Author Topic: Remove Filco Keys?  (Read 5630 times)
Offline imagine7xy
Remove Filco Keys?
« on: Tue, 14 December 2010, 20:47:33 »
I ordered a Filco Majestouch with WSAD but never received the key puller, I am trying to figure out how to take the keys out without one, is it possible? I contacted elitekeyboards about it, and getting the key puller as it was supposed to come but wondering if I have to wait.
Offline Kairxa
Remove Filco Keys?
« Reply #1 on: Tue, 14 December 2010, 20:50:14 »
Yes it is. But it will be hard, very hard. Try to hold and wiggle, while pulling the keycaps.
Offline RoboKrikit
Remove Filco Keys?
« Reply #2 on: Tue, 14 December 2010, 20:53:47 »
I bent a paperclip into a squared-off U shape and used it to remove keys before my key puller arrived.
Lovely day for a GUINNESS
Offline Azuremen
Remove Filco Keys?
« Reply #4 on: Tue, 14 December 2010, 21:12:15 »
Dental Floss. Sounds crazy but you can loop it under the keys and run very little risk of scuffing or scratching anything.
Filco Tenkeyless Tactile Click ~ Kinesis Professional ~ White label Model M ~ DX HHKB Killer
Mionix Naos 5000 ~ Logitech Mx518
Flickr
Offline theferenc
Remove Filco Keys?
« Reply #5 on: Tue, 14 December 2010, 21:39:53 »
I generally use the back of a spoon. The handle end. But a butter knife would work, too. Just more risk of damage to the keys.
Offline isp
Remove Filco Keys?
« Reply #6 on: Tue, 14 December 2010, 22:23:54 »
do take care, and make sure to wiggle a lot
hhkb
Offline leotnnz
Remove Filco Keys?
« Reply #7 on: Tue, 14 December 2010, 22:50:34 »
thin electric wire.
or a diy puller with stainless steel wire.
http://www.pcwaishe.cn/viewthread.php?tid=29380&highlight=%B0%CE%BC%FC%C6%F7
