Author Topic: IBM vs Unicomp  (Read 2122 times)
Offline patrickgeekhack
IBM vs Unicomp
« on: Sat, 06 November 2010, 19:43:36 »
I have the impression that the IBM Model M has a higher pitch sound than the Customizer 104. Am I the only with that impression?
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
IBM vs Unicomp
« Reply #1 on: Sat, 06 November 2010, 19:48:30 »
Quote from: ripster;243580
I'd say the Model M is pingier from the spring sound.  Otherwise the same.
Yes, pingier. That is exactly what I was trying to say. That said, why is it pingier? That's the question.
IBM vs Unicomp
« Reply #2 on: Sat, 06 November 2010, 19:53:54 »
That can explain why. I just could not find a plausible reason to explain this since they are basically identical keyboards. I need to remove the silicone grease from my Customizer so that I can use it from time to time just for fun.
IBM vs Unicomp
« Reply #3 on: Sat, 06 November 2010, 20:29:30 »
Quote from: ripster;243600
Here's  an idea.  Do the dental floss mod.  Over time you should be able to soak up all that grease.
You mean that the grease should get off the spring the more I type? I thought about this, but then again, I wonder where the grease will go though and if it will cause any kind of problem once is went "down." The other thing that bothers me is that I was not able to inject the same amount of grease in each swith. As a result some of them feel quite different. Some of them even feel mushy.
IBM vs Unicomp
« Reply #4 on: Sat, 06 November 2010, 20:37:44 »
Quote from: ripster;243607
I'm assuming the dental floss will soak up the grease.  Then pull them.
Did not think about this one.
