Author Topic: [IC] KAT Anaglyph  (Read 50998 times)
Offline brunosan_.
[IC] KAT Anaglyph
« on: Fri, 07 August 2026, 09:18:16 »
Hey everyone!
This is KAT Anaglyph, a set inspired by the red and cyan image separation used in classic anaglyph 3D images
The set will be manufactured by Keyreative in KAT profile.
Vendors, pricing, and dates are still being worked out.
RENDERS
Phidias
Ekleipsis
KITS
BASE KIT
ACCENT KIT
DESKMAT (In the works)
Actual KAT Anaglyph samples
WHAT'S NEXT?
Create the first physical samples ✔
Finish the initial kit designs ✔
Finish the keyboard renders ✔
Collect IC feedback
Make any necessary kitting adjustments
Confirm regional vendors
Finalize pricing
Finalize the group-buy dates
Prepare the final production samples
Updates and changes will be posted in this thread as the project moves forward.
INTEREST CHECK FORM
The form is the best place to leave feedback about the kits, pricing expectations, regional vendors, and anything you think should be changed.
FILL OUT THE KAT ANAGLYPH IC FORM
You can follow the project on:
« Last Edit: Fri, 07 August 2026, 23:02:10 by brunosan_. »
Offline brunosan_.
Re: [IC] KAT Anaglyph
« Reply #1 on: Fri, 07 August 2026, 09:18:52 »
reserved
