Author Topic: [GB] Nooir K2 - The Klavier II | GB Live!  (Read 21007 times)
Offline ClickClack.io
  • Find us on clickclack.io
    • clickclack.io
« on: Tue, 02 June 2026, 18:18:39 »
Follow-Up GB Now Live!
NOOIR K2 (Klavier-II)
by Nooir Studio
Welcome to Nooir
The NOOIR K2, also known as Klavier-II, is an ultra-premium 65% mechanical keyboard kit that fuses the layered structure of fine pianos with precision mechanical engineering. Born from Nooir Studio's philosophy of "precision mechanical art," the K2 introduces a host of industry-first features — most notably the WING 2.0 suspension system and a magnetic flip-open top case — wrapped in two distinct piano-inspired themes.
World's First Mechanical
The K2 introduces structural innovations never before seen in a mechanical keyboard, combining a synchronous suspension system with a fully magnetic, tool-free service experience.
Real User Experiences
Campaign Status
The Kickstarter campaign for the NOOIR K2 was completed successfully on May 22, 2026. A follow-up Group Buy is now live at ClickClack through June 10, 2026 — last chance to secure a unit before fulfillment.
Kickstarter: April 8 – May 22, 2026 (Completed Successfully)
Follow-Up Group Buy: Now through June 10, 2026
Fulfillment: Q4, 2026
Pricing:
• White Veil — $999
• Nocturne — $1,350 (Limited to 199 units globally)
Where to Buy
Worldwide: Click Clack — open through June 10, 2026
Two Themes
The K2 is available in two distinct aesthetics, each drawing from a different era of piano design.
White Veil
Inspired by the pure white bridal veil, White Veil embodies the simplicity and purity of the modern piano — clean lines, restrained elegance, and a quiet kind of refinement.
Nocturne
Nocturne draws from the classical pianos of the 18th and 19th centuries — intricate gold carvings, shimmering sheen, and rigorous structural elegance. Limited to 199 units globally.
Innovative Inner Case Structure — WING 2.0
At the heart of the K2 is the WING 2.0 Suspension System: double-sided wave springs paired with side slide rails allow the internal assembly to move synchronously, delivering a uniform typing feel across every key. Rotatable limit shafts let you switch between soft and hard typing modes — no tools required.
No Disassembly — Flip Open
The magnetic top case lifts open like the lid of a grand piano, revealing the complete mechanical linkage structure beneath. Service, swap, and customize without a single screw.
Materials & Craftsmanship
• 6063 aluminum alloy — lightweight, strong, and highly machinable
• 304 stainless steel — wear-resistant and corrosion-resistant
• 220-mesh zirconia particle surface treatment
• Laser engraving
• Powder coating
Comfortable Typing, Clean Sound
A multi-layer cotton damping combination attenuates keystroke noise and case resonance, producing a tone that's purer, fuller, and more comfortable across long typing sessions.
Essential Features
• Tri-Mode Connectivity: 2.4GHz wireless, Bluetooth, and USB Type-C wired
• Hot-Swappable: Tool-free switch replacement
• VIA Support: Real-time remapping and customization
• Multi-Platform: Mac, Windows, iOS, Android
Custom Switches & Keycaps
Star Year Amber Switches
Designed exclusively for the K2 — inspired by amber preserving stardust across time. Paired with PCB-integrated LED effects that bring the switch housing to life.
Pianist Keycaps
A piano-themed keycap set with alternating black/white legends that mimic piano keys, accented by string-element designs on selected positions.
Specifications
• Layout: 65%
• Mounting: WING 2.0 Suspension System (double-sided wave springs + side slide rails)
• Adjustable Typing Feel: Soft / Hard modes via rotatable limit shafts (no tools)
• Materials: 6063 Aluminum Alloy / 304 Stainless Steel
• Top Case: Magnetic Flip-Open
• Connectivity: 2.4GHz / Bluetooth / USB Type-C
• PCB: Hot-swap, VIA-supported
• Compatibility: Mac, Windows, iOS, Android
• Surface Treatments: 220-mesh zirconia particle finish, laser engraving, powder coating
• Weight: 10,886g per unit
Package Contents
• CNC Aluminum Case (Magnetic Flip-Open Top)
• PCB with Hot-Swap Sockets
• Mounting Plate
• Stabilizers
• Multi-layer Cotton Damping Kit
• USB Type-C Cable
• Documentation
Note: Switches and keycaps are sold separately. The Star Year Amber switches and Pianist keycap set are available as optional add-ons.
Options & Pricing
White Veil — $999
Timeline
• Kickstarter: April 8, 2026 – May 22, 2026 (Completed Successfully)
• Follow-Up Group Buy: Now through June 10, 2026 at Click Clack
• Fulfillment: Q4, 2026
Brand & Team
Nooir Studio approaches the mechanical keyboard as a piece of precision mechanical art — a discipline borrowed from the craft of fine instruments. The K2 is the result of that philosophy.
Follow ClickClack's IG for other new projects:
Offline Fraaaan
Re: [GB] Nooir K2 - The Klavier II | GB Live!
« Reply #1 on: Wed, 03 June 2026, 03:08:17 »
lmao
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #2 on: Wed, 03 June 2026, 11:07:42 »
sonion
