Author Topic: Tenkeyless.  (Read 5213 times)
Offline Shuki
Tenkeyless.
« on: Sun, 21 November 2010, 11:24:28 »
I have been considering buying a tenkeyless keyboard recently due to me realising my numpad is fairly redundant and the fact a full size keyboard takes up a lot of space on my desk.
The last time I looked at tenkeyless models the only ones which caught my attention were the filco boards as the base of the keyboard is pretty much the minimum necessary size to be able to fit the keys. Whereas other boards seem to have useless extra space at the top or bottom of the board which seems to defeat the point of having a space saving keyboard.
What options are there when it comes to tenkeyless considering I would only buy one which has cherry brown switches or cherry red (if any actually exist)? Are there any boards on the horizon which will have cherry reds?
The only other requirement is that the board would be at least a 4 key roll-over.
I would be grateful if anyone has any suggestions which fulfil these criteria. :)
« Last Edit: Sun, 21 November 2010, 11:27:56 by Shuki »
Offline kidchunks
Tenkeyless.
« Reply #1 on: Sun, 21 November 2010, 11:36:41 »
Best bet at this point would be pchome or armygroup for a tenkeyless with browns. EKB is currently out of tenkeyless with browns.You can check out the wiki for more information.
Topre || BS > *
my root : kidchunks[dot]com
Offline bakageta
Tenkeyless.
« Reply #2 on: Sun, 21 November 2010, 11:38:58 »
No cherry reds, unfortunately, so it'll have to be browns... Filco's tenkeyless models are all full NKRO with a ps/2 adapter, and 6 key rollover on usb.
Offline Shuki
Tenkeyless.
« Reply #3 on: Sun, 21 November 2010, 11:45:24 »
Currently I have a Deck 104key, a steelseries 6g and a Filco Brown (NKRO) so I guess I was looking for more of a change from my current keyboard than the size. However if there is no alternative I would be happy buying I tenkeyless Filco Brown.
@kidchunks  With armygroup will there be any problems with shipping to the UK?
« Last Edit: Sun, 21 November 2010, 12:43:41 by Shuki »
Offline kidchunks
Tenkeyless.
« Reply #4 on: Sun, 21 November 2010, 15:39:18 »
Quote from: Shuki;250150
The prices should be the same if not less. It cost $20 for my blank keys when I selected "america and others."
Topre || BS > *
Offline panda-R
Tenkeyless.
« Reply #5 on: Sun, 21 November 2010, 15:44:02 »
The Cherry 1863/1865's are so nice but the prices on them are crazy!
DO YOU FEEL THE BEAT? I DO.
One Keyboard to DOOM them all, REALFORCE.
Offline kidchunks
Tenkeyless.
« Reply #7 on: Sun, 21 November 2010, 16:27:56 »
Quote from: Shuki;250244
Narrowed it down to either
http://translate.google.co.uk/translate?hl=en&sl=auto&tl=en&u=http%3A%2F%2Fworld.pchome.com.tw%2F%3Fmod%3Ditem%26func%3Dexhibit%26IT_NO%3DDCAH0X-A50118368%26c%3DA05%26tm%3Du
http://translate.google.co.uk/translate?hl=en&sl=zh-TW&u=http://world.pchome.com.tw/%3Fmod%3Ditem%26func%3Dexhibit%26IT_NO%3DDCAH0X-A50461659%26c%3DA05%26tm%3Du&ei=oZrpTL2kJY2IhQeMmIC4DA&sa=X&oi=translate&ct=result&resnum=1&ved=0CBwQ7gEwAA&prev=/search%3Fq%3Dhttp://world.pchome.com.tw/%253Fmod%253Ditem%2526func%253Dexhibit%2526IT_NO%253DDCAH0X-A50461659%2526c%253DA05%2526tm%253Du%26hl%3Den%26biw%3D1680%26bih%3D867
Ducky is cheaper, any real differences I should know about?
Also I assume this is Taiwanese dollars?
Ducky is made a little different than filco hence the cheaper price. Also from what I seen on some of the ducky boards they are not all cherry browns but a mix of black,brown and blue switches.
If money isn't a problem, go with the filco then get the ducky later ^^
Topre || BS > *
Offline Shuki
Tenkeyless.
« Reply #8 on: Sun, 21 November 2010, 16:30:34 »
Really?
I was reading this and it kind of threw me off.
"The trigger shaft key way of tea is 2.0mm, the pressure grams of 56 ± 20g (2.0 oz ± 0.7 oz), life expectancy 50 million times, MX-axis in the most complex kind of work, the combination of green and black shaft axis characteristics, pressure quite a few grams and green axes, avoiding the long axis of the black hand fatigue problems, using as a two-step with the green axis travel, except the voice of the lack of CLICK, key sound moderate, Single life 50 million times, taking into account office and games."
Offline kidchunks
Tenkeyless.
« Reply #9 on: Sun, 21 November 2010, 16:37:02 »
Quote from: Shuki;250247
Really?
Looks like it has a mixture of switches. Is that what you're looking for?
Topre || BS > *
Offline Shuki
Tenkeyless.
« Reply #10 on: Sun, 21 November 2010, 16:43:55 »
No, in fact if it has anything but brown switchs I don't think I'll get one.
Are all the boards a mixture of switches or do some have all brown?
Offline kidchunks
Tenkeyless.
« Reply #11 on: Sun, 21 November 2010, 16:57:12 »
Quote from: Shuki;250251
All the dk1087 models have a mixture of switches from what I've seen.
Topre || BS > *
Offline panda-R
Tenkeyless.
« Reply #12 on: Sun, 21 November 2010, 16:58:04 »
NO! You can get duckys with one switch type. Just look at the pictures below and you'll see what the board uses.
For your reference.
Tea = Brown
Green = Blue
Black = Black
Offline Shuki
Tenkeyless.
« Reply #13 on: Sun, 21 November 2010, 17:06:31 »
Would I be correct in assuming this is 100 percent browns?
Ones with both seem to show the two types, like brown on the letter keys and blue on insert home page up etc.
Offline kidchunks
Tenkeyless.
« Reply #14 on: Sun, 21 November 2010, 17:07:18 »
Quote from: panda-R;250256
For your reference.
Tea = Brown
Green = Blue
Black = Black
You're right, I stand corrected. Finally found a review that showed the internals of a dk1087
http://kbc.5d6d.com/thread-2077-1-1.html
« Last Edit: Sun, 21 November 2010, 17:09:41 by kidchunks »
Topre || BS > *
Offline laden3
Tenkeyless.
« Reply #15 on: Sun, 21 November 2010, 17:10:41 »
Buying a Ducky 1087 right now is actually not recommended because the tab at the left of the arrow keys can break easily if the keyboard isn't handled carefully during the delivery. If you really want one, it is probably better that you wait until they come out with the newer models.
I rrrove brrracks.
Offline Shuki
Tenkeyless.
« Reply #16 on: Sun, 21 November 2010, 17:13:26 »
I guess you've made up my mind for me then.
I'll probably order a tenkeyless filco (w browns) in the next few days.
Offline laden3
Tenkeyless.
« Reply #17 on: Sun, 21 November 2010, 17:16:42 »
I rrrove brrracks.
Offline panda-R
Tenkeyless.
« Reply #18 on: Sun, 21 November 2010, 17:23:24 »
Quote from: Shuki;250260
you are correct sir!
Offline J888www
Tenkeyless.
« Reply #19 on: Sun, 21 November 2010, 17:42:00 »
Suddenly so much Tenkeyless to choose, now to decide which has the best build quality.
I would still like a Buckling Spring, if only Unicomp would decide to manufacture a Space Saver Tenkeyless.
The Duckeys with two types of switches are called 80%. Silly really, why settle for 80% of a keyboard when you can buy 100% for the same price?
« Last Edit: Sun, 21 November 2010, 19:42:22 by J888www »
Often outspoken, please forgive any cause for offense.
Thank you all in GH for reading.
Keyboards & Pointing Devices :-
[/FONT]One Too Many[/COLOR]
Offline kidchunks
Tenkeyless.
« Reply #20 on: Sun, 21 November 2010, 17:49:38 »
Quote from: J888www;250273
Suddenly so much Tenkeyless to choose.
Same, they would make a killing if they had tenkeyless version available.
Topre || BS > *
Offline laden3
Tenkeyless.
« Reply #21 on: Sun, 21 November 2010, 17:56:28 »
geekhack should buy the patent from Unicomp, then, we make our own keyboards
I rrrove brrracks.
Offline J888www
Tenkeyless.
« Reply #22 on: Sun, 21 November 2010, 18:00:23 »
Curious as to the value of Unicomp.
Offline msiegel
Tenkeyless.
« Reply #23 on: Sun, 21 November 2010, 18:13:50 »
Quote from: laden3;250276
the buckling spring patent has expired. unicomp owns the tooling for manufacturing the parts.
that said, i vote for a version with capacitive switches :)
hmm, i wonder how hard/expensive it would be to make accurate 3d models of the barrels and flyplates, design new tooling, and have it cnc milled. i'll bet our friends at signature plastics could do the injection molding.
Offline laden3
Tenkeyless.
« Reply #24 on: Sun, 21 November 2010, 18:24:49 »
I guess someone from China can do that if u can convince him/her that making a buckling spring keyboard is profitable...
I rrrove brrracks.
Offline theferenc
Tenkeyless.
« Reply #25 on: Sun, 21 November 2010, 18:52:28 »
So, just for reference, trusting google translate on Chinese is like trusting a hungry dog to keep intruders away from aging meat.
The structure of the language is just so vastly different from English and the Romance languages, at least, that even if it got translated literally, 100% accurately, it would likely still make little sense to you.
The ducky you linked to is 100% brown switches, according to the page. The section you quoted is, near as I can tell, simply saying that brown switches have the best characteristics of the blues and blacks, without the annoying sounds of the blues, or the fatigue of the blacks.
Maybe someone who is better at reading traditional chinese can clarify it further. I'm only passable at simplified, and traditional is, obviously, harder for me to read.
Offline J888www
Tenkeyless.
« Reply #26 on: Sun, 21 November 2010, 19:36:40 »
Yes, the hungry dog can definitely be trusted to keep others from scoffing his food.
Offline msiegel
Tenkeyless.
« Reply #27 on: Sun, 21 November 2010, 19:48:59 »
dude, who raided the fortune cookie factory
Offline msiegel
Tenkeyless.
« Reply #28 on: Sun, 21 November 2010, 19:54:17 »
:lol:
how do you say "golf clubs" in mandarin? XD
Offline panda-R
Tenkeyless.
« Reply #29 on: Sun, 21 November 2010, 20:31:29 »
Quote from: ripster;250324
You say "Tiger Woods and wife".
hmm i don't know what is more lulz, the black lego tiger woods or his wife that has a mustache. She must be participating in Movember.
Offline bakageta
Tenkeyless.
« Reply #30 on: Sun, 21 November 2010, 20:31:35 »
Ripster, you have the most ridiculous lego collection...
