Author Topic: Dirty TG3 help  (Read 1703 times)
Offline Half-Saint
Dirty TG3 help
« on: Tue, 28 December 2010, 16:01:52 »
I recently bought a used TG3 and it is easily the Champion of Dirty. How in the world do you clean a keyboard with plate mounted switches? I've already spent almost three hours scrubbing the keys and the metal plate but without actually unsoldering all the keys, it's impossible to clean!
I tried dipping a toothbrush in alcohol but the grime doesn't go away. Q-tips are so far the best but you need a ton of them to do any significant cleaning. I don't want to spend a further two hours cleaning it so any help would be much appreciated.
Cheers
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline msiegel
Dirty TG3 help
« Reply #1 on: Tue, 28 December 2010, 16:08:15 »
if there were a way to soak those parts without removing them or dripping liquid into the innards.
but how...
Offline msiegel
Dirty TG3 help
« Reply #2 on: Tue, 28 December 2010, 16:16:57 »
what about turning the board upside down and laying it on a towel dampened with water and some detergent.
has anyone tried this?
Offline Half-Saint
Dirty TG3 help
« Reply #3 on: Wed, 29 December 2010, 00:15:28 »
I'll try that although I was just about to give up on it. Let's say I got it about 75% cleaned so far...
[SIGPIC][/SIGPIC]
Offline sixty
    • http://deskthority.net
Dirty TG3 help
« Reply #4 on: Wed, 29 December 2010, 01:07:18 »
Is it one of the backlit or non backlit ones? I'm after a non backlit version since a very long time. If it is and you want to part with it, let me know.
