Author Topic: Filco Tenkeyless Owners  (Read 5679 times)
Offline kidchunks
« on: Thu, 25 November 2010, 09:41:56 »
I've recently stumbled upon a minor issue with my tenkeyless(browns).
I've noticed that my "up" arrow key seems to rub against the body of the keyboard. I noticed it shortly after messing with the key caps I got from pchome (fugly purples).
Can see the gap on the left side of the W
I put back the black and it seems a little normal.
Now this is where it gets interesting, I took a shot with all the caps off and noticed that the switch and body aren't position centered to one another. It looks as though the up arrow switch is more towards the right.
Finally took a shot of the up arrow key attached only and it indeed does grind.
Don't mind the marks under the cap..f&^ker was bein a hoe and didn't want to come off. :tongue:
It doesn't effect the boards functionality in anyway. I was just curious to see if anyone else has this issue with their board.
Happy Holidays!
Topre || BS > *
my root : kidchunks[dot]com
Offline sixty
    • http://deskthority.net
« Reply #1 on: Thu, 25 November 2010, 09:46:37 »
Just checked mine here at the office, same indeed. Tiny gap between the switches when aligning a ruler to the edge of the switch.
Offline tjweir
« Reply #2 on: Thu, 25 November 2010, 10:26:19 »
Unscientific test of the Tenkeyless Brown shows the same thing.  The right side of the UP arrow is *very* close to the frame.
Offline elbowglue
« Reply #3 on: Thu, 25 November 2010, 10:42:56 »
That sucks.  Did you buy from elitekeyboards?  I would send it back.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline kidchunks
« Reply #4 on: Thu, 25 November 2010, 10:43:06 »
Quote from: sixty;252289
Is yours with blue switches? I'm wondering if its only the browns that are effected.
Topre || BS > *
Offline Twitchy
« Reply #5 on: Thu, 25 November 2010, 10:46:51 »
Just pulled the ▲ cursor key from my 105 key with browns. I got funny looks from my colleagues but saw a similar (if less pronounced) off-centred "ness".
Stuff
Filco Majestouch FKBN88M/UKB2
Topre Realforce 91UBY
Razer Imperator + Razer Vespula[/COLOR]
Offline Uninstall
« Reply #6 on: Thu, 25 November 2010, 10:51:09 »
The problem only happens when you use the bigger replacement keys right?
Offline kidchunks
« Reply #7 on: Thu, 25 November 2010, 10:51:42 »
Quote from: ripster;252314
If you look carefully on a HHKB you will see the keys are not exactly aligned.
Solution?
Don't  look so carefully.
LOL yea I didn't notice it until I swapped it out with brighter key caps.
Quote from: Uninstall;252316
Nah that black key is the "up" arrow that came with the board and it slightly rubs.
AGAIN! It doesn't hinder the board in anyway so no freak outs plz...
« Last Edit: Thu, 25 November 2010, 10:56:36 by kidchunks »
Topre || BS > *
Offline Soarer
« Reply #8 on: Thu, 25 November 2010, 10:58:16 »
My Tenkeyless with blues has the same issue, but I hadn't noticed it at all before, even when swapping all the keycaps. The cursors are to the right compared to the hole in the case. I wondered if it was just that the pcb wasn't positioned correctly, but no, the main alpha area is to the left compared to its hole (the tab etc keys are about as close to the left edge as the up cursor is to the right edge).
Offline a_fluffy_kitten
« Reply #9 on: Thu, 25 November 2010, 11:30:37 »
Both of mine look like yours - the up arrow key is shifted a little to the right.
2x Filco Blue Tenkeyless (and boy are they nice)
Offline wanabe
« Reply #10 on: Thu, 25 November 2010, 11:52:24 »
same thing with my filco brown tenless.  it bugged me at first, but i dont think its a big deal.
Offline KikassAssassin
« Reply #11 on: Thu, 25 November 2010, 12:47:20 »
My Filco brown tenkeyless is the same way. I didn't even notice it until you pointed it out, and it doesn't affect the key travel in any way, so I'm not worried about it.
Offline panda-R
« Reply #12 on: Thu, 25 November 2010, 13:08:56 »
Solution?
this is a good ideology to live by.
the less you know, the better off you are!
DO YOU FEEL THE BEAT? I DO.
One Keyboard to DOOM them all, REALFORCE.
Offline panda-R
« Reply #13 on: Thu, 25 November 2010, 13:10:54 »
oh i just checked my Filco Tenkeyless blues and the up arrow key is also misaligned! never knew until today... thanks a lot, you ruined my life!
Offline BlueRain
« Reply #14 on: Thu, 25 November 2010, 13:15:24 »
Quote from: panda-R;252342
Quote from: panda-R;252344
Should've followed your own advice...
DON'T LOOK!!!! /sigh you looked... :doh:
Offline msiegel
« Reply #15 on: Thu, 25 November 2010, 13:16:33 »
Don't  look
+1; it's Heisenberg compensation:
If the keys *were* exactly aligned, you could never tell how fast you were typing ;)
Offline kidchunks
« Reply #16 on: Thu, 25 November 2010, 14:58:32 »
lol glad I could help :tongue:
Topre || BS > *
Offline RoboKrikit
« Reply #17 on: Thu, 25 November 2010, 15:06:11 »
My Filco Tenkeyless w/blues is the same.  I noticed it when I put the orange WASD in the arrow key slots.  It doesn't stand out with the black keys, and I don't really notice it when pressing Up.
Lovely day for a GUINNESS
Offline nathanscribe
« Reply #18 on: Thu, 25 November 2010, 15:58:59 »
At the risk of stating the obvious, it doesn't appear to be a misaligned key, but a misaligned cutout.  Follow the lines of the hole around the key up to the HOme & End column, and you'll notice the gap around the up arrow key should be a little wider on the right, that's all.
My Tenkeyless w/blues is like this.  No trouble so I don't worry.
Conquering the world with BASIC since 1982
« Reply #19 on: Thu, 25 November 2010, 16:00:56 »
woody
  •  Guest
« Reply #20 on: Fri, 26 November 2010, 09:31:10 »
Points for the Filco - everything produced under same alignment. Now that's quality!
And I'm not kidding at all.
Offline Deverica Wolf
  • My name is Hack, Geek Hack.
    • Head-Fi
« Reply #21 on: Fri, 06 January 2012, 13:46:55 »
Quote from: ripster;252328
Keys are all identical. Optical illusion sometimes makes people think differently.
And look at the ESC key on a Model M sometime.  It's offcenter too.
HEY! I just noticed that on my Unicomp. MUST DESTROY! :mad2:
UNICOMP.Spacesaver BS  |  FILCO Majestouch-2 TKL  |  FILCO Majestouch-2  [-_-]~ TKL  |  FILCO Majestouch-2 TKL
FILCO Majestouch-2 TKL  |  Deck Legend - ToXic  |  CHERRY Touchboard ITA
Offline Linkas
« Reply #22 on: Fri, 06 January 2012, 14:41:26 »
In every thing which I bought I can find build disproportions. It drives me crazy  but I think everybody has to get used to it and as ripster said: "not look too carefully".
G80-3000
Offline Gin
« Reply #23 on: Fri, 06 January 2012, 16:03:54 »
Same for the left side of the main letter row of the keyboard. The left side of the case hugs the left side of the main area more closely than the right side.
    • Head-Fi
« Reply #24 on: Fri, 06 January 2012, 18:16:15 »
I swear there's a conspiracy here.
I'm switching to Mircosoft Keyboards. :high5:
Offline NorrisB
« Reply #25 on: Fri, 06 January 2012, 18:20:45 »
doesnt this fall under the McRip Effect?
Offline nhwhaup
« Reply #26 on: Fri, 06 January 2012, 18:29:47 »
Just checked my Filco Limited with Reds TKL and don't see this issue.  My up arrow key is centered very nicely and I also have the keys switched out with PBT white key caps.  No rubbing on my Filco.  Must have broken the mold with the Limited version.
Current in order of preference:  RealForce 87U Silent White with variable weighted keys X 2, Filco Majestouch 2 Tenkeyless with Linear Reds, Filco Number-pad, Poker with Linear Reds
Sold or returned:  Multiple Microsoft and Logitech keyboards, Das Keyboard Silent, Cherry 6140, RealForce 103UB, RealForce 86U, Filco Majestouch 2 full sized with Linear Reds
Offline Zet
« Reply #27 on: Sat, 07 January 2012, 10:50:57 »
I'll give it a check to my Filco TKL with blues on the office later today, if it's the case, you are doomed x_X I don't want to think about it's imperfection either
Offline Surly73
« Reply #28 on: Sat, 07 January 2012, 12:05:45 »
My Filco MJ1 w/ browns purchased from PCHome about 9 months ago also shows this slight alignment issue.  There's never been any rubbing and I didn't even notice until I saw this thread.    In my case I could say that the up/down switches align with one another, but the keycap of the up arrow ends up with less space to the casing on the right than the left.
