Author Topic: [IC]烟Smoke - 65% keyboard  (Read 29545 times)
Offline SENSY LAB
  • Where science meets sense.
« on: Fri, 22 August 2025, 00:06:45 »
烟Smoke
SENSY
The GB of Smoke will start on October 31st and end on November 30th
Hello everyone, this is SENSY. We are a new studio from China. In 2024, our core members XINGZHI and QIN collaborated with VERTEX to release our debut work "Seal". Moving forward, SENSY will operate independently to bring you new designs.
This keyboard draws inspiration from XINGZHI's favorite song, Deep Purple's Smoke on the Water. The song's core elements—smoke, water, fire—inspired us to create a keyboard with rich curves and surfaces, breaking traditional symmetry. That's why we chose the inherently asymmetrical 65% layout.
Let's dive into the details.
Basic Info
Layout: 65%
Size: 320.1 x 124.6 x 38.4mm
Mounting: Top mount
Weight (assembled): ≈2.1-2.2kg
Given the weight, we've switched to custom oval rubber feet instead of 8mm round ones, based on user feedback.
Typing Angle: 9°
Front height: FH=18.5mm/EKH=22.5mm (excluding rubber feet)
Front frame width: 10.5mm (including front slope)
The front height features an asymmetrical curved design, akin to early ergonomic keyboards from brands like Microsoft. For this asymmetrical 65% layout, we shifted the center of gravity to the F/J key center, using complex curved surfaces to achieve ergonomics without widening the front frame. The overall design language also follows this shifted axis.Thanks to the 3-layer, screwless external design, the front height stays under 20mm (Front height is 18.5mm, with a 13.5mm low point in the ergonomic slope). This allows for a lower curved front edge matching the ergonomic arc.
Side profiles boast complex curves for seamless 4-sided connections, meeting G3 continuity standards. The top cover has a raised curved design, no pure flat surfaces here. Kudos to our engineers for devising a variable-curvature surface to replace tricky corner chamfers, solving the issue of connecting irregular curves.
These complex side curves extend to the cable port side, with a weight transition using two cut surface changes.
Materials & Craftsmanship
Manufacturing: DDS (Dadesin)
Case: Aluminum (anodized or electrostatic coating)
Weight: Sandblasted Brass/ Sandblasted Copper/Stainless Steel (All with AF coating)
Mid frame: PEI, original color with knife pattern
Nameplate: PVD SS / Damascene Ti / Damascene Cu
Pate: Anodized Aluminum Plate / PEI (original color with knife pattern)
PCB Support
Single-mode, compatible with Vial. Offering WK and WKL options.
Soldered
Hotswap
Other Details
On ISO
Three team members are vintage keyboard enthusiasts with over 3 tons in collection. Yet, we see no need for ISO in 65% layouts.
The middle frame's reinforcing ribs and filling design (with a complete logic) would be compromised by ISO support. Thus, we skip ISO but retain popular features like split backspace.
On the 1U Upper-Right Key
Our favorite 65% keyboards (and our engineer's preference) omit this 1U Delete key. The complex top cover design also makes it unnecessary. So, we've scrapped the planned 1U key.
Assembly Experience
We'll include custom magnetic perforated screws and a magnetic screwdriver to avoid issues with the 3-layer structure, like issues such as screw detachment/getting stuck or similar problems. Responding to market feedback, we're switching to a magnetic scheme to resolve cable length/softness problems.
Structural Design
Enhanced Top Mount
Engineers opted for 3 upper + 2 lower fixing points (common in 60% keyboards), which performed well in prototypes and will be used in production.
Smoke uses soft buffers: 70a and 90a options. Engineers adjusted buffer design to minimize torsional deformation during screwing, ensuring stability.
Mid Frame with Built-in Force Break
We favor 3-layer, screwless designs and now the brass middle frame has also become quite popular. But personally speaking, we don't have a particularly strong preference for brass middle frames. especially with a heavy weight. XINGZHI proposed a transparent hard resin middle frame to echo "smoke on the water":
•   The weight represents "water," so the translucent frame evokes "smoke."
•   It isolates top and bottom cases, acting as a Force Break.
•   The hard resin's insulation lets us thicken the frame, reducing cavities for better filling.
Common Force Break designs risk increasing cavities or gaps. Our middle frame solution passed stress tests and prototyping. PEI was chosen over low-value PEEK or soft, deformable PC—our first mass-produced PEI middle frame.
4mm Plate (Optional)
Once popular, 4mm plates are less common due to complex design needs (early brass versions often caused finger fatigue). However, their filling effect and consistency outshine 1.5mm plates. Our engineers designed an optimized 4mm plate with improved support and logic, available as an option.
What's Included
•   Aluminum top and bottom cases + weight x1
•   Badge set (1 large, 1 small) x1
•   Internal aluminum badge x1
•   PEI middle frame set x1
•   Plate x1
•   PCB x1
•   Magnetic DB x1
•   70a + 90a buffer blocks x5
•   Rubber feet set x1
•   Carrying case x1
•   Outer box, T6/T8 Torx screwdrivers, instruction manual, etc.
Color Options
Anodized (7 options)
Black
silver
red
green
blue
purple
brown
Coating (1 option)
White
Accessory Options
Weight
Sandblasted brass AF
Sandblasted copper AF
Stainless steel AF
Badge
PVD SS (Gold/Rose Gold/Gunmetal)
Damascene Ti
Damascene Cu
Plate
1.5mm aluminum plate (silver/black)
4mm PEI plate
Vendors
America - Clickclack
Korea - Swagkeys
Singapore - iLumkb
Australia - Toro Studio
Canada - Unikeys
Vietnam - The Keebs Store
Japan - NEKOYUI
International - Zfrontier
How to follow news of the Smoke
Follow our or vendors’ Instagram and Discord for updates.
« Last Edit: Mon, 27 October 2025, 21:34:18 by SENSY LAB »
Offline meowoofun
  • Design Critic
Re: [IC]烟Smoke - 65% keyboard
« Reply #1 on: Fri, 22 August 2025, 21:49:44 »
The blue anode with the stainless steel weight looks absolutely gorgeous!
Offline Randomlosername
  • Gacha Done Got Me
    • IG
« Reply #2 on: Fri, 22 August 2025, 22:01:04 »
holy crap I need this rn.
Re: [IC]Smoke - 65% keyboard
« Reply #3 on: Fri, 22 August 2025, 23:47:49 »
This looks really really good. Can a vendor that is actually located in the United States be added as an option? Novelkeys, Divinikey, Cannonkeys, and BowlKeyboards to name a few. This is especially important considering Trump's Tariffs are in full effect moving forward
Offline SENSY LAB
« Reply #4 on: Fri, 22 August 2025, 23:51:40 »
ok,we will ask bowl
« Reply #5 on: Sat, 23 August 2025, 00:54:07 »
ok,we will ask bowl
Thank You!
Offline Gemmmmmmmmmmmmmy
« Reply #6 on: Sat, 23 August 2025, 00:58:17 »
This is gorgeous DAMNNNNNNNNNNNN
Life seems so much smaller
Swim to the moon
Offline kentdo10
« Reply #7 on: Sat, 23 August 2025, 04:15:06 »
They both ship out of China, so they gonna result in the same tariff regardless. But Clickclack which air-ship directly from China will have the board arrive at your doorstep much quicker no?
« Reply #8 on: Sat, 23 August 2025, 04:25:39 »
Actually no it doesn't ship much quicker when CC is the vendor and the tariff is not the same since it's 30% for businesses who move inventory well over 800 vs 55% for me who would be ordering directly. Also, shipping would be cheaper up front since it would be USPS/UPS Ground shipping. But even then it's also a matter of customer service. I'd rather deal with a vendor who's in the US and communicates during normal american hours who can provide after sales support without the need of waiting weeks for a replacement part to be shipped and delivered. CC's QC isn't the best (every board I've gotten from them has had PCB issues (so I've always needed to get 3+ PCBs from them). I'm happy to join this GB through a vendor like Bowl whose been fantastic in communication, fulfillment, and follow-up.
Offline kentdo10
« Reply #9 on: Sat, 23 August 2025, 04:37:51 »
ah yeah, I was just curious on the Tariff lmaooo Orange boi really f**k everyone up with his Tariff lol
« Reply #10 on: Sat, 23 August 2025, 04:39:45 »
Yuuuup
  • Gacha Done Got Me
    • IG
« Reply #11 on: Sat, 23 August 2025, 09:40:09 »
ok,we will ask bowl
In Bowl we trust fr.
Offline azhdar
  • Praise the AZERTY god
« Reply #12 on: Sun, 24 August 2025, 00:45:54 »
On ISO
I can't even come close to comprehend what this means ?
In what way is ISO not working/compatible with 65% keyboard.
If you were speaking about and HHKB I could understand.
« Last Edit: Sun, 24 August 2025, 03:43:31 by azhdar »
Azerty Propagandiste
Offline SENSY LAB
« Reply #13 on: Sun, 24 August 2025, 05:04:42 »
On ISO
we believe ISO is unnecessary for 65%.so when there is a conflict between ISO and structure,we choose to give up ISO
Offline azhdar
« Reply #14 on: Sun, 24 August 2025, 08:02:11 »
On ISO
smh, how hard is it to add 2 cuts into a plate...
Offline SENSY LAB
« Reply #15 on: Sun, 24 August 2025, 20:21:07 »
On ISO
it's not only influence the plate,it will change the middle frame's rib because of stabilizers' space.the pei middle frame is softer then metal,this will lead to abnormal deformation
Offline Bagri
« Reply #16 on: Tue, 26 August 2025, 03:17:08 »
I agree this doesn’t make sense looking at the component view…I would be curious to know more about how it could possibly affect it in such a way …
Also, you start with :
I think this is a deep misunderstanding of what ISO is. This is not about popular or unpopular feature from vintage board, or somewhat comparable to split backspace. This is a regional difference on how keyboards are made.
That being said the design look interesting especially on the asymmetrical aspect.  :thumb:
« Last Edit: Tue, 26 August 2025, 03:21:56 by Bagri »
Keyboard photos - https://www.instagram.com/bagri_shoot
Working on the NP-R -  https://bit.ly/NP-R
Designer of the Alt grrrrr kit - https://bit.ly/altgrrrrr
Offline SENSY LAB
« Reply #17 on: Tue, 26 August 2025, 07:37:31 »
ah yes. we have replied to another friend above. we highly respect the usage custom of different regions.  but our middle frame's rib cannot support vertical stabilizers. we have tried to add ISO support. it will reduce the middle frame's strength and cause mechanical deformation.
Offline bayernlad
« Reply #18 on: Tue, 26 August 2025, 10:47:10 »
When will the GB start? Any plans in September?
Offline SENSY LAB
« Reply #19 on: Tue, 26 August 2025, 19:57:47 »
maybe in October.we plan to start in September, but i guess we can't make it
Offline meowoofun
  • Design Critic
« Reply #20 on: Tue, 26 August 2025, 19:59:47 »
What's the price range?
Offline SENSY LAB
« Reply #21 on: Tue, 26 August 2025, 20:48:55 »
about $350-400
« Reply #22 on: Sun, 31 August 2025, 00:54:41 »
ok,we will ask bowl
Did Bowl respond/get back to you? Can he vendor this project?
Offline SENSY LAB
« Reply #23 on: Sun, 31 August 2025, 21:30:54 »
ok,we will ask bowl
After preliminary communication, our biggest problem at present is the lack of means to directly collect large amounts of US dollars. We are studying how to solve this problem, otherwise we will not be able to cooperate directly with our US vendor
  • Gacha Done Got Me
    • IG
« Reply #24 on: Tue, 02 September 2025, 02:11:01 »
ok,we will ask bowl
 Collect as in make profit from or collect as in receive money from the US via whoever you are located ?
Offline SENSY LAB
« Reply #25 on: Tue, 02 September 2025, 21:41:20 »
ok,we will ask bowl
There are many restrictions on collecting US dollars in China.I am contacting to try to solve this problem
Offline bayernlad
« Reply #26 on: Thu, 11 September 2025, 09:51:22 »
When will it be listed on unikeys or other vendors? Can we have some reviewers try it out and review? The board looks amazing but would like to see more content and info.
Offline SENSY LAB
« Reply #27 on: Mon, 15 September 2025, 06:23:45 »
we will send keyboards to alexotos & LightningXI & Blacksimon this month
Offline BossKeebs
« Reply #28 on: Fri, 26 September 2025, 10:30:23 »
Love the design
Offline SENSY LAB
« Reply #29 on: Mon, 27 October 2025, 21:38:31 »
The GB of Smoke will start on October 31st and end on November 30th.
Vendors
Korea - Swagkeys
Singapore - iLumkb
Canada - Unikeys
Japan - NEKOYUI
