Author Topic: [GB] Metanoia - $399 - Live until June 30th!  (Read 16831 times)
Offline Alchemist Keyboards
    • Alchemist Keyboards
« on: Thu, 14 May 2026, 09:09:47 »
    INTEREST CHECK THREAD
    AKB Website
    AKB Discord
    Sale Info | Colourways | Photos | Specs | Compatibility | What's In the Box
    Sale Info
    • Alta Dolch - $399
    • Alta Luna - $399
    • Alta Corde - $399
    • Alta Labe - $575
    Vendors:
    Group Buy: May 29th - June 30th
    ETA: Late Q4 2026/Early Q1 2027
    Colourways:
    Alta Dolch
    Black-grey 6063 aluminium top and badge, warm grey 6063 aluminium bottom, dark grey PVD steel accents.
    Alta Luna
    Silver 6063 aluminium top and badge, dark grey 6063 aluminium bottom, brushed stainless steel and PVD steel accents.
    Alta Corde
    Wine red 6063 aluminium top, bottom and badge, red patina brass accents.
    Alta Labe
    Dark teal 6063 aluminium top, blue patina brass bottom and badge, silver 6063 aluminium accents.
    Prototype Photos:
    Alta Dolch
    Alta Luna
    Alta Corde
    Alta Labe
    Specs:
    • Layout: 65% w/single macro column
    • Mounting style: Top mount
    • Typing angle: 7°
    • Front height: 17.1mm (22.3mm EKH)
    • PCB: 1.6mm Solder or Hotswap + Fly DB
    • Built weight: 1710g-2210g
    • Plate options: Polypropylene (PP), Polycarbonate (PC), Carbon Fibre (CF), Aluminium (Aluminium)
    Features
    • Top-mounted Fly-daughterboard, for easy build assembly
    • Semi-screwless design (2 internal case screws, 5 external)
    • QMK/VIA compatible PCBs
    • Optional badge if you prefer an extra key (badge is included)
    Compatibility
    Both solder and hotswap PCBs will have the full compatibility shown below:
    The plate is also universal:
    In the Box
    • 1x Metanoia keyboard of choice (top, bottom, internal weight, outer weight, inner badge, outer badge)
    • 1x PCB of choice (solder or hotswap)
    • 1x Plate of choice (PC, PP, CF or Alu)
    • 1x Fly DB
    • 2x Molex cable
    • 4x AKB feet
    • 1x Microfiber cloth
    • 1x Hard carry case
    • Assorted hardware
    [/list]
    « Last Edit: Fri, 29 May 2026, 06:04:27 by Alchemist Keyboards »
    Re: [GB] Metanoia - $399 - Launching May 29th
    « Reply #1 on: Thu, 14 May 2026, 10:59:41 »
    Approved :thumb:
    Offline HubertThemad
    • * St. Jude Supporter
      • Podcast Links
    « Reply #2 on: Thu, 14 May 2026, 13:52:03 »
    Wait whoa $399!?!?! Why did I think it was pricier  :eek: GLWGB Jimmy!
    Edit - Misspelled name
    « Reply #3 on: Fri, 15 May 2026, 01:16:34 »
    I like the weight design
    Re: [GB] Metanoia - $399 - Live until June 30th!
    « Reply #4 on: Fri, 29 May 2026, 06:05:30 »
    GB now live!
