lubed with dry film. Everything else is dry. There is no lube in the bottom housing or anywhere near the stem pole. The chance that these get lube pooling issue is very small.
Form of Sales
Time of Sales
May 21st
Vendor List
Global: https://unikeyboards.com/collections/keyboard-switches
Reviews and Videos
Coming soon
« Last Edit: Tue, 20 May 2025, 23:14:26 by DashanYYY »
Offline Damage
Re: [Instock] HMX Cosmic Purple/Lunar Stone switches
« Reply #1 on: Wed, 21 May 2025, 23:27:42 »
Looks great. Ordered some purples!
Offline Koniotaur
« Reply #2 on: Fri, 23 May 2025, 19:07:04 »
If it's in stock it's not pre order of group buy, is it?
Offline DashanYYY
    • Unikeys
« Reply #3 on: Sun, 25 May 2025, 17:15:17 »
Yes it's instock
Offline DashanYYY
    • Unikeys
« Reply #4 on: Sun, 25 May 2025, 17:15:33 »
Thank you :D
Offline Tune Lab
« Reply #5 on: Wed, 15 October 2025, 03:15:07 »
Lunar Stone Looking pretty nice
