Author Topic: Building my first custom keyboard – looking for advice (65%)  (Read 16823 times)
Offline bdube30
« on: Sat, 13 December 2025, 15:41:46 »
Hi everyone!
I’m looking to build my first custom keyboard. I initially considered a prebuilt, but I can’t seem to find one that combines the layout, switches, and color I like within a price range that works for me.
What I’m mainly looking for
“Basic” features
  • Can be connected via a USB cable (wireless would be nice to have).
  • Compatible with a reliable interface to configure the keyboard, either through software or, even better, a web interface.
  • Not high-end, but also not a cheap case/housing—something that will sound decent.
  • Decent build quality. I don’t want to worry about commuting with the keyboard (it will be protected in a soft case).
Case / Barebone
  • I’m looking for a 65% ANSI layout.
  • I just discovered split spacebars, and now I want that extra button 😛 It’s not a dealbreaker, but I would really love to have this feature.
  • I’ve seen many cases where the power button is hidden under a keycap. I don’t really understand why—I feel like this could be problematic long-term if the Caps Lock or Tab keycap becomes loose. I also don’t see myself carrying a keycap puller just to power the keyboard on or off. In a perfect world, I’d have direct access to the case controls.
  • I’d like some angle adjustment if possible. I haven’t seen much about that in what I’ve found so far.
I haven’t found many cases, but these are the ones I’ve come across:
Switches
I’m not fully decided on switches yet. I plan to use this keyboard at work, so I’m considering silent switches, but quiet brown switches or something similar could also work.
I’m leaning toward tactile switches, but I’m not strongly opinionated about it. From what I understand, silent switches are mostly linear?
I don’t know much about which switches are good, and there are thousands of choices, so I’m open to suggestions. I often hear about Gateron, but I’m not sure if they’re a good pick or if there are better options.
Here are a few I found:
So many choices  :eek: :D
Keycaps
I’m looking for Cherry profile keycaps that may include keys for a split spacebar. I’m mainly aiming for a dark-themed keyboard, but I might also be open to a gray set with orange or blue accents.
Here are a few sets I found:
I hope my message isn’t too long to follow, but if I’m spending a bit more money going custom, I don’t want to make beginner mistakes or forgot something obvious!
If it helps, here are some prebuilt keyboards I was considering. I know they’re mostly HE keyboards, but that’s not very important to me, and I figured that HE custom bases aren’t widely available yet (?):
Don't hesitate to share any advice with a keyboard builder noob :P ( I'm still a geek who build PC and watch a lot of keyboards video on youtube :P )
Re: Building my first custom keyboard – looking for advice (65%)
« Reply #1 on: Thu, 18 December 2025, 16:49:21 »
Hello and welcome! Do you have an overall budget that you're working within for the build? You mentioned having trouble finding a prebuilt that fits the budget, but to be honest building from individual components usually does come out to a higher cost than prebuilt so it would be good to know that constraint.
On the topic of switches, I do find that most silents are also linear, and it's maybe worth noting that even non-silent switches aren't necessarily "loud" (at least not annoyingly so). Clicky switches will almost always be pretty loud (that's kind of the point, after all), but most tactiles are just regular typing levels of loud, nothing worse than what everyone else in your office is probably typing on.
Offline bdube30
« Reply #2 on: Thu, 18 December 2025, 17:06:29 »
Hi,
Good question for the budget. I had a budget of 80-150$ for a prebuild keyboard, but I am aware that a custom one will probably cost me more. I'm flexible in term of budget but 200/250$ would be a limit I would try to stick to.
I'm open to non-silent switches that are on the quiet side too. I won't go for blue switches  ;D I Know 90% of my coworker (and myself for the moment) use a cheap low profile membrane that are quiet. Some of my coworker started to bring mechanical keyboard, so it sure, I will not stand out too much I think. I may look for the quietest tactile switch that are knowned to be reliable (?) I still don't know for sure what I will pick, since I can hardly test switches before buying them too.
Offline thunk
« Reply #3 on: Fri, 19 December 2025, 02:24:59 »
These days there are a lot of fantastic custom builds on the second hand market that are extrtemely cheap for what they're offering. Especially with a budget of around 200 you can get exceptional builds, often with switches (and keycaps if you're lucky -or have good negotiating skills).
So basically you'll get a custom, but prebuilt for you by someone else. A point to consider is that you'll have to do your homework if you want to go this route, in regards to your requirements.
Hope this is helpful.
Offline nescio
« Reply #4 on: Fri, 19 December 2025, 03:46:52 »
I would just copy some tutorial for the your first custom keyboard and only add changes when you are confident with the basics. I watched a guy on YouTube building a custom keyboard and it was already quite a big project. It's very easy to underestimate projects and overestimate your abilities.
The only reason I would build a custom keyboard, is if I had strong material engineering knowledge (which I don't), had research on the biomechanics of my specific hand for computing the optimal geometry of the keyboard  (which I don't), and had a good idea for the time investment required (which I also don't).
The Imprint keyboard does make keyboards taking photos from your hands as input. I have no affiliation with them.
So, objectively, building a keyboard should be seen as a hobby, a way to learn a bit about PCBs, microcontrollers, etc. Expecting a keyboard to be better, might be too optimistic.
Offline bdube30
« Reply #5 on: Fri, 19 December 2025, 08:08:28 »
These days there are a lot of fantastic custom builds on the second hand market that are extrtemely cheap for what they're offering. [...]
That's a good point, I will look for that
I would just copy some tutorial for the your first custom keyboard and only add changes when you are confident with the basics. I watched a guy on YouTube building a custom keyboard and it was already quite a big project. It's very easy to underestimate projects and overestimate your abilities. [...]
I Have look youtube videos, and will continue to do it.
For the second part of your message, when I say custom, I did not plan to design the PCB, etc. I was hoping to buy a base would have manage the  PCB, microcontroller, etc. and that I would then just buy switches and keycap to go on top of it.
Offline nescio
« Reply #6 on: Fri, 19 December 2025, 09:13:24 »
That sounds like a plan that will likely not result in disappointment.
Offline bdube30
« Reply #7 on: Fri, 19 December 2025, 09:37:01 »
I have sometimes difficulty to detect sarcasm in english (not my main language). Does your message is sarcastic? Or you think that is it realistic to get a barebone/case that will fit my need of then choosing my switches and keycap?
(I'm sorry if I misread you message, trying my best)
Offline Avenyx
« Reply #8 on: Fri, 19 December 2025, 11:12:02 »
Sounds like a great project! For switches, if you’re looking for something silent and tactile, Gateron Silent Browns could be a good choice. As for cases, options like the Keychron Q7 or GMMK2 are solid starting points. Good luck with your build! :thumb:
Offline nescio
« Reply #9 on: Fri, 19 December 2025, 11:34:11 »
You can ask ChatGPT whether or not it is sarcasm too, but this is not sarcasm.
I think it is a realistic plan with a defined scope.
You can reduce project risk by first clarifying your exact requirements. From what I have seen, if I were buying/building a new board, I would get those new inductive keyswitches, because they seem to be technologically better, but there is no doubt in my mind that someone with actual experience with them might disagree. Ultimately, it's sort of a gamble as to what you buy, because the only way to know it's not a gamble, is if you actually buy multiple and compare.
Offline bdube30
« Reply #10 on: Fri, 19 December 2025, 11:44:55 »
Ok, thanks for your answer.
And for the ChatGPT thing, I just asked and this is the answer I have got, so my brain must be close to AI  ;D
Is this sarcasm : «That sounds like a plan that will likely not result in disappointment.»
Yes — it’s very likely sarcastic, or at least dry / understated irony.
On the surface, the sentence is technically positive, but the phrasing “will likely not result in disappointment” is an awkwardly cautious double-negative. In everyday speech, that kind of wording is commonly used to signal skepticism rather than genuine approval.
But, yeah, I did not mean to accuse you or anything.
You're right that my post go on very large amount of variable, I will work on reducing the amount of options I have to choose between, that will surely help me take a better decision, and/or ask more specific question.
Offline bdube30
« Reply #11 on: Sun, 21 December 2025, 20:09:48 »
Mockup done with AI to decide for the base color and keycap
I continue my research to decide what my custom keyboard will look like and this is what I'm on right now:
Base: Weikav Lucky65 V2
 https://weikav.com/product/weikav-lucky65-v2/ (with the split pacebar option)
Switches: Outemu Cream Yellow Pro V2 https://www.amazon.ca/gp/product/B0DNWB84S3/ref=ox_sc_act_image_3?smid=A24R95VR7GPNGC
Keycaps: https://www.aliexpress.com/p/tesla-landing/index.html?scenario=c_ppc_item_bridge&productId=1005007378465113&_immersiveMode=true&withMainCard=true&src=google&aff_platform=true&isdl=yhttps://www.aliexpress.com/p/tesla-landing/index.html?scenario=c_ppc_item_bridge&productId=1005007378465113&_immersiveMode=true&withMainCard=true&src=google&aff_platform=true&isdl=y&src=google&albch=shopping&acnt=631-313-3945&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&&albagn=888888&&ds_e_adid=&ds_e_matchtype=&ds_e_device=c&ds_e_network=x&ds_e_product_group_id=&ds_e_product_id=en1005007378465113&ds_e_product_merchant_id=504944729&ds_e_product_country=CA&ds_e_product_language=en&ds_e_product_channel=online&ds_e_product_store_id=&ds_url_v=2&albcp=19215273764&albag=&isSmbAutoCall=false&needSmbHouyi=false&gad_campaignid=17178707511
With what I looked so far on youtube, reviews, etc. I'm confident toward the base and the switches, for the keycap, I would have prefer to have more options that the ones I have found, but I do not want to spend too much on keycaps (for now). I need a kit with the extra spacebar keys. I doubt a bit about the quality of them, but I did not find any others keycap I liked under +/- 50CAD$.
I will probably hit the buy button soon, but I will keep an eye here to see any recommendation toward this build!
Offline nescio
« Reply #12 on: Mon, 22 December 2025, 02:49:18 »
Which AI (and which subscription, if relevant) and how close is it to what you actually want? Was the output a Blender file such that you could edit it for your own purposes or just the picture?
Excellent use of AI to reduce project risk.
Offline bdube30
« Reply #13 on: Mon, 22 December 2025, 07:40:13 »
I just use ChatGpt with the free tier, I paste the image of the Weikav Lucky65 V2 and the image of the Keycaps set :
For me it help me decide to use this set of Keycaps over a white set :
But we can see the color of the Keyboard frame was changed by chatGpt in the process, so it's more for having a general idea.
Offline julimma
« Reply #14 on: Thu, 12 February 2026, 19:50:36 »
I think there are many entry level 65% cases out there that doesn't break the bank, like the KBDFans ones or the EAVE65. You can try them to get a feel of what you like in terms of switches, mounting options.
