Author Topic: What IBM Keyboard is that?  (Read 3677 times)
Offline buedi
« on: Thu, 04 November 2010, 16:54:17 »
Hello everyone, I found someone offering a IBM PC AT Keyboard 1394312.
Iīll try to attach a picture.
But I canīt find any information about that Keyboard. It looks like one of those Keyboards I worked on the AS/400 Terminals many years ago. But they are not PC AT compatible and would be of no use on my current PC.
The seller however claims that this one is working on a current PC. But Iīve never seen a Model F with the AS/400 Terminal Layout...
I still try to find a substitute for my Model F (AT, which I canīt use unfortunately) and my Model M... still searching for something which comes close to the AS/400 Terminal Keyboards. They even had a built in Speaker, but did not work on PCs back in that time.
Offline JBert
« Reply #1 on: Thu, 04 November 2010, 16:57:12 »
That's a 122-key terminal keyboard.
It is normally not meant to be used on a PC, but Kishy together with the help of other GH members got it working. See link below.
EDIT: It appears to be a model M instead of an F, if you look at pictures in the 122-key Terminal Keyboard Conversion (to AT, PS/2) you'll see it has a metallic label. This one seems newer.
« Last Edit: Thu, 04 November 2010, 17:00:15 by JBert »
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline buedi
« Reply #2 on: Thu, 04 November 2010, 17:14:27 »
Wow, that reply was quick :-)
Yes, it looks more like a Model M. Not only the Sticker, but also the "rounded" edge on top of the F Keys. But maybe thatīs just looking different on the Photos.
I still believe that this one will not work on a PC without a Mod. Because the F sounds so sexy Iīm always on the search if somewhere somebody sells something who doesnīt know what heīs giving away. But since this one looks like an M and it may not work on the PC, maybe Iīll grab it if itīs cheap or just leave it... continuing my search for a AT compatible F :-)
Offline JBert
« Reply #3 on: Thu, 04 November 2010, 17:22:34 »
FYI, here's another pic in the Model F 122-key vs Model M 122-key thread.
The storage list:
[/SIZE]
Offline buedi
« Reply #4 on: Fri, 05 November 2010, 16:36:39 »
Thanks everyone for your replies. I think Iīll skip this one. Iīm running Windows 7 x64 at home and in my Office. And even if I get this running with a cable Mod and another Driver (for up to XP), It wonīt do the job for me. And the USB Mod doesnīt seem to be perfect either (although itīs impressive with what you come up!). I donīt even have the talent to solder something properly... so Iīm doomed to keep my eyes open for something which is working for me out of the Box :-(
Also it seems like this is sounding and feeling the same like the Modem M I have here. So the search for a Model F working on my PC continues. Man... if I could go back 20 years again... I was surrounded by these things. But the only thing I have from that time is my G80-3000 (still working like a charm and a joy to write on).
Offline Sam
« Reply #5 on: Fri, 05 November 2010, 20:56:40 »
According to this page:
http://publib.boulder.ibm.com/infocenter/iseries/v6r1m0/index.jsp?topic=/nls/rbagssbcskybrddispprtnumb.htm
the 1394312 is a German/Austrian version of the 3477/3476 class keyboard.  The more common US layout equivalent looks to be the 1395660, which is a Model M AS/400 board, and is not PC compatible.  See here:
http://www.clickeykeyboards.com/model-m-buyers-guide/
Offline buedi
« Reply #6 on: Sat, 06 November 2010, 02:19:07 »
Quote from: kishy;243205
Buedi, do you already have this keyboard or was this all pre-purchase? If you've already got it there may be possible buyers here.
These were all pre-purchase questions. If someone is interested, hereīs a link to the ebay Auction. I told the seller, that this thing is not a PC AT Keyboard as he claims and that it wonīt work on a PC without mods. But it doesnīt seem like heīs interested in the truth... there are already 4 bids on it.
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=280583272432
The Auction will end in 2 hours and 45 minutes.
Edit: Heīs writing in a very bad German language, so Google Translate will not work properly.
Heīs claiming that heīs a collector (very doubtful) and that the Keyboard is in a "collectors condition". I think we can see clearly in the picture, that this one needs extensive cleaning and that the Spacebar looks a bit "yellow".
He says, that the Keyboard is working 100% (donīt know how he tested it, since he was not aware that this is a Terminal Keyboard and with the RJ-45 plug he was surely not able to plug it into his PC).
He also says that he cleaned it "a bit" and that thereīs only some minor dirt left.
Looks more like a free-rider /copycat than a true collector. It would be similar if I sold my Model F XT and claimed that itīs a AT Keyboard. Iīm sure if I find at least 2 collectors, the prices would go through the roof ;-)
« Last Edit: Sat, 06 November 2010, 02:23:25 by buedi »
