Author Topic: [IC] GMK CYL Evil Lime | GB LIVE!!  (Read 182025 times)
Offline nadhole69
« on: Mon, 13 April 2026, 17:37:06 »
Discord
GMK CYL EVIL LIME
Hi, im Nad and let me introduce my first set, Evil Lime — a set based on GMK N9 and CR base colors, and for the legends, I chose to use a custom purple and lime colors. To be honest, there's not much else to say; I just think they work really well together.
This is also a first step toward understanding the community's interest in this set.
Any additional kitting or changes to the base kit will be evaluated later.
KIT:
Base:
EXTENSIONS:
Lime alpha kit:
Extension kit:
Accents kit:
RENDERS in differents lights:
Colors:
base alpha: GMK N9
base mods: GMK CR
lime: Pantone 389C
Purple: 2592C
SAMPLES:
The purple changes a bit depending on the light but The first 2 image are pretty accurate, The last one was taken outdoors and the purple came out a bit darker than usual.
The two purple at the top are the old sample that I discarded and DY purple.
Vendors:
CN: KBDfans
SEA: Pantheonkeys
UK: Proto[Typist]
KR: Geonworks
EU: Delta Key Co.
CA: Deskhero
OCE: Switchkeys
US: Bowlkeyboards
others TBD
Collaborations: TBD
Pricing: TBD
Instagram
Discord
Please consider filling out the form to help me better understand your base kit preferences: FORM
« Last Edit: Wed, 09 September 2026, 18:19:01 by nadhole69 »
Offline nadhole69
Re: [IC] GMK CYL Evil Lime
« Reply #1 on: Mon, 13 April 2026, 17:38:07 »
reserved
« Reply #2 on: Tue, 12 May 2026, 13:57:01 »
Approval bump :thumb:
Offline mr_foggy
  • neue = nope
« Reply #3 on: Tue, 12 May 2026, 14:14:11 »
unexpected banger
I like this a lot
Offline nadhole69
« Reply #4 on: Tue, 12 May 2026, 14:31:50 »
unexpected banger
I like this a lot
thank you foggy
Offline Zahul
« Reply #5 on: Tue, 12 May 2026, 14:57:09 »
This looks amazing! Any chance for an alpha kit with green legends?
« Last Edit: Tue, 12 May 2026, 14:59:16 by Zahul »
Offline nadhole69
« Reply #6 on: Tue, 12 May 2026, 15:11:43 »
Thanks, Yes, the alpha with lime legends is among the additional kittings I have in mind..But nothing confirmed.
« Reply #7 on: Tue, 12 May 2026, 17:20:09 »
Oh this is nice. Purple & Lime Green go real well together
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #8 on: Tue, 12 May 2026, 18:38:14 »
i would be careful to not end up like darkskel, while people really like it i found it very hard to look at and much preferred my sky modo set
green alphas would be baller
Offline Keyboard_Dad
« Reply #9 on: Tue, 12 May 2026, 20:04:25 »
I like! I second the lime legends. Glwic!
Offline VXQN
« Reply #10 on: Wed, 13 May 2026, 02:39:49 »
This is nice! I'd like to see it with darker alpha base color though (like, say GMK Slasher) to make the purple really pop more. I always thought that CR and N9 are actually slightly too far apart in terms of tint to work that well together.
Offline nadhole69
« Reply #11 on: Wed, 13 May 2026, 02:46:07 »
Thank you! I thought about it, and that's why I chose not to use a darker purple (like the one of hyperfuse) but something in between purple and magenta... But I'll keep your idea in mind too
Offline HungHingDaiLo
  • 無間道
« Reply #12 on: Wed, 13 May 2026, 04:06:07 »
https://www.pantone.com/color-finder/PURPLE-C
Pantone purple-c (pure violet) might be a good option to consider, since the 2070C you chose is still on a darker purple spectrum IMO
IG: @rayhhdailo
Offline adh10022194
« Reply #13 on: Wed, 13 May 2026, 05:42:01 »
Great concept. In.
Offline YoungManKim
« Reply #14 on: Wed, 13 May 2026, 09:26:31 »
The alphas in these renders are really hard to look at, hope you consider a color with better contrast. GLWIC!
Offline Zahul
« Reply #15 on: Wed, 13 May 2026, 09:29:46 »
Sounds great! In case you do decide on this kitting. Any chance we would see renders of lime legends with black alpha's and with grey alpha's. So that we can see which pairing looks better? Either way I'm in!
Offline nadhole69
« Reply #16 on: Wed, 13 May 2026, 10:36:48 »
  • Added alpha lime kit
  • Added SEA Vendor
  • fixed a pipe slash mistake in base kitting
Offline pixelpusher
« Reply #17 on: Wed, 13 May 2026, 13:09:25 »
I with the people who prefer the lime alphas as the base set :)  It's pretty cool, honestly
Offline Manukbs_
« Reply #18 on: Wed, 13 May 2026, 15:46:40 »
Please also esc purple base/ green legend and instabuy
Offline meowoofun
  • Design Critic
« Reply #19 on: Wed, 13 May 2026, 17:49:14 »
Lose the purple alphas and stick to green as main,
Alternate alphas should be lime alphas with purple legends
Offline cht1821
« Reply #20 on: Thu, 14 May 2026, 02:27:39 »
Feel like the purple needs some change, doesn't seem very cohesive with the bright lime colour
Offline nadhole69
« Reply #21 on: Thu, 14 May 2026, 02:50:28 »
I understand the skepticism, to have a comparison it would be very similar to darksel with the lime extension, for me it is a great combination but I understand that it is a matter of taste.
Offline nadhole69
« Reply #22 on: Thu, 14 May 2026, 02:52:52 »
Yes, this could be done.
« Last Edit: Thu, 14 May 2026, 02:56:57 by nadhole69 »
Offline adh10022194
« Reply #23 on: Thu, 14 May 2026, 04:51:24 »
I agree with some of the other posts that I think the set would be better with the green alpha as the base and the purple as an extension.
Offline Zahul
« Reply #24 on: Thu, 14 May 2026, 06:57:44 »
Lime alpha's look great! Thanks for the quick work!
Offline jigumina
    • Personal site
« Reply #25 on: Thu, 14 May 2026, 11:41:20 »
The lime alphas looks great! GLWIC and with your first set!
Offline rayy
  • aesthetics enthusiast.
« Reply #26 on: Thu, 14 May 2026, 14:45:33 »
Excited to see how this progresses, i do agree another shade of purple might suffice for legibility reasons IRL.
Offline Warfinger
« Reply #27 on: Sat, 16 May 2026, 10:42:52 »
I really like this. Good luck.
Offline nadhole69
« Reply #28 on: Sat, 16 May 2026, 15:18:34 »
UPDATE:
  • I read a lot of feedback and they were very helpful, I decided to change the purple to improve the clarity of alphas, and to consider a possible full lime kit(with purple alpha as extension)... I created a form to understand your preference :)
« Last Edit: Sat, 16 May 2026, 15:20:47 by nadhole69 »
Offline SwitchKeys
    • SwitchKeys
« Reply #29 on: Mon, 18 May 2026, 16:42:20 »
Unexpected banger combination. I like it! :thumb:
Offline nadhole69
« Reply #30 on: Wed, 20 May 2026, 04:20:03 »
UPDATE!
1- Updated Vendor List:
                CN: KBDfans
                SEA: Pantheonkeys
                UK: Proto[Typist]
                KR: Geonworks
                EU: Delta Key Co.
                CA: Deskhero
2- Surprisingly, the votes for the base kit are very close, and due to the possible return and run of others black-lime set, i’ll probably choose the OG base kit, with the Alpha Lime kit as extras — but nothing is confirmed yet.
3- Added discord channel
thanks to the vendors and people who believe in the project :thumb:
« Last Edit: Wed, 20 May 2026, 11:28:41 by nadhole69 »
Offline Zahul
« Reply #31 on: Wed, 20 May 2026, 14:17:55 »
UPDATE!
                CN: KBDfans
                SEA: Pantheonkeys
                UK: Proto[Typist]
                KR: Geonworks
                EU: Delta Key Co.
                CA: Deskhero
Any chance of getting unikeys as a vendor :)
Offline nadhole69
Re: [IC] GMK CYL Evil Lime | Added vendors
« Reply #32 on: Sat, 23 May 2026, 05:51:59 »
UPDATE
Ordered samples from GMK
added some questions to the FORM , such as the possibility of making the numpad separately to lower the price of the base kit, pls filling out
Added Oceania vendor
Offline nadhole69
Re: [IC] GMK CYL Evil Lime | Samples ordered and Added vendors
« Reply #33 on: Sun, 31 May 2026, 03:58:34 »
« Last Edit: Tue, 08 September 2026, 05:55:35 by nadhole69 »
Offline pixelpusher
« Reply #34 on: Sun, 31 May 2026, 11:05:21 »
UPDATE!
Added US vendor: Bowlkeyboards
Samples are arrived and i redid all the renders ( N9 were too light in the renders while in real life it is decidedly dark)
Lime 389c is perfect, the purple is a bit too light/lilac in some situations, I wanna try something more vibrant
that's a great followup with the renders.  I own all of the GMK sets with N9 and I definitely think the new renders look closer to my IRL experience.   :thumb:  Still makes me want the all lime version even more.  It looks amazing.  I do agree that the purple needs more of a punch to match that lime intensity.
« Last Edit: Sun, 31 May 2026, 11:07:12 by pixelpusher »
Offline nadhole69
Re: [IC] GMK CYL Evil Lime | Samples arrived and Added US vendor
« Reply #35 on: Thu, 04 June 2026, 04:01:13 »
UPDATE
I got permission and added the new GMK skulls in the accent kit, I think these can characterize the set even more.
And a reminder to fill out the form, is really important for kitting, also added new link for discord channel (it was expired)
Offline Fede_Feo
« Reply #36 on: Sun, 07 June 2026, 08:51:13 »
Such a nice colour combination
Offline nadhole69
« Reply #37 on: Mon, 13 July 2026, 09:12:48 »
-Still waiting the new quotes from GMK and new Purple samples, but there will be big changes in the base kit, I will update the new kits once I get the quotes, In the meantime, you can check them out on my Discord.
-For now, the poll shows the base kit with purple alpha slightly in the lead; I’m reminding anyone who hasn’t done so yet to vote if they are interested in the set.
Offline nadhole69
Re: [IC] GMK CYL Evil Lime | Big changes to the kitting
« Reply #38 on: Thu, 23 July 2026, 01:52:04 »
-I’ve received the quotes from GMK and confirmed the new kits, which feature big changes like adding an extension kit. I invite you to check out the kits on top on the page.
-For suggestions, you can always fill out the form or talk to me directly on the Discord server which I will also use for future projects.
-The purple in base is confirmed. I'm sorry for those who wanted the full lime, but given the poll results we've decided to stick with purple and lime as extension.
-GB date has not been confirmed, but it could be between September and early October.
« Last Edit: Thu, 23 July 2026, 01:57:03 by nadhole69 »
Offline mr_foggy
  • neue = nope
« Reply #39 on: Thu, 23 July 2026, 15:13:47 »
confirmed base + alt alphas
thanks for running this
Offline clik_clak
« Reply #40 on: Fri, 24 July 2026, 16:25:24 »
Best looking set I've seen in quite some time. Can't wait to put in my order.
Any chance you're working on matching deskmats?
Offline AndrewG
« Reply #41 on: Mon, 27 July 2026, 08:46:02 »
Icon mod could be interesting for me  ;D
Offline nadhole69
« Reply #42 on: Tue, 28 July 2026, 09:36:11 »
UPDATE SAMPLES
The purple sample has arrived, and I'm really satisfied with this shade, it change a bit with the light but the first 2 images are pretty accurate, The last one was taken outdoors and came out a bit darker than usual
The two at the top are the old sample that I discarded and DY purple.
« Last Edit: Tue, 28 July 2026, 09:52:41 by nadhole69 »
Offline EdgeOfInfinity
Re: [IC] GMK CYL Evil Lime | Got all the Samples!
« Reply #43 on: Wed, 05 August 2026, 18:18:17 »
are the lime sample keys the same in each pic? ngl the first two look more yellow than lime
this set has a lot of potential, thanks for taking the time to do multiple rounds of sampling.
Offline gmk_keycaps
  • Official GMK Account - here to help :)
    • Official GMK Web Store
« Reply #44 on: Thu, 06 August 2026, 01:42:34 »
Same color, but under different lighting.
Generally speaking, this always applies: Daylight contains lots of blue, making any color look rather cool and crisp. Warm desk lights lack blue and push red/yellow, making the exact same plastic suddenly look warmer. This is simply how ABS reacts to different lighting conditions in general. You will always be able to see both sides of this spectrum, depending on which lighting conditions you put them under.
Offline nadhole69
« Reply #45 on: Thu, 06 August 2026, 09:06:56 »
Yes, it’s the same lime color. It’s difficult to capture the exact shade in photos, and as GMK mentioned above, it can appear slightly different depending on the lighting. As a reference, Pantone 389C should be the same color used for GMK Toxic. From what I’ve seen, it tends to look more yellowish-lime under bright, warm lighting, while under neutral or cool natural light it appears a bit greener. Obviously, it’s not the same green as GMK Lime, but I can assure you that it’s definitely a shade of lime and not pure yellow.
« Reply #46 on: Tue, 11 August 2026, 18:45:11 »
appreciate the info  ;D
« Reply #47 on: Sat, 22 August 2026, 22:59:53 »
Yeah taking pics which shows the color accurately is such a hassle, especially across multiple caps
Offline nadhole69
Re: [IC] GMK CYL Evil Lime | GB 8th September!
« Reply #48 on: Sun, 23 August 2026, 17:36:28 »
Group By from 8th September to 8th October!
Offline nadhole69
« Reply #49 on: Sat, 29 August 2026, 07:43:32 »
Sorry for the delay, i just realized I hadn't replied here. I'm glad you like it; as for the deskmat, there aren't any plans unfortunately, but there will be collaborations with artisan makers—I've just sent the samples to Brocaps
