Author Topic: Back to my Xxxxxxx and loving it.  (Read 5951 times)
Offline ricercar
  • mostly abides
« on: Tue, 07 December 2010, 19:51:35 »
Back to my Kinesis Contour and loving it. I started a project about a year ago, to replace the mylar keys with Cherry browns like the rest of the board. Once the old F keys were disabled, the keyboard stopped returning to my desk between mod sessions. One thing followed another with technical delays compounding delays from family concerns.
Ooh, la, la! This is what typing should be. In a year, I had forgotten why I consider the Contour to be the ultimate keyboard. Hand position, movement required (i.e. lack thereof), and Cherry brown tactile. Orgasm.
Offline Lanx
« Reply #1 on: Tue, 07 December 2010, 20:12:27 »
oh i hear you on the mod for a few hours then make it work as a daily driver every day!
Offline theferenc
« Reply #2 on: Tue, 07 December 2010, 22:56:48 »
You know, I was just going to comment that I'm still having trouble getting used to my kinesis, and I notice that I made your sig.
That's a bit embarrassing, actually. Ah well. It's still true!
Offline Lanx
« Reply #3 on: Wed, 08 December 2010, 01:53:58 »
i've readjusted my typing in preperation for my new v2 mod, my only issue was really the "c" button i used my index, now i use my middle finger 90% of the time.
Offline Sam
« Reply #4 on: Wed, 08 December 2010, 02:02:44 »
I'd like to try a Kinesis Advantage or similar, but I do not like Cherry Browns.  Have you opened it up?  If so, do you think it would be a lot of work to replace the switches with Cherry Blues?  Ideally, I'd like to pop in some IBM buckling (or beam) springs into that form-factor to try it, but I know that would be a major undertaking.
Offline Azuremen
« Reply #5 on: Wed, 08 December 2010, 04:02:16 »
Hmm, making looking forward to using my Kinesis Pro again a bit, now that I've cleaned it.
The lack of hand travel is great though. And the backspace key.
Filco Tenkeyless Tactile Click ~ Kinesis Professional ~ White label Model M ~ DX HHKB Killer
Mionix Naos 5000 ~ Logitech Mx518
Flickr
Offline InSanCen
« Reply #6 on: Wed, 08 December 2010, 05:37:14 »
I keep coming back to my M13. For whatever reason, I just don't get on with other boards for extended periods of time (Other than the AT F, but I need to sort out the Spacebar now that I have a new one, thanks HaaTaa!), and back out it comes.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline ricercar
  • mostly abides
« Reply #7 on: Wed, 08 December 2010, 05:55:29 »
The M13 is a great board, and I keep pulling mine out and using it for a day or two. It's the only buckling spring board I use any more.
Offline itlnstln
« Reply #8 on: Wed, 08 December 2010, 07:41:58 »
I'm back on crack, and I'm huffin' it!
Offline theferenc
« Reply #9 on: Wed, 08 December 2010, 08:05:32 »
Quote from: Sam;259409
You mean I'm not the only one who dislikes them?
Offline ricercar
  • mostly abides
« Reply #10 on: Wed, 08 December 2010, 09:54:47 »
There's a hard-to-load project page on otd.kr in which a korean installs Cherry reds, mechanical FKeys, and a trackpad into his Contour, so we know switch swapping is possible. I've also dreamed of a Cherry blue Contour, but I ended up selling my second Contour before starting that mod.
EDIT
Even my PDF print from the page didn't create properly. :-(
« Last Edit: Wed, 08 December 2010, 10:12:37 by ricercar »
Offline Lanx
« Reply #11 on: Wed, 08 December 2010, 09:58:07 »
you want to replace the browns with blues? mass desoldering doesn't take long, neither does resoldering.
Offline bionicroach
« Reply #12 on: Wed, 08 December 2010, 10:10:45 »
Wow, that Cherry Red mod is epic!  I particularly enjoyed this line from the Google Translation to English:
Contains a ***** went.
LIMKB and the best inventions of the 20th century (!) If this was a glue gun
Motkkul task was to dream.
"Ahkkwanim respect. ^ ^"
Can scroll through some of the pressure.
Offline elbowglue
« Reply #13 on: Wed, 08 December 2010, 10:45:00 »
Thats the Korean version of Ripster.
BTW that's what Ripster sounds like to the Koreans who are perusing this forum.
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline itlnstln
« Reply #14 on: Wed, 08 December 2010, 10:57:27 »
I'll tell you what I am neither loving nor back to: my ex.
Offline keyboardlover
« Reply #15 on: Wed, 08 December 2010, 11:25:12 »
Quote from: itlnstln;259568
Whoah is that her? Baby got back! ;)
« Reply #16 on: Wed, 08 December 2010, 11:34:02 »
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #17 on: Wed, 08 December 2010, 11:42:10 »
no man, the other one — the one in yellow is itinstin.
Offline shrap
« Reply #18 on: Wed, 08 December 2010, 13:10:15 »
Those are some crazy-looking keyboard internals.
Offline itlnstln
« Reply #19 on: Wed, 08 December 2010, 13:11:03 »
He's right.  I'm on the phone with my ex in that pic.  Xs, are you going to make our court date?  The judge said I get full custody of the kids.  All 12 of them.  I hope Wal-Mart is back in stock on Ramen by next week or I'm going to want more child support.
Offline Azuremen
« Reply #20 on: Wed, 08 December 2010, 14:56:07 »
Quote from: shrap;259629
Yeah they are pretty zany.
And I love that mod that the Korean did. I was thinking how great it would be to have a trackpad build into the Kinesis.
Flickr
Offline xsphat
  • Enlightened
« Reply #21 on: Wed, 08 December 2010, 14:59:11 »
Quote from: itlnstln;259631
No man, I have a date with three underage hookers and a decent bag of meth.
Offline xsphat
  • Enlightened
« Reply #22 on: Wed, 08 December 2010, 15:00:54 »
Oh yeah, cool keyboard mod too. I always wanted to test drive one of those keyboards, but sadly I may never get the chance. If a member has one I could try out, I'll pay shipping both ways and maybe even buy the thing off you. PM me.
