Author Topic: Headphone Thread.  (Read 1847856 times)
Offline bavman
Re: Headphone Thread.
« Reply #1400 on: Sun, 16 December 2012, 22:42:47 »
So many options, so little money lol
Will my O2 amp drive the 600 ohm versions of the dt 880/990 well?
« Last Edit: Mon, 17 December 2012, 00:31:49 by bavman »
Offline thegunner100
  • (╯'□')╯︵</3 ノ( '-'ノ)
    • The Emotional Skyscraper
« Reply #1401 on: Mon, 17 December 2012, 05:39:54 »
I'd say that if you don't mind the clamp of the pro version, then just get it to save the money. Otherwise if you don't mind buying used, there's a like-new dt990/600 on Amazon for $194.02. The O2 will definitely get you enough volume for 600 ohm but I'm not sure if it's ideal.
Input Devices:CM QF Rapidx2 ~ REALFORCE 87uw 45/55g ~ Logitech G5v2 ~ Wacom Bamboo CTH-460
Audio Setup: look me up on head-fi
Check out my blog on touhou/doujin music, audiophile gear, and doujin games!
Offline TheProfosist
  • Custom Layouts Only!
« Reply #1402 on: Mon, 17 December 2012, 07:18:50 »
I know that this is a headphone thread but I am looking for a nice headset that will properly interface my audio equipment, be a high quality mic, and be a great set of just headphones when needed. I my older DAC is a Edirol FA-66 and the one im currently using is a Focusrite Scarlett 2i4. So far I have found the Beyerdynamic DT 797 PV but was wondering if there are any better or more preferred option out there.
« Reply #1403 on: Mon, 17 December 2012, 18:43:58 »
My Grado SR80i. Love these babies.
« Reply #1404 on: Mon, 17 December 2012, 20:53:16 »
Beyer MMX 300, nearly the lowest price in Amazon's history:
http://www.amazon.com/Beyerdynamic-MMX-300-Premium-Microphone/dp/B001BYMZ5W/ref=sr_1_1?ie=UTF8&qid=1355799040&sr=8-1&keywords=Beyerdynamic+MMX+30
http://camelcamelcamel.com/Beyerdynamic-MMX-300-Premium-Microphone/product/B001BYMZ5W
Re: Re: Headphone Thread.
« Reply #1405 on: Mon, 17 December 2012, 21:45:28 »
thats a standard pc headset did you look at what I had and what ive found so far?
« Reply #1406 on: Mon, 17 December 2012, 22:17:38 »
Im not too familiar with recording equipment, but the MMX 300 might be good for others here.
Offline modulor
« Reply #1407 on: Mon, 17 December 2012, 23:51:19 »
FYI, the MMX300 is a DT770 Premium 32ohm...it would be better to get a standard DT770 80ohm (or higher impedence if you plan on amping) and an additional clip on mic, or if you're feeling crafty, you can make your own attachment:  http://www.head-fi.org/t/195242/the-ultimate-gaming-headset-beyerdynamic-dt-770-microphone-mod
NP-R (soon) | 21XX | Leggera-G Acrylic | Classic TKL | Frog TKL 8K | GH60revC | R1 86U 45g | G80-2100HDU | G80-3000HAU | G80-3700HAU | QFR V1 | FC200R | Poker X | G80-11900LUMEU
Offline ChaoticKinesis
« Reply #1408 on: Tue, 18 December 2012, 01:28:52 »
I just received my ModMic today, to complement my DT880s. I think I'll stick with that.
« Reply #1409 on: Tue, 18 December 2012, 08:01:30 »
Ahh ok I didn't realize that the MMX 300 was the dt770/32.
I posted the link to that in another thread a while back, how is it?
« Reply #1410 on: Tue, 18 December 2012, 12:32:54 »
Well I'm coming from the Zalman ZM-Mic1. The ModMic is much more sensitive and sounds clearer, so it does not require putting it so close to my mouth. I'm really liking it so far, though I've never really had a higher-end mic to use as reference.
« Last Edit: Tue, 18 December 2012, 13:18:19 by ChaoticKinesis »
Offline tauburn
« Reply #1411 on: Tue, 18 December 2012, 14:32:22 »
These things have held up pretty well.  Good value.
I have the MDR-7506
which is the same headphone but with a blue sticker.
« Reply #1412 on: Tue, 18 December 2012, 14:35:54 »
I have the MDR-7506
im heard that the 7506's have even less bass which make them not as flat and slightly more sharp because the cone is stiffer as they assume their going to be used more
Offline swagpiratex
« Reply #1413 on: Tue, 18 December 2012, 15:35:11 »
Place my order for a ModMic last week, heard today that they received a new shipment and we should be getting them either this or next week :D
Offline tauburn
« Reply #1414 on: Tue, 18 December 2012, 20:04:53 »
I have the MDR-7506
nahh i've owned both. theyre the same thing.
« Reply #1415 on: Tue, 18 December 2012, 20:14:01 »
I have the MDR-7506
ever take one apart?
Offline tauburn
« Reply #1416 on: Tue, 18 December 2012, 22:04:27 »
I have the MDR-7506
I took my v6 apart after it broke. why?
« Reply #1417 on: Tue, 18 December 2012, 22:05:46 »
I have the MDR-7506
just wondering if you comared the 2 inside because i believe their replacement part number are different too.
« Reply #1418 on: Thu, 20 December 2012, 14:26:24 »
Just got my T70 yesterday and damn it pretty much sounds like a closed version of the dt880/600 but with MUCH better imaging and detail, though smaller soundstage. I finally put some gel pads on the T70 this morning and WOW, the sub-bass response improved pretty drastically but the treble levels went up a bit as well. Hopefully the burn-in will tame some of that treble.
Offline Vintage
« Reply #1419 on: Thu, 20 December 2012, 16:40:39 »
I have Astro A40s from 2010. The sound quality is pretty good.
CM QFR w/ MX Reds  | Logitech G900
Offline tauburn
« Reply #1420 on: Fri, 21 December 2012, 09:56:12 »
I have the MDR-7506
no i havent taken both apart.
« Reply #1421 on: Sat, 22 December 2012, 10:30:37 »
Helping my friend sell his like-new Beyerdynamic Custom One Pro for $160 shipped if anyone is interested:
http://geekhack.org/index.php?topic=29455.0
Also, I actually think I prefer the T70 with the stock micro-velour pads rather than the gel pads. Less piercing highers, clearer mids, but a bit less bass and isolation. They also don't get hot and sweaty like the gel pads do.
Offline takaki
« Reply #1422 on: Fri, 28 December 2012, 11:55:11 »
Even a cmoybb can drive 600 ohms headphones to loud volume levels, but the word well could also mean a whole new ball park of improvements.
Offline lazerpointer
  • ya gotta stay phresh
« Reply #1423 on: Fri, 28 December 2012, 12:35:48 »
Just got a pair of Logitech G930 for xmas and God they are the best headphones I've ever used. Just great great sound, and you can switch to 2.0 if you don't like 7.1 like me. Also the software it comes with will change your voice on teamspeak lol great for trolling.
« Last Edit: Tue, 08 January 2013, 11:30:51 by Flip »
i type, therefore i geekhack
Offline codymaust
« Reply #1424 on: Fri, 28 December 2012, 23:20:21 »
Got these for Christmas, and for $20 they are hard to beat!
http://www.amazon.com/MEElectronics-M6-CL-MEE-Noise-Isolating-In-Ear-Headphones/dp/B0038W0K2U
Unfortunately, I can't get the cable to straighten out completely so it looks like I have spaghetti hanging from my head
Offline Atakp
« Reply #1425 on: Sun, 30 December 2012, 14:55:31 »
Here's some horrible crappy cellphone pics with crappy lighting of what I have on my desk at the moment.
Offline sammsorensen
« Reply #1426 on: Sun, 30 December 2012, 21:14:31 »
Sennheiser HD555s with the 595 mod. I've considered marrying them.
You should consider selling them, or retiring them while they still work.. Their value is only going to increase! Recently sold my 4 year old pair for more than I bought them for.
In regards to this thread, I am currently using Beyerdynamic DT 990 premium 250 ohm.
Filco MJ2 TKL brown
Offline takaki
« Reply #1427 on: Tue, 01 January 2013, 02:11:02 »
you sir belongs to head-fi hahaha.
Offline RougeR
« Reply #1428 on: Wed, 02 January 2013, 17:40:54 »
got a pair of D2Ks
just got my modmic for them
Buckling spring warrior!
Offline Atakp
« Reply #1429 on: Wed, 02 January 2013, 21:48:21 »
lol I do spend a fair amount of time lurking over there as well  :)
Offline ihasmario
« Reply #1430 on: Sun, 06 January 2013, 12:53:39 »
Self explanatory.  :)
Offline bigsneakysnake
« Reply #1431 on: Sun, 06 January 2013, 16:29:57 »
Pretty standard choice, but an amazing one nonetheless. I like these better than the MDR-7506s I had for a couple years.
Offline Alessandro
  • The Price Is Right
    • Alessandro's Sweet Shop
« Reply #1432 on: Sun, 06 January 2013, 16:36:09 »
Hey atakap, is that the little dot mk1 or 2, and how do you find it in terms of general quality?
« Reply #1433 on: Sun, 06 January 2013, 16:42:26 »
That's a WA6. Quite a price & performance gap between the little dots and WA6 :P
http://www.wooaudio.com/products/wa6.html
Offline Alessandro
« Reply #1434 on: Sun, 06 January 2013, 16:52:49 »
Silly me! Looked a lot like the LD2 on that photo.
Offline Atakp
« Reply #1435 on: Sun, 06 January 2013, 18:22:43 »
That's actually a WA3 with a vintage Tung Sol 5998 tube. It resembles the sophia princess tube on the WA6 though. I've never owned an LD so I can't comment on that.
Offline KangarooZombies
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #1436 on: Sun, 06 January 2013, 20:07:28 »
Wow those are some petty ritzy headphones...
Having a bad day?
Offline missalaire
  • Great Finder of Great Finds
« Reply #1437 on: Mon, 07 January 2013, 15:45:54 »
Offline Firefly303
« Reply #1438 on: Mon, 07 January 2013, 19:17:08 »
haha EA. reminds me of the $1,000 HDMI cord
« Reply #1439 on: Mon, 07 January 2013, 19:51:41 »
  • HHKB Pro
  • ʕ•ᴥ•ʔ
« Reply #1440 on: Mon, 07 January 2013, 23:17:39 »
Having a bad day?
« Reply #1441 on: Tue, 08 January 2013, 11:05:34 »
More importantly... Is that a Portal gun in those Amazon pics? o_0
Offline takaki
« Reply #1442 on: Tue, 08 January 2013, 11:21:40 »
I just got myself a crack kit, any guidance on tube rolling ?
The numbers, they just seem all too confusing to me. Like the same model number has so many different makes, I think I should be asking this on head-fi but this question seem so noob to be posted there and I'm too lazy to read the tube rolling thread.
Anyway, here is my humble HD600.
Offline llovro
« Reply #1443 on: Tue, 08 January 2013, 11:28:49 »
I have Logitech g930. Pretty sweet headset
Offline codymaust
« Reply #1444 on: Fri, 11 January 2013, 11:19:14 »
How do you guys feel about spending $$$ on high-end IEMs?
Just curious, because I had initially thought that I wanted to drop $100-$200 on some nice IEMs, but I've been using $25 Sony earbuds that have plenty good sound quality and a comfortable fit. Not as good as my dt770s, but miles ahead of SkullCandy/iPhone quality.
Idk if I can justify expensive buds/IEMs like I could a full sized set
« Reply #1445 on: Fri, 11 January 2013, 13:37:22 »
It depends on how often you use your IEMs. Do you take them outside when you walk? Commute? If you use them for at least 30 minutes a day, I think that would justify spending the money on some more expensive IEMs. I think if you purchase the Vsonic GR07, you will find that it is close to the DT770's performance. It's not quite there since it's an IEM, but it does have very good sound quality. For reference, I used to own the dt770/250 and I still currently use the gr07 when I go out or commute.
Offline Jocelyn
  • 조셀린
« Reply #1446 on: Fri, 11 January 2013, 13:55:58 »
This^ and I like that you used GR07 as a comparison. I own Gr07 MK II (and others), and while I agree that the Vsonic and all iems are "not quite there" for certain things (bass, soundstage, etc.) they do other things way better than overs (detail and accuracy). I will take a quick dynamic or dual ba iem over full size headphone any day of the week.
Offline takaki
« Reply #1447 on: Sat, 12 January 2013, 04:48:03 »
It really depends on how much you crave for better quality music, it probably won't be day and night difference on the first listen despite what you read from the head-fi reviews.
I would really suggest you go with a slow upgrade route, the GR-07 is a good benchmark to start with, if not the shure 215 can do the trick for a decent 1st "higher" quality IEM.
Offline wetto
  • Brazil's Keyboard Enthusiasts Representative
    • Portuguese Mechanical Keyboard Guide
« Reply #1448 on: Fri, 18 January 2013, 12:03:18 »
Got my hands on one of these Cooler Master Sirus 5.1 for review:
Damn, how can they sound so worse than some $35 headphones?
My collection:
Mice: Logitech G602, CM Storm Recon, CM Storm Spawn, Razer Naga, Ozone Radon Opto, Corsair M60, Tesoro Gandiva, CM Storm Alcor, Mionix Naos 8200.
Keyboards: Matias Secure Pro, Matias Mini Quiet Pro, custom modded Metadot Das Keyboard Model S Professional Silent (MX Brown, Costar), CM Storm Trigger (MX Brown), Noppoo Choc Mini (MX Red), Tesoro Lobera G5NFL Supreme, CM Storm Devastator.
Soon: CM Storm Quick Fire TK (MX Brown), CM Storm Trigger Z.
Boards I don't own anymore: CM Storm Quick Fire Rapid (MX Black), Logitech K800 (Membrane), Logitech G710+ (MX Brown), Thermaltake Meka G-Unit (MX Black), Corsair K70 (MX Red).
Mice I don't own anymore: Logitech G9x MW3, Corsair M65, Logitech G700, Roccat Kone Pure.
Offline Internauta
« Reply #1449 on: Sat, 19 January 2013, 20:46:37 »
Hey guys, my friend is looking into TDK's STi710 and I'm not sure if geekhack would recommend them or not! Not too sure on TDK quality, never tried or researched much! He would be satisfied with any headphones, not the BEST performence/money. He bought beats and I made him return them ;).
http://www.tdkperformance.com/en-us/Headphones/High-Fidelity-Headphones/STi710/
