Author Topic: [IC] GMK Imperator  (Read 53490 times)
Offline Ephem_eral
[IC] GMK Imperator
« on: Thu, 27 August 2026, 00:40:25 »
This was another project I originally planned at the beginning of the year. At the time,
I wanted to try using metallic-colored plastic for the alpha keys of the Knight keycap set, but I ultimately decided against it because of the visible flow lines that can occur with injection molding.
However, this effect is much less noticeable when the metallic color is used for the legends. I also wanted to make a red keycap set, which eventually led to this project.
This set is based on the character Nero.
Below are the keycap renders. Please note that the colors may differ slightly from the actual color samples.
Standard plastic color
Since the Romans used Latin, I chose Japanese as the sublegend option to reflect the character’s origin in a Japanese game.
Metallic plastic legends
The metallic color can appear noticeably different depending on the lighting, so I made renders under different lighting conditions to show how the color changes.
I’m not sure if GMK’s sublegend printing can achieve a metallic effect.
For the novelties and other kits,
I’d like to wait for the GMK samples before making a final decision on how to produce them.
 I’ll update this IC in more detail after the Knight keycap GB.
Color Renders Under Different Lighting
Color Selection
F1-8X by Geonworks
Update Log
[2026/08/30]-Added color sample renders.
[2026/08/31]-Added a simple keyboard render.
[2026/09/03]-Added red Alpha and all-gold legend based on community feedback.
« Last Edit: Thu, 03 September 2026, 09:36:26 by Ephem_eral »
Offline Ephem_eral
Re: [IC] GMK Imperator
« Reply #1 on: Mon, 31 August 2026, 11:09:35 »
Update 1
Offline nadhole69
« Reply #2 on: Mon, 31 August 2026, 11:22:43 »
Just for let you know, GMK doesn't offer UV metallic
Offline Ephem_eral
« Reply #3 on: Mon, 31 August 2026, 11:38:05 »
Thank you for pointing this out. I’ll keep Latin as the main legends and explore some other options for the sublegends to see what works best.
« Reply #4 on: Mon, 31 August 2026, 11:54:54 »
Any chance for Alt Alphas for a full Red?
« Last Edit: Mon, 31 August 2026, 12:06:09 by MartinThePolarBear »
Offline meowoofun
  • Design Critic
« Reply #5 on: Mon, 31 August 2026, 23:42:11 »
Keep the alphas (with sub Katakana) as strickly gold instead of the green and you have a slam dunk! This set would have no problem hitting moq.
Offline nadhole69
« Reply #6 on: Tue, 01 September 2026, 03:03:36 »
you can eventually make the main metallic gold and the sub green, or just full gold by removing the green
Offline schizobovine
« Reply #7 on: Wed, 02 September 2026, 11:56:31 »
Roman and metallic plastic definitely have me interested!
Offline Ephem_eral
« Reply #8 on: Thu, 03 September 2026, 09:26:17 »
Thank you for the suggestion! I’ll look into the possibility of adding a red Alpha kit in a future update.
Offline Ephem_eral
« Reply #9 on: Thu, 03 September 2026, 09:28:08 »
That’s an interesting idea! I’ll consider both the gold + green option and the full gold option
Offline Ephem_eral
« Reply #10 on: Thu, 03 September 2026, 09:39:32 »
Update 2
Added renders for a red Alpha option and a gold legend based on community feedback.
Offline meowoofun
  • Design Critic
« Reply #11 on: Thu, 03 September 2026, 12:29:15 »
Oh man the gold alphas make the set look... well like gold! This set on a white board looks fire 🔥
Offline newzealot
« Reply #12 on: Sat, 05 September 2026, 11:06:18 »
I must say the pure red and gold keycaps really looks far superior. Can you make that the base instead?
With bolder font on the non-alpha keys as it currently looks unbalanced.
Well i guess that goes against your current concept.
