Author Topic: [IC] PBTfans CALKIS  (Read 7085 times)
Offline sososoya
[IC] PBTfans CALKIS
« on: Thu, 05 June 2025, 15:18:05 »
PBTfans CALKIS
Join Discord Server for updates XD
Intro
Hi all, this is Soya. It’s been a while – today, I bring you the interest check of PBTfans CALKIS.
Inspiration
CALKIS is the sequel to the SOYA TEA probiotic beverage keycaps series.
[IC] TUTKEYS Yakeylt
This is a drink that I never miss every time I go to eat Japanese food.
Renders
Due to the influence of environment and lighting, the rendering color may differ from the actual object to some extent. Please refer to GMK CP for the white color code of the keycaps.
Kitting
There may be changes, please refer to the GB post for accuracy.
Contact
If you are interested in this set, why not join my Discord server? I will post updates on the latest progress of PBTfans CALKIS from time to time there. (I will communicate with you using Google Translate XD)
Discord server:https://discord.gg/cFXNcGUbcf
Disclaimers
The renders may differ visually from the final product. In case of any discrepancy between the renders and the final product, the final product shall prevail.
« Last Edit: Wed, 25 June 2025, 02:21:08 by sososoya »
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
Re: [IC] PBTfans CALKIS
« Reply #1 on: Thu, 05 June 2025, 15:20:56 »
I got addicted to these a while back, so this makes me feel warm and fuzzy feelings. GLWIC!
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #2 on: Thu, 05 June 2025, 18:56:54 »
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #3 on: Fri, 06 June 2025, 10:28:47 »
Your Enter novelty says "Deisgn" instead of "Design".
I'd consider getting this if it wasn't pbtfans.
Offline sososoya
« Reply #4 on: Sat, 07 June 2025, 20:22:43 »
Thank you for pointing out the mistake. I will correct it.
Offline dvorcol
« Reply #5 on: Tue, 28 October 2025, 18:16:37 »
KBDfans 18 Oct '25 - "Estimated production completion date: 31 Oct 2025"
https://kbdfans.com/products/pbtfans-calkis
