Author Topic: [In Stock] OE93 Unique Layout Tri-mode Aluminum Mechanical Keyboard  (Read 11654 times)
Offline john08099
  • Velocifire MK
  • * Moderator
    • Mechanical keyboards for typers
OE93
Designed by NEKEY Studio
Design
OE-93 is the first product in NE Key Studio's Retro Series. Inspired by IBM's classic MODEL F AT, its layout design incorporates the essence of IBM, combined with the designer's unique insights and modern user needs. After market research and analysis of user habits, the designer shifted the central input area to a 64-key layout on the left side.
The numeric keypad remains intact
The F-area on the left side of the keyboard is separated in the middle to reduce accidental presses. The independent four-key column provides more possibilities for custom shortcut keys.
The designer retained the nostalgic large forehead design of vintage keyboards and added stripe elements on the sides and center. In the middle, six multimedia shortcut keys are placed, which can be customized for different functions. This preserves the retro charm while seamlessly integrating modern elements, achieving a perfect blend of tradition and modernity.
The top-left metal nameplate uses magnetic attachment, allowing it to be easily lifted with a gentle press, and hides a compartment inside for storing the 2.4G receiver.
The keyboard features a sandwich-style design. The designer selected a vibrant color for the mid-frame that contrasts with the cool tones of the top and bottom case, adding depth to the overall look.
Color Options
Zinc Titanium White
Naples Yellow
Phthalocyanine Green
Eggshell Gray
Gallery
Features
3 Mount To Choose
Plate Gasket
PCB Gasket
Top
High-End Configuration and Craftsmanship
Material: 6063 aluminum case
Sound Dampening System:
Japanese Inoue poron 3.0mm pad
3.0mm switch socket silencer pad
0.5mm IXPE switch pad PET anti-static film
[/size]
Specifications
Mount: Plate Gasket, PCB Gasket, Top
Connectivity: Tri-mode
Material: 6063 CNC Aluminum
Surfacing: CNC spraying paint, PVD (nameplate)
Acoustic: Japanese Inoue poron 3.0mm pad; 3.0mm switch socket silencer pad; 0.5mm IXPE switch pad; PET anti-static film
Layout: Shift left 64; Left F zone, Pad zone; Stepped Capslock, Split backspace, ISO enter)
PCB: Hotswappable; Support ANSI Layout; Support VIA; 1.6mm; No flex cuts
Battery capacity: 6000mAh
Weight: 2.2kg
Size: 153 * 483 mm
Default Plate: Alu plate
Typing Angle: 7°
Compatible System: Support Windows & Mac
Connectivity: Wired, Bluetooth 5.0, 2.4G
Rolling rate: 1000Hz (Wired, 2.4G), 125Hz (Bluetooth)
Front Height: 19mm
Back light: No
Typing Test Video
Price Info
Price: 399 USD
Purchase Now
Please feel free to ask us any questions about the keyboard below! :)
Welcome to join our Discord and follow our Instagram,TikTok, YouTube  for more discussion, latest update and questions! :)
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
