Author Topic: Untested M2 $10 + shipping  (Read 3594 times)
Offline msiegel
« Reply #1 on: Sun, 02 January 2011, 17:51:08 »
interesting... although no BIN
model# 1395300.
can we tell which ones are the rubber dome ones, and which the buckling spring ones?
Offline Pylon
« Reply #2 on: Sun, 02 January 2011, 17:57:26 »
1395300 is guaranteed BS I believe.
Offline PRISONER 24601
« Reply #3 on: Sun, 02 January 2011, 20:06:10 »
yup. I love the M2. Awesome design, and easy on the fingers too.
Ever tried. Ever failed. No matter. Try Again. Fail again. Fail better.
G80-3000LSCRC-2 (MX), "Ricercar" G86-6241OEUAGSA (MX), MX11800 (MX), AEKII (ALPS), AEK (ALPS) Apple Keyboard A9M0330 (ALPS), IBM Model F XT (Bucking Spring), IBM Space Saver 1391472 (Bucking Spring).
Offline MissileMike
« Reply #4 on: Sun, 02 January 2011, 22:53:51 »
"untested" on an M2 almost always means it's not working and you have to do the capacitor transplant.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
Offline msiegel
« Reply #5 on: Sun, 02 January 2011, 22:55:30 »
is there a reliable, inexpensive supply of broken ones? err, ones needing a capacitor replacement
Offline Ascaii
« Reply #6 on: Mon, 03 January 2011, 18:14:21 »
Quote from: msiegel;272206
i have 8 or so, let me know if you're interested.
Offline Shawn Stanford
« Reply #7 on: Tue, 04 January 2011, 06:30:16 »
I might be interested. What makes these different/better than a standard Model M? How tough is it to transplant the capacitor?
The Brat Prince of COBOL
Offline MissileMike
« Reply #8 on: Tue, 04 January 2011, 08:12:47 »
They're much smaller than the Model M, but other than that, they're pretty much inferior in every way.
But, if you want a smaller, cheap keyboard that still has buckling springs, it could do the trick.
Offline javifast
« Reply #9 on: Tue, 04 January 2011, 09:40:08 »
I prefer a Unicomp Spacesaver...
Too many keyboards....
Offline msiegel
« Reply #10 on: Tue, 04 January 2011, 10:32:35 »
hm, 2 hours left and still no bidders
Offline Pylon
« Reply #11 on: Tue, 04 January 2011, 13:56:14 »
Quote from: Shawn Stanford;272872
The keys are laid out flat, while the Model M is "scooped" (curved backplate). The board is also much smaller than a regular M (and even Unicomp's Space Saver)
« Last Edit: Tue, 04 January 2011, 16:30:58 by Pylon »
Offline theferenc
« Reply #12 on: Tue, 04 January 2011, 15:59:00 »
Nobody bid on it at all. I thought about it, but only as a parts donor. Then I forgot.
Ah well.
Offline msiegel
